Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 10-14-2002, 11:32 PM   #1
2003 sedan
Member#: 24103
Talking When does the PCM shut down the engine do to too much boost?
Ok I just couldn't leave well enough alone!! Tweaking the boost and HELLO the computer said THATS IT!! Then the ever loving CHECK ENGINE light followed(this happened at night so my wife and I could really enjoy the amber ambiance) but luckily I hooked up the scanner at work and got that nasty reminder on the dash to go away. By the way I think the code was a PO244. So back to the question. When is too much boost too much. I know one or more of you guys has to know this . Thanks for your input and comments.
2003 sedan is offline   Reply With Quote
Old 10-14-2002, 11:55 PM   #2
HellWagon
Member#: 16172
Stock turbo... conservatively I would say 16 psi*
*Over that... The consensus seems to be that you will just be getting a bunch of hot air.
HellWagon is offline   Reply With Quote
Old 10-15-2002, 02:17 AM   #3
LiquidIQ
Member#: 6408
2014 FiST 2004 MSM
Race Red & Velocity Red
You should be adjusting the fuel mix if you are raising boost.
LiquidIQ is offline   Reply With Quote
Old 10-15-2002, 09:32 AM   #4
nickgomez
Member#: 16820
88 535i
alpinweiss
I believe 17psi and the computer cuts the fuel. It can spike higher than 17psi momentarily.
Dominic
nickgomez is offline   Reply With Quote
Old 10-15-2002, 02:38 PM   #5
2003 sedan
Member#: 24103
Thanks nick thats what I was looking for
Weird boost gauge readings or too much boost in the cold? Blown95ImpalaSS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-29-2005 07:15 PM
What to do about too much boost? Ren4Dub Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 11-21-2005 07:43 AM
Too much boost back to stock! aspenwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-24-2003 12:34 PM
Boost Monkey + MBC cranked down = too much boost, help! Mephiska Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 06-24-2002 03:17 PM
