Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 01-21-2014, 06:47 PM   #26
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
This was on straight 91?
Old 01-21-2014, 06:59 PM   #27
Kuros
Member#: 328669
2011 STi boosted FRS
04 sti
That's what it says, bruh.
Kuros is offline   Reply With Quote
Old 01-21-2014, 07:09 PM   #28
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
I wasn't asking you, bruh.
Old 01-21-2014, 07:16 PM   #29
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
yea straight 91 oct.
renosubby is offline   Reply With Quote
Old 01-21-2014, 07:38 PM   #30
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
Awesome!
Old 01-22-2014, 08:57 AM   #31
Flat4ATX
Member#: 301539
2006 STi
Impressive, subscribed to see how this progresses on better fuel.
Flat4ATX is offline   Reply With Quote
Old 02-01-2014, 02:29 AM   #32
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Started the pull alittle late but took it to 7600rpm now still 22.5 psi
Old 02-01-2014, 03:34 AM   #33
BURNING4ORCE
Member#: 356215
NV 91 better than CA 91 octane gas? Power is insane on pump 91 congrats on the tune and setup.
BURNING4ORCE is offline   Reply With Quote
Old 02-02-2014, 08:24 PM   #34
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Thanks man. No gas is the same as CA.
Old 02-05-2014, 02:03 AM   #35
BURNING4ORCE
Member#: 356215
Good to know. Kudos to you man those are some awesome numbers as I don't see too many people making these kind powers on pump CA 91 on a subie.
Old 02-05-2014, 10:14 AM   #36
Daggernomad55555
Member#: 343485
2008 TT VR6 GTX4202r
3826/3851lbs seems heavy for me. Did you make pulls with a buddy with you ?
I still cannot believe you do that much power on 91 octane gas! Not hater, i am just curious what you do that other people don't ...
Daggernomad55555 is offline   Reply With Quote
Old 02-05-2014, 10:16 AM   #37
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
That is amazing power and spool on 91 with that fairly conservative timing and the AFR's. It's a beast and the head work seems to be making it shine! Look out once you tune it with E85!!
Old 02-05-2014, 11:22 AM   #38
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
No I understand It was me and a buddy. Basic tools set. Car seat and a block with pistons and rods. Was heading to machine shop to drop it off
Old 02-05-2014, 11:30 AM   #39
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Its easy. He's running a large turbo at a lower boost level where its not creating much heat or requiring much for driving pressure. Couple that with a nice safe AFR and this kind of power level is achievable. I'd never try this on a non-built motor though, one detonation event and it would be game over.
I'm excited to see what this setup does on higher boost and E85.
WRXt4cy is offline   Reply With Quote
Old 02-05-2014, 11:32 AM   #40
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
I'm doing a very similar build and will be running a closed deck also with 99.5 mm pistons. I will be running 93 octane and after seen the awesome results on 91 octane I'm super anxious to get my car done. I already have PnP heads with kelford 276/272 cams. I will be adding +2mm valves since i have stock size WRX valves now. Hoping for 550whp or more on 93 octane and 650-700 in E85 at 35 psi.
OP, you have stock size STi valves? When you plan to run E85 and how much boost you shooting for?
Wil
wil06STI is offline   Reply With Quote
Old 02-05-2014, 11:45 AM   #41
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Wil
Which block are going with? Outfront bores out to 99.75 after the deck pieces are pressed in because the process distorts the sleeves a bit.
Old 02-05-2014, 12:19 PM   #42
Daggernomad55555
Member#: 343485
Seems to be the key here.
So, the weight you give is perfect and that shouldn't change results. I just wanted to know.
Give at that beast a bit of alcohol !
Old 02-05-2014, 12:35 PM   #43
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Wil
Stock size valves. E85 won't happen prob. So not sure what I'm gonna do yet
Old 02-05-2014, 01:57 PM   #44
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
I'm going with the Element Tuning Closed Deck which doesn't required a line hone or bigger size pistons. I want to run as much boost as i can so don't want to bore out the cylinders.
Old 02-06-2014, 10:19 AM   #45
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
The insert is NOT pressed in, its "sucked" in...
2Fast4U1DAY is offline   Reply With Quote
Old 02-07-2014, 10:51 AM   #46
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
I have no idea how that would be done but sounds cool
wrxsubiemod is offline   Reply With Quote
Old 02-07-2014, 11:15 AM   #47
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
I didnt expect them to tell me their secrets! I was inquiring about what they do to the block AFTER the insert, as I too thought it was pressed in. John informed me that they are not pressed in but "sucked". This means no distortion of mains and a bore/hone to fit is the only real necessity after having the insert done.
Old 02-07-2014, 11:35 AM   #48
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Edit: Clarification was already posted.
Still curious how exactly "sucked in" is correct and how that process works but that info is good to know. John is the man for sure.
Old 02-07-2014, 11:48 AM   #49
toph
Member#: 78640
14 KTM SuperDuke
15 STi CWP | 02 STi Wagon
Nice another MA guy with an Element closed deck
toph is online now   Reply With Quote
Old 02-07-2014, 11:57 AM   #50
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Theyd never tell us... I mean John may WANT to tell us but this is going to be his (and anyone else that works at outfront) bread and butter for a while. Id only tell the public what they need to know and keep the secrets a secret... jus sayin ;-)
Theres a couple way that I can think of having it sucked in but I dont want to give their secrets away unintentionally
