Old 03-05-2014, 01:03 PM   #51
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
I think the dealership put in an 07 STi shortblock when the original owner blew it up @ 30k. Is there any way I can visually verify that it's #3?
BeastianSTI is offline   Reply With Quote
Old 03-05-2014, 01:12 PM   #52
Motion Machine
Member#: 383547
Look at #5 main, it is machined for the shoulders of the thrust bearing.
Motion Machine is offline   Reply With Quote
Old 03-05-2014, 01:15 PM   #53
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Doesnt matter year. All ej257 blocks are phase 2 which makes it a #3 thrust.
2Fast4U1DAY is offline   Reply With Quote
Old 03-05-2014, 01:16 PM   #54
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
But I am wrong lol looked at it again thats def a #5 thrust
Hard to see some of these pics on the stupid app
Old 03-05-2014, 01:16 PM   #55
BeastianSTI
Member#: 310506
2005 WRX STi
Haha - thanks for the input guys!
Old 03-05-2014, 01:19 PM   #56
BeastianSTI
Member#: 310506
2005 WRX STi
Wow - I wish I stopped by your machine shop while I was in Danville a bit over a year ago! Was doing some work @ the Commissioner / Treasurers Office - really nice people in Danville. Jimmie Gillie is quite the character - haha.
Old 03-05-2014, 01:36 PM   #57
Justin V
Member#: 98747
07 WRX
Awesome! Motion Machine is a vendor, I really want them to do my machine work.
Justin V is offline   Reply With Quote
Old 03-05-2014, 01:43 PM   #58
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Whatcha waitin for?
Old 03-05-2014, 01:45 PM   #59
BeastianSTI
Member#: 310506
2005 WRX STi
Looks like they do quite a bit of machining, based on: http://www.motionmachineinc.com/Services.html
It seems like most shops don't do align bores / crank balancing, that i've seen.
Old 03-05-2014, 02:05 PM   #60
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
I used Justice Racing for my previous build and they did both for me. IDK if they farmed the crank balancing out or not but I know they do the mains in house or at least they did
Old 03-05-2014, 02:39 PM   #61
BeastianSTI
Member#: 310506
2005 WRX STi
Damn - how much did they charge you for torque plate bore / hone?
I just called Engine Lab here in the Tampa area, and it looks like it's going to be $180 to have the block torque plate bored... That's more than double the price of normal boring from other shops.
Old 03-05-2014, 03:31 PM   #62
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Idk what they normally charge. They did a whole long block for me since my cams and journals were scored from pickup failure. I towed the car there they yanked the engine, sleeved it, cleaned up the mains, used their spec'd CP pistons manley I beams, king bearings, bore/hone, trued up the bellhousing surface to the centerline, and final cleaning/assembly. I supplied them with new head castings +1mm ferrea valves, ferreas spring/shims/retainers/keepers GSC S1's. They did the all the necessary machine work for the valves, assembled the heads and installed the heads to the block. Finished reassembling the engine (valve covers manifolds etc) installed the engine back into the car. Broke the engine in and I picked the car up about 5 weeks later to the tune of $12,500 (thats including the parts I supplied and all the work and all of the parts they supplied and a new TD04)
Old 03-05-2014, 04:09 PM   #63
BeastianSTI
Member#: 310506
2005 WRX STi
That's a lot of dough! I'm sure it was well worth having a good shop do it, but damn. If I didn't DIY, I would never be able to afford tweaking my subie lol
Old 03-05-2014, 04:41 PM   #64
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Lol yeah it was a nice chunk of change. I DIY as well, but when all of this happened I was still in tech school full time, working full time, and juggling trying to be there for my fiancÚ when her mother passed away, and taking her to the Dr for checkups on our unborn daughter. I was already running on no sleep, so theres no way I wouldve had the time to do it. Hell I had to drink 2-3 pots of coffee a day just to keep moving!
It was nice to be able to drop it off borked and pick it up and go out and drive it like I stole it right away. The only thing I didnt like about the whole deal was feeling like someone was following me on my drive down there with 12.5K cash in the car. I dont think ive ever been more nervous in my life!
Old 03-05-2014, 04:51 PM   #65
BeastianSTI
Member#: 310506
2005 WRX STi
LOL - yeah that sounds like a good enough reason. I just hope I do it right the first time, and that the machine work is spot on.
Old 03-05-2014, 05:18 PM   #66
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
All I can say is take your time during cleaning and assembly. The excitement of everything finally coming together makes it hard not to rush, and if you are rushing its easy to forget about the attention to detail thats necessary when working with tolerances that are the same thickness of an average human hair (and some tolerances are less than that)
Old 03-05-2014, 05:36 PM   #67
BeastianSTI
Member#: 310506
2005 WRX STi
That really put it into perspective for me... The average human hair follicle is roughly 100 microns = .003937". The PTW clearance alone is even smaller than that lol!
I'm just going to use a bunch of carb cleaner before putting the case together, and do it in a nice and clean environment. I may actually bring the shortblock into my apartment to ensure there isn't anything in the air.
Old 03-05-2014, 06:03 PM   #68
JonnyV2889
Member#: 197384
2006 WRX Ltd
Cleaned and calibrated is the name of the game. Have made many parts with .0005" tolerance or less, all it takes is one little chip or some dirt and your screwed.
JonnyV2889 is offline   Reply With Quote
Old 03-05-2014, 07:28 PM   #69
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
I wipe the cyl walls down with atf (you can see the crap that comes off even after hot tanking) and put it on the piston skirts before I drop em in. My Machine shop instructor taught me that old trick.
You definitely dont want any dust or dirt floating around. The last thing you want is bearing contamination after you have worked so hard to get this far
Old 03-05-2014, 07:59 PM   #70
Motion Machine
Member#: 383547
I get $260 to bore/plate hone/ clean a Subaru. But bear in mind, this is done on a 4 axis CNC with the cases torqued together for the entire process, including honing. I set up off the factory datum and can correct bore locations to the blueprint spec.You cannot access the datum when just clamping the case halves on a mill table or a boring table. I'm not saying you can't do them this way, lots of shops do. But if you want your block blueprinted and have equal deck heights, it must be done on a 4 axis. This video shows the process
Old 03-05-2014, 08:35 PM   #71
BeastianSTI
Member#: 310506
2005 WRX STi
I've heard some say to use engine oil instead of atf. Could the ATF damage the cylinder walls / bore? Why would the say not to use it, I wonder ...
Old 03-05-2014, 09:25 PM   #72
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Ive used that trick on the 20 or so engines ive built for myself for friends and for customers at the shop without a failure.
It wont hurt anything. It actually helps the ring seal by helping the seating process along. Never was given a clear explanation as to why but it works! I do it on every build.
Old 03-05-2014, 10:23 PM   #73
BeastianSTI
Member#: 310506
2005 WRX STi
Interesting!
I just sent an e-mail to my local machine shop requesting an itemized invoice for all of the things listed. Hoping I can keep my left leg ;-)
Old 03-05-2014, 10:38 PM   #74
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Interesting!
Ha good luck. I lost an arm a leg and half my left nut on my build by the time I got the 20g, got the fuel system sorted, and a 2 hour tune session. All said and done IIRC I was into it for 15-16k but like I said I didnt really have the time to do the wrenching so I payed ALOT in labor
Old 03-05-2014, 10:56 PM   #75
BeastianSTI
Member#: 310506
2005 WRX STi
Yeah... Hey - at least you already have a top-feed system. I've gotta source some parts to make it to e85 / ID1300s!
