Old 02-03-2014, 01:44 PM   #26
tomacGTi
Member#: 297396
I've used a Mitivac to bleed the clutch before, HOWEVER, I was much more successful using a big syringe-type bleeder you can find at a FLAP. You can usually find them in the pre-mix section obviously to pre-mix 2-smoke gas.
Make sure the bleeder is teflon taped and the syringe is pretty full, remove the cap off of the res and make sure it's almost empty and fire the fluid through the bleeder into the res. Close the bleeder, refill (or suck it from the res) and try again. Go into the car and see how the clutch feels.
I've had much more success doing it that way solo than with a mitivac.
-Randy
BTW, the teflon tape trick works on the brakes as well...
tomacGTi is offline   Reply With Quote
Old 02-04-2014, 05:05 PM   #27
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Default Crank Pulley Fun
Not my pic, will try this.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 02-04-2014, 08:49 PM   #28
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
you dont bleed clutch that way...
Old 02-04-2014, 10:01 PM   #29
some dude
Member#: 100300
06 WRX
CGM
Lmao!!
some dude is offline   Reply With Quote
Old 02-05-2014, 01:54 AM   #30
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
No girls out there in BFE ? ;-)
BeastianSTI is offline   Reply With Quote
Old 02-05-2014, 02:46 AM   #31
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Lets get back on topic so other people can benefit.
Old 02-06-2014, 11:03 PM   #32
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
LOL
I gravity bled my clutch. Took a while but it worked....
Tightening the crank pulley usually I just put it in 4th gear and tighten it.
alcoolaid is offline   Reply With Quote
Old 02-07-2014, 06:03 PM   #33
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
I just hit my crank pulley with a impact gun with a little blue locktight to keep it on but able to come off with the inpact again if need be and it is just fine.
nate_fisher is offline   Reply With Quote
Old 02-07-2014, 07:16 PM   #34
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^Impact gun does not fit with engine in vehicle, even with radiator out there is no room. Anyhow, this is what I did, floor jack handle, two 3/8" ratchet extension, 15mm wrench stuffed into jack handle. Worked great, jacked handle long enough to make contact with garage floor.
Old 02-07-2014, 08:03 PM   #35
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Says who?
Ive done several TB jobs and have taken the pulley off with a 3/8 drive snap on impact which is much smaller than most 1/2 inch drives and it still has enough ass to do mostly anything youd ask of it.
Not all tools are created equal (no pun intended, lol)
2Fast4U1DAY is offline   Reply With Quote
Old 02-08-2014, 10:17 PM   #36
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
My comment applied to 99.5% of us with 1/2" impact guns.
Which model do you have? I would like to check the overall length.
Old 02-08-2014, 10:28 PM   #37
Paul
Member#: 56203
00 RSTI Coupe
Im pretty sure I could get a impact on mine if I pulled rad and grill...maybe I'd have to jack motor up Alil and use a swivel bit....Mine is a GC8 Tho.
I usually just put it in gear and use a breaker bar and if that doesn't work pull starter and jam flywheel with something. Never really had a issue
Old 02-09-2014, 12:53 AM   #38
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
I feel like I could get my 1/2in in there too, but its way overkill at 1100lb-ft in reverse...
I usually use my MG325 though which is rated at 325lb-ft
Old 02-09-2014, 09:32 AM   #39
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
A 1/2" impact does not fit PERIOD, unless you have the snap-on 3/8" $350 this guy is talking about.
Old 02-09-2014, 11:25 AM   #40
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
A 1/2" impact does not fit PERIOD, unless you have the snap-on 3/8" $350 this guy is talking about. I have tried Jesus.
I feel like my IR 1/2" would fit too because its not much longer and I have low profile impact sockets which are shorter length (it would probably only grab the top 1/2-2/3 of the bolt head), and also swivel impacts.
