Old 05-27-2014, 09:12 PM   #376
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Originally Posted by BeastianSTI View Post
Going to work on pulling the engine this upcoming week. Then ill just tear it down and we shall see what happened
So it has all begun. The garage is super messy though. Such disappoint
BeastianSTI is offline   Reply With Quote
Old 05-28-2014, 12:54 PM   #377
Dillinja666
Member#: 332644
07 STI
It's white
That sucks man, hopefully its something simple and cheap to fix. Keep us posted.
Dillinja666 is offline   Reply With Quote
Old 05-28-2014, 01:01 PM   #378
BeastianSTI
Member#: 310506
2005 WRX STi
Me too. I'm not sure if they bearing could have been badly chewed up from less than 5 minutes of run time, but... Hoping the damage isn't too bad.
I removed everything from the engine last night; she's ready for the engine hoist later tonight haha. I suppose there isn't any sense in ordering new bearings yet until I see what has happened.
Old 05-28-2014, 06:13 PM   #379
KornShaDoW097
Member#: 313618
2004 WRX
Oh, and just a note for anyone that reads or is following this thread...
I had a hard time with the typical piston ring compressor. I was wishing i would have went with the tapered insert rather than the sheet metal wrapping device - the final piston gave me a hard time because it was difficult to get the compressor perfectly even/level, relative to the top of the piston.
IF I had to do it again, I would buy the sleeve specific for my size bore, if not for convenience, then peace of mind that the rings/bore wouldn't be damaged
I second that.
KornShaDoW097 is offline   Reply With Quote
Old 05-28-2014, 06:19 PM   #380
KornShaDoW097
Member#: 313618
2004 WRX
I plan on putting doing 400 WHP... I've always lived by "do it right the first time, or don't do it at all".
I don't want an aluminum paperweight because I didn't follow the proper documentation. All I know is that the key to a good motor is precision in measurements and torque.
I want to build it properly. Appreciate everyone's guidance on all of this.
You sound like me on my current posts haha
Old 05-28-2014, 06:50 PM   #381
Dillinja666
Member#: 332644
07 STI
It's white
Exactly. See what the damage is and go from there.
Old 05-29-2014, 08:01 PM   #382
BeastianSTI
Member#: 310506
2005 WRX STi
Ok - something i've noticed while tearing everything apart... On the driver's side, I stuck my finger into the hollowed out back side of the intake and exhaust cams. I felt little metal slivers in there, but not in the drivers side. Both heads are off.
What is the best way to clean the heads out of all the metal flakes? I don't have a parts washer unfortunately. Is there some way I can clean them out well at home/in garage?
Old 05-30-2014, 08:11 AM   #383
BeastianSTI
Member#: 310506
2005 WRX STi
Bumpp
Old 05-30-2014, 10:16 AM   #384
ALOKIN
Member#: 348177
2013 WRX STI Limited
600whp IAG CD goodness
If you have shavings in your heads I would not trust a diy cleaning solution. Have a pro do it.
Last thing you want to do is rebuild it, and having skimped on cleaning, spin another bearing.
ALOKIN is offline   Reply With Quote
Old 05-30-2014, 10:31 AM   #385
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
This is sound ^^.
Just remember if you can see shavings anywhere where oil flows, you need to disassemble EVERYTHING and have it (heads & block & oil pump) thoroughly cleaned. If you can see it there, just think about the oil galleys that you cant see into that have had shavings pumped through with the oil.
I would also flush AVCS lines and Turbo feed and return lines, oil pan etc. You dont ANY possibility of bearing contamination when you put it back together
2Fast4U1DAY is offline   Reply With Quote
Old 05-30-2014, 11:15 AM   #386
BeastianSTI
Member#: 310506
2005 WRX STi
Originally Posted by 2Fast4U1DAY View Post
This is sound ^^.
Thanks for the advice guys. Ill see what sort of places are around here that can clean it up. Is there a certain cleaning process I should ask for?
Old 05-30-2014, 11:43 AM   #387
Dillinja666
Member#: 332644
07 STI
It's white
There is a thread about disassembling and AVCS cam gears somewhere, you will need to do that too to get the metal out of them. Did you find a spun bearing or the source of the metal yet?
Old 05-30-2014, 12:49 PM   #388
BeastianSTI
Member#: 310506
2005 WRX STi
Not yet. Just pulled the wrist poston covers. Pulling the pistons next!
Old 05-30-2014, 02:06 PM   #389
BeastianSTI
Member#: 310506
2005 WRX STi
Ok, so this is interesting ...
Check out these photos first I suppose!
It looks like a minor amount of damage to the bearings and crank as far as the mains go ( i'm not an expert of course ).
When I grab the connecting rods by the little end and wiggle side to side, they all move a tiny bit as expected but no clunking etc. When tugging on any of the rods, nothing really feels out of place. They all have the same tiny amount of play.
I'll remove the rods from the crank and take a look next... So far I haven't really seen the culprit?
Old 05-30-2014, 02:11 PM   #390
BeastianSTI
Member#: 310506
2005 WRX STi
Oh... And I read about this trick in the "tricks of the trade" thread, and dang it worked SO WELL. The wrist pistons glide out like nobody's business, and you don't scrape up the inside of the pin, etc.
Old 05-30-2014, 02:48 PM   #391
uglybetty
Member#: 381907
2005 forester STI
been following your thread for a bit now. sorry for the luck. makes me a little more cautious about doing this whole process myself in a few weeks. good luck in getting it going again soon. about the oil priming bit......have you checked to see if the turbo sent anything through there? I've always read that you should wait for oil to come out of the oil feed hose to the turbo because that is the point furthest from the pump in the oiling system. seems like you did everything right in re-reading your thread. just guessing and trying to throw something else out there that may be worth taking a look at.
uglybetty is offline   Reply With Quote
Old 05-30-2014, 03:22 PM   #392
BeastianSTI
Member#: 310506
2005 WRX STi
Yeah, im hoping to identify if there simply wasnt enough oil pressure on initial start or what. None of the bearings spun, but bearings are scuffed up a bit...
Or... there could have been metal hidden all up in the heads after machine work. Posting pictures of rod bearings soon
Old 05-30-2014, 03:38 PM   #393
Dillinja666
Member#: 332644
07 STI
It's white
IDK, but those main bearings looks done to me. I'm no expert though
Old 05-30-2014, 03:42 PM   #394
BeastianSTI
Member#: 310506
2005 WRX STi
OK - here are the pictures of the rod bearings ( some clues here I think lol ):
Old 05-30-2014, 03:43 PM   #395
BeastianSTI
Member#: 310506
2005 WRX STi
What do you guys think?
Old 05-30-2014, 03:50 PM   #396
MedicDG
Member#: 329822
2016 WRX STi
Looks like oil starvation to me. Maybe oil pump did not wk or maybe no oil on rod bearings on start up. Did u use oil or engine assembly lube on rod bearings?
MedicDG is offline   Reply With Quote
Old 05-30-2014, 04:00 PM   #397
BeastianSTI
Member#: 310506
2005 WRX STi
red line assembly lube or the bearings. Applied liberally.
Old 05-30-2014, 04:02 PM   #398
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
What method did you use to prime the engine?
Old 05-30-2014, 04:02 PM   #399
uglybetty
Member#: 381907
2005 forester STI
I'll second the not liking the look of the bearings
Old 05-30-2014, 04:09 PM   #400
MedicDG
Member#: 329822
2016 WRX STi
I was watching a YOUTUBE video and Subaru master tech used motor oil. I have no idea if that matters or not bit it looks like bearings did not get oil in a timely matter.
