Old 10-15-2002, 10:15 AM   #1
Austin
Member#: 7089
2016 STi
Default TEC2/TEC3 & EJ20 - Correct Knock Sensor
Knock frequency is based on engine bore size, which, for the EJ20, is 92mm/3.62in. The bore size for an EJ25 is 99.5mm/3.917".
The knock sensor supplied with my TEC3 (which I'm assuming is the knock sensor sold by Electromotive) gave pure crap response on my EJ20. Noise levels 50-70 (on a 0-100 scale) centering around 3500 rpm, and then dropping to 15-20 at 7000 rpm - not at all what was actually happening. Spikes to 100 when there was definitely no audible knock, and zero response when there was definitely audible knock.
I needed a GM knock sensor tuned/designed for an engine with a 3.62" bore size. (Tuned to sense knock at 6250 Hz) After researching it, I've found one.
Borg Warner p/n 8009 or S8009
OE #'s 1103700 or 10456019
Buick 88-94
Cadillac 88-90
Chevy 88-92
Chev P/U 92-95
GMC 93-95
Oldsmobile 87-94
Pontiac 88-94
This knock sensor works just like you would expect a knock sensor to work. Noise levels up to 30 at 7000 rpm, increasing with a nice steady trend. Definitely senses actual knock.
Closest I could find for EJ25 is is a knock sensor from an LS1 or LT5 chevy 350. Both have a bore of 3.900, compared to your bore size of 3.917
Austin is offline   Reply With Quote
Old 10-15-2002, 11:05 AM   #2
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Wow, thanks for the info!
Can I ask what you referenced for the GM bore sizes?
And would you have the PN's for the LS1 OE sensor and borg warner?
Thanks!
-Nate
crash is offline   Reply With Quote
Old 10-15-2002, 12:36 PM   #3
Austin
Member#: 7089
2016 STi
I referenced autoparts store's catalogs of engine rebuild kits. Basically went page by page to find motors with specific bore sizes.
I don't have the PN for the LS1 sensor, but if you search for this thread on the Vishnu boards, somebody has it.
Old 10-15-2002, 10:08 PM   #4
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Part # for LS1 knocksensor
AC Delco
ACD# 213-362
GM# 10456603
(Working on a way to get this sucker to mount to the block... Will post pics later.)
Revision is offline   Reply With Quote
Old 10-15-2002, 11:23 PM   #5
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
What about the 2.5L that is in the S-10 pickup? It is even metric thread.
david2z4 is offline   Reply With Quote
Old 10-16-2002, 12:31 AM   #6
Austin
Member#: 7089
2016 STi
Well, you should have the owner's manual... What's the bore size for that engine?
Old 10-16-2002, 09:01 AM   #7
Revision
Member#: 242
MY05 PSM GGA !STOCK
Unless that s10 has a aluminum block and heads like the EJ25 and the LS1...
Heh, the EJ25 is like 1/2 of a LS1 right?
Old 10-16-2002, 09:17 AM   #8
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
So where can we change GM references for other engines? My EJ22T is a different bore so I need to see what's best for it. I plan to run a TEC when I put the engine in next spring hopefully.
Jon
omahasubaru is offline   Reply With Quote
Old 10-16-2002, 11:04 AM   #9
Austin
Member#: 7089
2016 STi
Jon
Like I said, I had to go down to the autoparts store and pour through the catalogs for engine rebuild kits. Dealers didn't have a good info source, couldn't find any good sources on the net...
Old 10-16-2002, 08:30 PM   #10
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
ok
the 2.5L for 1985-1990 and maybe later is a 4.0 (101.6mm) bore.
the 2.0L and the 2.2 vortec is a 3.5 (89mm) bore
tec2/tec3 and a ej20 anyone? Jaxx Engine Management & Tuning 6 04-11-2005 11:54 AM
TEC2, TEC3 - Use same MAP sensor? Chris Stein Engine Management & Tuning 0 09-30-2003 08:06 PM
TEC2 w/ stock Knock Sensor ? Cusco Engine Management & Tuning 1 07-03-2003 12:00 AM
Correct Knock Sensor for EJ20 + TEC3 Austin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-29-2002 01:14 PM
TEC3 & EJ20 - Correct Knock Sensor Austin Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-15-2002 11:46 PM