I wasnt implying all 1/2" drives would fit and ive never even thought to use it as the mg325 was already in my arsenal. Im a flat rate tech so I use 3/8 air impact 3/8, 1/2, and 1/4 electric impacts alot for disassembly. Snap on had me by the balls for a minute there lol but I can tell you this it was worth every penny. I increased my work output by roughly 27%....
Old 02-09-2014, 03:39 PM   #41
cowboy_Rob
Member#: 194062
2003 Impreza WRX
My Mac 1/2 gun fits fine with a short socket and a universal joint. I did buy this cool new thing off the Cornwell. Truck the other day I want to try for subie crank bolts. It's called a powerbar basically a 1/2 drive on a short lever with a pivot to a big rod. Put the socket on, lever at 90 degrees, hit the big rod with a hammer and its supposed to make up to 600ft lbs depending how hard you hit it. I've got small arms and am flat rate so I wanna try an bang out timing belts without pulling the radiator lol
cowboy_Rob is offline   Reply With Quote
Old 02-09-2014, 03:47 PM   #42
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Well back to the clutch pedal issue, I have tried bleeding the system with a humanoid, and also with a vacuum bleeder with no luck, the pedal is stuck to the floor, any ideas before I crack the trans open?
Old 02-09-2014, 03:52 PM   #43
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Without reading back through all this. Pull the pedal up by hand. Pump it a half dozen times. You may have to pull it back up. If the pedal pumps up and starts to feel more normal then let it sit ten minutes. If its soft again you have air in it. If its still normal feeling you might be good. You usually have to pull it back up after bleeding
Old 02-09-2014, 04:21 PM   #44
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
This is exact what I did but still I am not feeling any resistance.
Press the pedal to the floor, second person opens the bleeder momentarily to "burp" off the air, while the 1st person is still holding the pedal to the floor.
Close the bleeder and the 1st person pulls the pedal up from the floor. Press down again, 2nd person cracks the bleeder again momentarily. 1st person pulls the pedal up and repeat this until you start getting fluid at the bleeder but there is no fluid coming out of the bleeder and no increase in resistance, the clutch is stuck to the floor.
Old 02-09-2014, 04:38 PM   #45
ripman
Member#: 305707
1999 WRX
WRC Blue
If there is no fluid coming out of the bleeder it is most likely that you do not have the system fully assembled. Make sure that everything is where it should be for the clutch to operate under normal conditions.
ripman is offline   Reply With Quote
Old 02-09-2014, 05:29 PM   #46
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
I only took apart the slave cylinder and put it back together, I have not fiddled with the rest of the system.
Old 02-10-2014, 12:09 PM   #47
Paul
Member#: 56203
00 RSTI Coupe
I had a similar issue, I'd pump the slave but no fluid came out. Took the slave off the trans, bench bleeded the slave, then installed. Still had to bleed it some more but IIRC that's how I fixed my similar issue.
Old 02-10-2014, 01:04 PM   #48
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Bench bleeding the MC this morning, next I will do the slave, by reversing the tool pump ports I can either do vacuum or inject fluid (reverse bleeding) into the system, pics shows reverse bleeding method. Only reason why I have the hose drawing fluid from the reservoir is to avoid having to empty it and refill it constantly but it is better to draw fluid from a new container, less aeration.
Old 02-10-2014, 03:48 PM   #49
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Agggh, about to call AAA and have the car towed to dealer, once installed in the car I am back to square one, it is like the MC is blocking the fluid, I cannot pull fluid out of bleeder or inject fluid into bleeder (reverse bleed)........
Old 02-10-2014, 10:37 PM   #50
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
I assembled the system off the car, reverse bled (injected fluid thru bleeder) and confirmed there is no blockage. However I just pull air with conventional bleeding, no fluid comes out of bleeder just air. I have zip ties on all tubing and teflon at the bleeder, so I am pretty sure the setup is air tight.
Showing below the reverse bleeding injecting fluid thru bleeder, I did not take pics performing conventional bleeding (pulling fluid thru bleeder). At this point I am ****ing clueless and ****ing frustrated....
