Old 01-30-2014, 04:24 PM   #1
outfrontmotorsports
Member#: 220204
Default Outfront Motorsports 1/2" Stud Torture Test, compared to ARP 2000 and 625+
The results are in, we just performed the ultimate head stud torture test on uncut video (soon to be uploaded).
we tested a stock fastner with a snap-on digital torque wrench with torque recall.
the stock fastner gave way at 125ftlbs. at this point the stud felt like it was deforming/growing (it did not pull out)
11mm ARP2000, this fastner torqued to 166ftlbs (from memory) when the fastner had no more to give. it also appeared to be stretching
11mm 625+ this fastner torqued to 185 ftlbs when it wouldn't go any more, it also started to stretch
this shows that these two studs above are really at their max torque (75% of yield)
The New Outfront 1/2" head stud torqued to 201ftlbs and then our socket broke. getting a new socket we torqued it to 233ftlbs, the fastner still felt strong and no feeling of stretch.
torque facts from ARP
ARP 11mm 2000= 15,700 pounds clamping at 90ftlbs cost $220 220ksi
ARP 11mm 625+= 18,000 pounds of clamping at 100ftlbs cost $520 260ksi
Outfront 1/2= 20,500 pounds of clamping at 140ftlbs cost $480 220ksi
Our studs do require block and head machining that we can do for $270
there is zero reason for spending the money on timeserting the block for 11mm studs. it is clear that there is no "pullout" of any stud before the yield was met or at 233ftlbs!
we will start a new "stud torture test" thread
Give us a call at 714 994 5222
Outfront
outfrontmotorsports is offline   Reply With Quote
Old 01-30-2014, 04:48 PM   #2
Paidfor
Member#: 267815
Be in awe
dont hate .)
Freakin awsome!!!!!!!!!!!!!!!
Paidfor is offline   Reply With Quote
Old 01-30-2014, 04:56 PM   #3
outfrontmotorsports
Member#: 220204
More info: we went to take the fastners out of the block. the 1/2 unit unscrewed by the allen at the tip of the stud.
but guess what?...........................both of the 11mm units could not come out of the block using the allen (or should I say my allen started to strip out)
beings that these studs used in this test are junk, we just put a stud removing tool on them to get them out. they did not come out easy and felt like the threads in the block were not OK any more.
So Chris (KillerBee) there is your answer: threads pulling out of the block with stock 11 mm threads appears to start happening at 140-170 ftlbs. pull out of the 1/2"ers are unknown at this point. it also proved that there is no weakness in the block (at least at 233ftlbs) I might add we did find a weakness with our kit. The 1/2" 12point nut did not move on our stud. this test damaged the nut!
Outfront
Old 01-30-2014, 05:11 PM   #4
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
In for the video!
jnorth85 is offline   Reply With Quote
Old 01-30-2014, 05:13 PM   #5
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Love it!
Old 01-30-2014, 05:35 PM   #6
25rsti
Member#: 166324
Love all the work and effort you guys put into helping us out. Knowledge is power!
Old 01-30-2014, 06:44 PM   #7
outfrontmotorsports
Member#: 220204
Old 01-30-2014, 07:14 PM   #8
m.bryant
Member#: 310077
2007 Legacy GT SpecB
Haha, another great video and love the stand setup!
I know I torqued my 1/2" studs to 110 on the outside and 120 in the middle using the stock torquing sequence at John suggested.
I fear no evil
m.bryant is offline   Reply With Quote
Old 01-30-2014, 08:05 PM   #9
25rsti
Member#: 166324
Now that you've done that test do you think you'll cut up that block to see the threads? IF you can get those studs out that is.
Old 01-30-2014, 08:15 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I like that! I approve!
FuJi K is offline   Reply With Quote
Old 01-30-2014, 08:27 PM   #11
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You guys have an email. ignore the machining question as you answered it above.
Old 01-30-2014, 08:28 PM   #12
outfrontmotorsports
Member#: 220204
email replied.
Old 02-06-2014, 07:41 PM   #13
outfrontmotorsports
Member#: 220204
We will be running a one day sale on these tomorrow. It will be a one time deal FYI.
Old 02-06-2014, 08:21 PM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Very nice. I approve. You guys notice the inner threads vs outer threads more easily damaged? With regular sized studs specifically. From the cutaway the front looks thinner at the bottom.
KillerBMotorsport is online now   Reply With Quote
Old 02-07-2014, 12:17 PM   #15
outfrontmotorsports
Member#: 220204
Old 02-07-2014, 01:20 PM   #16
tomtom84
Member#: 167794
06 wrx limited wag
6spd 35r daily + 91miata
great post. thanks for the info.
tomtom84 is offline   Reply With Quote
Old 02-07-2014, 02:30 PM   #17
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
thank you for doing this.
cnstman is offline   Reply With Quote
Old 02-07-2014, 02:55 PM   #18
MartinSTi05
Member#: 145145
2006 wrx STi
I just ordered a set of these headstuds among other things... Jeremy was a great help in getting the order squared away. Thanks!
MartinSTi05 is offline   Reply With Quote
Old 02-11-2014, 01:23 AM   #19
outfrontmotorsports
Member#: 220204
Thank you, just tapped another three blocks today!
we have some big names running these studs, we are excited to hear the
results. we even have a company talking to us as our studs cost less retail
than it cost him to make his 14mm studs and our studs install with less headaches.
Outfront
Old 02-11-2014, 01:36 AM   #20
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
This might be a stupid question but can you relate this too boost pressure/horse power?
I assume they are designed to hold 35+ psi?
jdpsearcher is offline   Reply With Quote
Old 02-11-2014, 01:55 AM   #21
outfrontmotorsports
Member#: 220204
Crystal Impreza and others have run our previous 1/2 stud to the 40psi range, our new 1/2 stud is even stronger, easier to install and machine for. I would say the next weak link will be more in the head gaskets than the studs at this point, we are exploring the idea of using and testing torque values and effects with some pressure sensitive film
stay tuned
Outfront
Old 02-11-2014, 10:15 AM   #22
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Like using this stuff? A head of you on that one
Crystal_Imprezav is offline   Reply With Quote
Old 02-11-2014, 10:40 AM   #23
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Its always great when I hear there's new things getting developed for our engines.
Great work Outfront
Screw the studs, $50 engine plate? Sweet deal
wrxsubiemod is offline   Reply With Quote
Old 02-11-2014, 10:48 AM   #24
outfrontmotorsports
Member#: 220204
Great work Outfront
was that a pun^^^ screw the stud
Old 02-11-2014, 10:49 AM   #25
jnorth85
Member#: 76785
SRP
That Engine plate is pretty genius
Great work on the studs guys! Cant wait to get my motor running, we just need some of this snow to melt!
