Old 10-15-2002, 12:54 PM   #1
rallytuned
Wiped Out By KGB
Member#: 19566
Default Does UTEC sense knock?
Does UTEC sense knock and retard engine timing as a result of it?
P.S. How about the Link?
rallytuned is offline   Reply With Quote
Old 10-15-2002, 01:14 PM   #2
gossamer_monster
Member#: 3574
Blase' Yellow----R.I.P.
Wow the "search" is your friend.
There must be 50+ UTEC threads and I bet almost all of them mention something about knock detection.
Bill
gossamer_monster is offline   Reply With Quote
Old 10-15-2002, 03:02 PM   #3
hobbzz
Member#: 24172
04 STI
JBP
Bill..Actually there 84! I found that out by doing a search on "utec".
Rallytuned... I saw something about this a couple days ago... unfortunately I can't remember which thread. Isn't it funny how people will take the time to tell you to do a search, but not take the time to help you? j/k
Brent
hobbzz is offline   Reply With Quote
Old 10-15-2002, 06:20 PM   #4
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
Actually I was wondering about this today... sort of. I know the UTEC will pull timing when it senses knock but does it REMEMBER that pulled timing value and store it when you shut the car off? Or does it simply only remember it while you car is powered on and then resets itself back to it's programmed numbers once the car is powered down?
I think in the past 2-3 weeks of having the UTEC it has only detected knock once with the CEL flashing effect. Funny I was nice and rich and my knocklink didn't pick it up [shrug].
davidm_sh is offline   Reply With Quote
Old 10-15-2002, 06:57 PM   #5
TurboXS
Member#: 4143
2002 WRX Wagon
WR Blue
Yes it detects knock. And it is programmed to pull timing when it detects knock. You can program knock threshold by rpm range, # of knock counts to consider a knock event, #degrees of timing correction per knock event, # of crank cycle to retard timg, and maximum # of retard. There are default values already programmed in for each of these.
There is no "memory" for knock correction. If you are getting knock at a particular load/rpm point, you must change something (less ignition advance, lower boost, more fuel, higher octane fuel) to eliminate it. The UTEC will run the programmed timing curve and will react to knock events. It is up to you to decide what to change and to change it.
Mark
TurboXS
TurboXS is offline   Reply With Quote
Old 10-15-2002, 07:04 PM   #6
davidm_sh
Member#: 5994
Java Black
Cool... just checking that is the way I prefer it actually.
Thanks Phil.
HELP! ECU sensing knock with upgraded valvetrain big67 Commercial ECU Reflashes 3 03-25-2007 01:45 AM
Stage 1 STi UTEC and knock sensativity Mancini Engine Management & Tuning 14 12-20-2004 03:44 PM
UTEC Q: does UTEC intercept stock O2 sensor readings? happasaiyan Engine Management & Tuning 6 12-10-2004 12:29 PM
my first utec log. knock knock, who's there Rickyh Engine Management & Tuning 4 10-13-2004 06:14 PM
UTEC and knock? gossamer_monster Engine Management & Tuning 7 12-20-2002 12:15 PM
