Old 01-29-2014, 10:30 PM   #1
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Default delete
delete
xabre1200 is offline   Reply With Quote
Old 01-30-2014, 08:02 AM   #2
sexyyrex
Member#: 128022
2015 Mustang GT
stock car? do you have a tune?
sounds like someone forgot to adjust the warm start cranking tables.
sexyyrex is offline   Reply With Quote
Old 01-30-2014, 11:07 AM   #3
TommyShibby
Member#: 365303
2011 STi Hatch.
I have the same f ing issue! Except it is like that everytime I start it haha. I have been concerned for a while that something is wrong with my 11 STi.... How do I check this stuff? Also my car is kinda slow recently... Also if I unplug the battery and forget to retune, I go to start up and it never starts. I am runnin 93 oct stage 1 + SF. I then retune and it still barely wants to start up! Any help would be greatly appreciated..
TommyShibby is offline   Reply With Quote
Old 01-30-2014, 11:21 AM   #4
TommyShibby
Member#: 365303
2011 STi Hatch.
Default Oil too
It is also just eating up oil!!
Old 01-30-2014, 11:25 AM   #5
themaus
Member#: 321211
You probably have busted ringlands or something else going on with your motor.
themaus is offline   Reply With Quote
Old 01-30-2014, 11:46 AM   #6
TommyShibby
Member#: 365303
2011 STi Hatch.
**** balls! How do you check for that?
Old 01-30-2014, 12:07 PM   #7
VictorOfHavoc
Member#: 341994
2010 Wrex
compression and leak down test
VictorOfHavoc is offline   Reply With Quote
Old 01-30-2014, 12:42 PM   #8
TommyShibby
Member#: 365303
2011 STi Hatch.
Thanks dude
Old 01-30-2014, 02:38 PM   #9
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
ttttt
Old 01-30-2014, 02:40 PM   #10
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
ttttt
Old 01-30-2014, 02:42 PM   #11
VictorOfHavoc
Member#: 341994
2010 Wrex
Originally Posted by xabre1200 View Post
I'm running stage 1 but my car doesn't eat up oil like that and my power seems fine.
Are you Cobb tuned or open-source?
Old 01-30-2014, 02:44 PM   #12
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
It's a stage 1 ots tune by torqued performance.
Old 01-30-2014, 02:48 PM   #13
VictorOfHavoc
Member#: 341994
2010 Wrex
Take some logs after warming up, cruising on the highway, and after it has trouble starting. Send them off to Eric and see what he says. He'll respond really quick. Both of my cars are tuned by him and I couldn't be happier with the tunes. Chances are your warm engine starts need to be tuned up a bit...
Old 01-31-2014, 10:14 AM   #14
swpshgnwgn
Member#: 150494
17 WRX Limited
I actually have the same issue running stage 2 torqued. Eric and I had gone back and forth with logs so not quite OTS. Let me know what you hear.
swpshgnwgn is offline   Reply With Quote
Old 01-31-2014, 04:26 PM   #15
0V3RC10CK3D
Member#: 285081
2011 Subaru WRX
I have the same issue on my 100% stock 2011 WRX.
Thought it might be the battery so I swapped it for a yellow-top. It did seem to start much quicker for months but now it will chug for a bit before turning over. Really strange.
0V3RC10CK3D is offline   Reply With Quote
Old 01-31-2014, 04:35 PM   #16
VictorOfHavoc
Member#: 341994
2010 Wrex
sounds sir like you might have a ground issue...
these newer subarus tend to have issues with puddle lights, fog lights, rear center brake lights, headlights (for 2011+), and passenger airbag light (2009 to 2011 Forester) grounding issues...
If you have any of these, which you probably do, then chances are you have a small ground that over time will wear down your battery. I'm still looking for mine on my Forester XT and on my WRX I had to swap my battery recently (more from age than anything else)
Old 01-31-2014, 07:12 PM   #17
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
ttttt
Old 02-01-2014, 07:48 AM   #18
sexyyrex
Member#: 128022
2015 Mustang GT
well, I cant think of anything else that would make your car not start with warmer operating temps. OP, if its an accessport i'd strongly suggest flashing to the cobb OTS map and see how that works for you. FYI, Cobb is a trusted OTS map. If another company developed the map, it's considered custom stage 1, not OTS.
I can't really think of a scenario other then a tune that would cause this issue.
cheers.
Old 02-01-2014, 08:56 AM   #19
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Any reason why you are using the real-time tune and not reflash? You should not need to reflash after an ecu reset/disconnected battery.
Cathexis is offline   Reply With Quote
Old 02-01-2014, 08:59 AM   #20
TommyShibby
Member#: 365303
2011 STi Hatch.
I am using reflash! Even though i use reflash I still have to retune every time I disconnect the battery! It sucks.
Old 02-01-2014, 11:49 AM   #21
themaus
Member#: 321211
You are doing something wrong.
Old 02-01-2014, 11:55 AM   #22
jt subie
Member#: 364962
2012 WRX
^this^
jt subie is offline   Reply With Quote
Old 02-01-2014, 12:26 PM   #23
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Plug in your ap. Go to the map screen (not sure what its under offhand since I am at work maybe someone can chime in) and tell us what map it says you are on under reflash AND real-time.
Old 02-01-2014, 12:27 PM   #24
99pgpgt
Member#: 338096
2013 WRX
Could also be the ground wire issue for the coils. Something to look at.
99pgpgt is offline   Reply With Quote
Old 02-01-2014, 12:30 PM   #25
99pgpgt
Member#: 338096
2013 WRX
Xabre, check this out. It may be your problem.
http://forums.nasioc.com/forums/show....php?t=2550077
