Old 01-22-2014, 10:40 PM   #1
jussblaze
Member#: 294526
Default Advice on my STI map
Greetings I have a 2003 JDM STI with simple mods and I would just like some advice as I am new to the tuning. I have read several tuning threads and am familiar with most of the terms and a general idea of how they operate. I am familiar with learning view and rom raider, which I use to log my car.Basically I would just like to get some feedback on my current setup and where I can improve on my map.
Car Mods:
Stock internals
Stock intake
VF-37
full 3" turbo back exhaust
excedy heavy duty clutch kit
Grimmspeed 3 port EBCS
AEM water meth kit (start at approx. 10 psi) 50/50 mix
95 octane gasoline
target AFR on ECU is 12.3
actual AFR @ WOT is11.5
both logs were done in 3rd gear
HTML Code:
https://docs.google.com/spreadsheet/ccc?key=0ArXt7JQVH-u-dEFWVFI2NUxwRzNVTXd2eEdWeW11RVE&usp=sharing
HTML Code:
https://docs.google.com/spreadsheet/ccc?key=0ArXt7JQVH-u-dExLaFdCMlc3SlZnTTBDcmw1ajRjenc&usp=sharing
jussblaze is offline   Reply With Quote
Old 01-22-2014, 10:55 PM   #2
Bluestreak03
Member#: 125887
2003 18g ej255 swap
04 STI WRB
what do you A/F look like, and am i reading that correctly target boost of 21? if i read that right its trying to pull just a lil bit of timing in the mid range 3k-5k.
Bluestreak03 is offline   Reply With Quote
Old 01-22-2014, 10:58 PM   #3
jussblaze
Member#: 294526
hey thanks for the reply my AFR is 11.5 average
Old 01-22-2014, 11:00 PM   #4
jussblaze
Member#: 294526
^^ yeah 21 is the target boost, am I running too much timing for my setup?
Old 01-27-2014, 01:39 PM   #5
leforce
Member#: 246246
Yes, pull around 1.5 degrees between 3k-4k
Load figures look high, check for boost leaks.
leforce is offline   Reply With Quote
Old 01-27-2014, 05:56 PM   #6
jussblaze
Member#: 294526
^^ hey thanks for the advice will reduce some timing around the lower range and post up the new logs when I get them. Also will look into the boost leak checks. Thanks again
Old 01-29-2014, 01:51 PM   #7
jussblaze
Member#: 294526
updated log of another 3rd gear pull.
https://docs.google.com/spreadsheet/...FE&usp=sharing
after doing some checking i realized that my aem meth controller was set to stat @11 psi and max @ 33 psi which obviously i am not getting out of my turbo. So i adjusted the start from 11psi to 7 psi and logged the car:
https://docs.google.com/spreadsheet/...Xc&usp=sharing
looking at the first log my car starts to knock around 7psi so i adjusted the meth to start to spray @7psi and from the second log the knock stopped. I also adjusted the max from 33 to 20psi (didn't log this pull) but i noticed the difference when the max spray came on. In addition my AFR dropped from 11.5 to 11 and on my base map my target afr is 12.3.Now i assume that my spray nozzle is too big(mechanic installed the largest nozzle). I will install the medium jet which hopefully brings my afr back up to ~11.2-~11.8 with my start spray @7psi and max @20psi.
Old 01-31-2014, 03:14 AM   #8
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Can't you adjust your maf table to get close to Afr in fuel table and tune that way. The big nozzle is fine I would have start meth at 7-8 and max at 15-16 psi to be honest.
renosubby is offline   Reply With Quote
Old 01-31-2014, 06:47 PM   #9
jussblaze
Member#: 294526
already installed the medium jet, afr came from 11 up to 11.2 with start @7 and max @18 have to do some more teaking so i'll post the log when i do it. thanks
