Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 02-07-2014, 07:13 PM   #26
B-85
Member#: 60628
1994 Sti.94,Sold 96.
Well this is almost a harness?
I will start a temp run to see what can be trimed.
Randy
B-85 is offline   Reply With Quote
Old 02-10-2014, 09:33 PM   #27
B-85
Member#: 60628
Another Doner! More parts,what to do ,what to do?
Old 02-10-2014, 10:06 PM   #28
B-85
Member#: 60628
Well , the motor is almost in
Just messsing with you ! But it is VERY COOL?
Randy
Old 02-10-2014, 10:21 PM   #29
JapCarRealGood
Pirates > Your Mom
Member#: 104055
96 RHD555 98RHDSTi
99OBSTi 91NSX 06 9-2xAero
Rally Stuff
^ LoL... Looks like the 2008 Subaru World Rally Team (SWRT) S14 set up?!?
JapCarRealGood is offline   Reply With Quote
Old 02-10-2014, 10:30 PM   #30
JapCarRealGood
Pirates > Your Mom
Member#: 104055
96 RHD555 98RHDSTi
I'm pretty sure the white Fozzy is a restored/salvage title because of teh fire...
How's the black Fozzy's title?
If it's clean, I'd swap that one instead, and up the resale value by a lot.
I still think should you swap a 93-95 Impreza instead...
It's easier to make road worthy, to emission with just a simple idle/sniffer test, and sell in the future.
-DBB
Old 02-10-2014, 10:48 PM   #31
B-85
Member#: 60628
I've been thinking about thar DBB,but this one just seems more fun ?
Have run into a problem with the title on the white car. Trying to work it out?
So,I may need to go with the Black one ?
But may need to get V6/7 for something to do in retirement !
Old 02-14-2014, 06:59 PM   #32
Kuros
Member#: 328669
2011 STi boosted FRS
04 sti
I envy your determination and patience!
Kuros is offline   Reply With Quote
Old 02-14-2014, 10:21 PM   #33
B-85
Member#: 60628
More cleaning and fitting.
This is what is under your dash!
And here is what needs to go to the dask!
Some temp fitting of the air/box and the MAF.
And a shifter. Still will need to see if it will work with the old Sti. trans ? May need to fab some stuff ?
Thanks to Jerome ! He has a cool build going!
Randy
Old 02-15-2014, 03:28 PM   #34
B-85
Member#: 60628
Also a Thanks to Eric at Integrity Auto Repair for his help.
Randy
Old 02-16-2014, 06:09 PM   #35
B-85
Member#: 60628
Got started on reconstituting the motor and transx from a mid-engine setup from my tube car . Photo of the adaptor that makes it a FWD or Mid-engine. Also some motor shots.
Installed the used shifter I got ,think it is from a 07 and looks like it will work ? I will know more when I fit it to the chassis.
Still working out where all the backets went too?
Randy
Old 02-17-2014, 10:25 PM   #36
B-85
Member#: 60628
Getting the turbo back on and repairing the motor harness. Good day!
Also ,looks like the parts from PA. well get sent. Weather is the problem. Funny here in AZ. it was 80+ today ???? :icon_wink:
Randy
Will need to work on the exhaust outlet ? maybe a ?
Old 02-19-2014, 12:38 AM   #37
B-85
Member#: 60628
May need to move to the Black chassis? Problem with the White cars title?
Got the motor just about dressed.
Randy
Old 02-20-2014, 08:46 PM   #38
B-85
Member#: 60628
Doing some work on the front, cross frame. Fitting the Sti. sway bar and the Alum. arms. Need some bushings and balljoints. Trying to see what chassis the sub-frame came from ? Ideas ? Has the cutouts for the turbo uppipe.
Randy
Old 02-21-2014, 10:11 PM   #39
B-85
Member#: 60628
Some work with the motor carrier and a shot of the Black Car.
It Fits!!
Will need some work ?
Randy
Old 02-22-2014, 08:51 PM   #40
B-85
Member#: 60628
Washed the Black car. Man,does it need body work! Need to look into getting a title for the white one!
I know that no one would do a 1994 Sti swap ( just this dum -ass) into a 98+ Forester but here are some things I haved learned.
The holes for the power steering are just off, so you will need to elongate them.
The doner is RHD and the steering hoses will not work with the US pump. Maybe a WRX would but I don't have a WRX. I will just have some hoses made. Also did some bending of the banjo fitting for the pump. Will need to weld some ends on the steel pipe for the hoses. Thinking a AN fitting ? The presure side is like 2500 PSI. at lock. The return line is no big deal. It will go to the cooler and then to the pump return.
Read something that the RHD pump can't be used on a LHD steering system ? So I reused the Forester's pump. Most of this is to keep and clear the coolent tank (just if front of the Turbo) and to reuse the Sti. radiator.Will also need some heatstop on the hoses. Wi also rap the uppipe.
Bill I don't know what size tubing I will use for the bumper yet.
Old 02-24-2014, 10:22 AM   #41
Kenward
Member#: 297091
2012 STi Limited
Sub'd. This will be great.
Kenward is offline   Reply With Quote
Old 02-24-2014, 06:23 PM   #42
B-85
Member#: 60628
Got some parts today. Thanks Markos ! At Camelback Subaru Mazda .
And also had the power steering hoses made. Went with a -6 hose that can be replaced in the future if needed.
Randy
Old 02-25-2014, 07:40 PM   #43
B-85
Member#: 60628
Need some input. What is the best oil for the transmission? Also for motor oil ?
Found some more parts and got them installed.I also installed the stock heat shields . Will need to wrap the uppipe. And also do something about the turbo ?
Randy
Old 02-27-2014, 10:08 PM   #44
B-85
Member#: 60628
More new/old parts. I'm at a point to be able to install the motor/tran's package ! Also did some work on the Forester ABS removel and Sti brake install. Going to be able (with a lot of rebending ) to reuse the brake lines with some reflairing of lines.
Input?
Randy
Old 02-28-2014, 03:17 AM   #45
CodeRed30
Member#: 350787
2013 WRX
<--------Silent observer. Can't wait to see the end result!
CodeRed30 is offline   Reply With Quote
Old 02-28-2014, 04:01 AM   #46
yman
Member#: 199051
04 sti
psm
Randy
This is just my opinion but:
Either Rotella T6 or some quality dinosaur oil in the motor and subaru GL5 on the trans unless you're getting grinds. I've had good results with the Amsoil severe gear 75w90.
yman is offline   Reply With Quote
Old 03-03-2014, 09:07 AM   #47
shoesandsocks
Member#: 383434
awesome build so far definitely going to subscribe
shoesandsocks is offline   Reply With Quote
Old 03-03-2014, 12:37 PM   #48
B-85
Member#: 60628
Lines all reused and ready to be bleed . Looks almost stock. I need to work on my line bending ?
Randy
Old 03-03-2014, 09:38 PM   #49
LESSthanDan
Member#: 358897
05' WRX Wagon
Looks good man. Subscribed for sure!
LESSthanDan is offline   Reply With Quote
Old 03-04-2014, 09:09 PM   #50
B-85
Member#: 60628
Here are the photos of what makes up the engine bay parts. From the green tape to the pump is removed and reused. Take a look at the black cars motor bay to see it replumed.
Then its just taking the time to remove all the electric stuff! = taking the inside of your Forester apart !! Or just leave it ?
For today I setup things to remove the rear tray and install the tray from the white car. It has the disc brake hangers,the other is a L drum system. Oh, and moving the white car into the bay the left front wheel and bearing fell off!
