Old 01-30-2014, 11:26 AM   #1
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
Default my Ipad install 2011 wrx
After seeing another members install of their Ipad, I decided to tackle mine. Mounting ipad with single din radio behind in for all stereo functions.
I'm no professional by any means so don't flame me to much.
Ive done some fiberglass stuff in the past so I started with some fleece and wrapped a 2x4 and ipad
After working with the fleece for awhile it came apparent that I needed to redo in fiberglass mat. it was by far the best way to do it.
after cleaning up the fiberglass some
Splinter51 is offline   Reply With Quote
Old 01-30-2014, 11:31 AM   #2
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
I then decided to add a finger slot to be able to pull the ipad out.
I then ordered some magnets off Ebay to attach to the top to hold Ipad in.
I dremeled hole and slid magnets in and refiberglassed them.
Old 01-30-2014, 11:38 AM   #3
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
after some thought, I decided to take the finger slot out. It didn't look the greatest.
The Ipad for the most will not be taken out of care. Most radio functions can be done on steering wheel. After cleaning the fish tank one afternoon it hit me. one small suction cup and I can pull it out at will, if need be. suction cup is kept in glove box if needed and it looks ten times better. Here it if test fitted
Old 01-30-2014, 11:43 AM   #4
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
I used some plastic weld to glue the fiberglass piece to the bezel, it worked awesome. After many coats of filler and sanding, we're at this point. Notice that a had to move the plastic bar just above the vents done also. it was trimmed shorter and glue it with same glue. In this picture the spots to the right of Ipad, are just reflections from meter on Ipad.
Old 01-30-2014, 11:47 AM   #5
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
Here we are with a few coats of filler primer. Still a lot of sanding to do.
Ipad fitting like a glove
I will be painting in the next day or so. I'll keep you posted
Old 01-30-2014, 11:48 AM   #6
HammrsHell
Member#: 363758
2013 WRX Hatchback
Satin White Pearl
damn man thats excellent!!
HammrsHell is offline   Reply With Quote
Old 01-31-2014, 06:56 PM   #7
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
Paint all done! Waiting on Alpine
Old 01-31-2014, 06:58 PM   #8
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
Old 01-31-2014, 07:34 PM   #9
SidewinderLGT
Member#: 357383
2011 Legacy 2.5i
Crystal Black Silica
How's the Vent functionality? If you set the heating too high up, does it affect the iPad or affect the fiberglass? And how much flow are you getting/losing out on, if applicable?
Awfully cool stuff. I'll be watching; keep it up!
SidewinderLGT is offline   Reply With Quote
Old 01-31-2014, 07:56 PM   #10
HammrsHell
Member#: 363758
2013 WRX Hatchback
Satin White Pearl
How is the connectivity with the rest if the car? Steering wheel controls. How do you have it hooked up to interface with everything?
Old 02-01-2014, 11:05 AM   #11
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
I will be putting in a alpine head unit with steering wheel controls. So volume and track up and down will still be done from there. The vents are still completely sealed, so heat still works. Not to worried about the heat on those vents because I mainly use floor and side vents. Thanks for the input
Old 02-01-2014, 11:50 AM   #12
USMCBuckWild
Member#: 285422
2004 Forester XT
JBP
Great job OP!!
I need to give fiberglass a try. Never done anything with it before, why not start now
USMCBuckWild is offline   Reply With Quote
Old 02-01-2014, 12:06 PM   #13
laxaholic
Member#: 338950
2006 Impreza 2.5i
This is awesome! On my list of things to do for sure
laxaholic is offline   Reply With Quote
Old 02-01-2014, 12:22 PM   #14
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
Really simple. The filler I used is a putty coat. I got it from oreillys. It sticks really well to the plastic. Bondo filler will not stick very well.
Old 02-01-2014, 12:27 PM   #15
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
Going to get a skin for my iPad, thinking brushed aluminum.
Old 02-01-2014, 12:34 PM   #16
KFREX
Member#: 330609
2016 Subaru WRX
Very clean and very cool! Super impressed with the fit & finish
KFREX is offline   Reply With Quote
Old 02-11-2014, 08:51 PM   #17
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
Finished up
Old 02-11-2014, 08:52 PM   #18
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
Old 02-11-2014, 09:38 PM   #19
uicsux
Member#: 144983
2011 honda
odyssey
good looking install.
uicsux is offline   Reply With Quote
Old 02-11-2014, 09:53 PM   #20
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
slick!
WhatsASubie is offline   Reply With Quote
Old 02-16-2014, 12:03 AM   #21
CPRICEIV
Member#: 322726
2012 WRX 5 Door D9R
Impressive... very clean setup. Someone needs to mass produce one of these mounts!
CPRICEIV is offline   Reply With Quote
Old 02-16-2014, 02:03 AM   #22
toad37
Member#: 373205
wicked!
toad37 is offline   Reply With Quote
Old 02-16-2014, 02:41 AM   #23
trx450r1989
Member#: 324468
2000 RS 2.5
wow that is awesome!!
trx450r1989 is offline   Reply With Quote
Old 02-17-2014, 09:53 PM   #24
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
Decided to make a second one. Pretty much same thing except angling down toward radio. May sell one when I finish it
Old 02-17-2014, 10:25 PM   #25
07wrxstage2
Member#: 262366
07 wrx-sold 06sti-
sold 00rs-rip 05 GRP LGT
Very cool and great work! Curious about the finger slot. I didn't notice it in the finished pictures?
07wrxstage2 is offline   Reply With Quote
