Old 01-17-2014, 06:38 PM   #1
neb_subi
Member#: 329049
04 sti
PSM (unfortunately)
Default Aftermarket hub and quick release
I've been looking into going with a short hub and a quick release for my 04 sti.
I have already removed the stock steering wheel and have found out my stock clock spring is broken.
Now I know when you use a NRG short hub that you have to remove the clock spring. In others opinion is it worth using the nrg hub and getting rid of the clock spring or have most used the works bell hub and kept the clock spring so yet could use the horn and turn signal stalk
neb_subi is offline   Reply With Quote
Old 01-17-2014, 06:45 PM   #2
neb_subi
Member#: 329049
04 sti
PSM (unfortunately)
The main question I ask all of this is since my clock spring is broken will the horn and turn signal still work without the clock spring and just an nrg hub
Old 01-24-2014, 05:09 PM   #3
mephistomarius
Member#: 330895
2002 Impreza wrx
blaze yellow
you have to hook up the horn, blinkers just wont auto turn off
mephistomarius is offline   Reply With Quote
