Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 02-07-2014, 08:32 PM   #1
subyro0
Member#: 125349
2014 WRX STi
World Rally Blue
Default 2014 STi baseline dyno results
Event: 3 Dyno pulls
Ambient Temp: 40 F
Elevation: About Sea Level
Weather: Cold, Just started raining/humid, overcast.
Car: 2014 STi
Dyno Info: Dyno Dynamics
Peak HP at RPM: 217.6whp @ 6500
Peak Torque at RPM: 225.7ftlb @ 3650
Fuel: 93 octane unleaded
Modifications: OEM
Here are my 3 dyno runs from Engine Logics in Houston. Unfortunately I'm on the low end of the baseline dyno But oh well, combination of luck of the draw and humid weather. Here are the results. First is the TQ + HP, 2nd is air/fuel + HP, and the 3rd is tq / turbo PSI. Let me know what you think. I have pretty bad luck getting factory freaks, i always get the factory dud. I will have another dyno up in a week or 2 once my Cobb intake/Accessport comes in. It will be the canned Cobb tune... once I hit stage 2 (about 1-2 months) I will be getting a dynotune.
subyro0 is offline   Reply With Quote
Old 02-07-2014, 11:18 PM   #2
Balcazar_s86
Member#: 321461
2013 WRX/STI
Ice Silver Metallic
Was this in sport or sport sharp?
Balcazar_s86 is offline   Reply With Quote
Old 02-07-2014, 11:29 PM   #3
subyro0
Member#: 125349
2014 WRX STi
World Rally Blue
That is a good question. I honestly have no idea. Would it even make a difference on top end horsepower? It seems like it only changes throttle response.
Old 02-08-2014, 01:43 AM   #4
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
217hp, really? wow! that dyno reads really low. If I were you, screw that place. Since you're in Tex, Id go straight to Cobb for tuning.
Ysidro is offline   Reply With Quote
Old 02-08-2014, 03:32 AM   #5
Balcazar_s86
Member#: 321461
2013 WRX/STI
Ice Silver Metallic
That is also a good question, lol! I know it makes a difference on my TP stage 2 tune. Not sure about stock though.
Old 02-09-2014, 09:46 AM   #6
ALOKIN
Member#: 348177
2013 WRX STI Limited
E85 Tune w/ Dom1.5XTR
Ive been there. Their dyno does read low and they aren't cheap for what they do.
I ended up making the drive to plano for my subsequent tunes, never got a good vibe from those dudes for whatever reason.
ALOKIN is offline   Reply With Quote
Old 02-09-2014, 11:45 AM   #7
bmwrx06
Member#: 255620
08 Sti hatch
actually the driving modes dont just change the throttle response, it advances and retards the timing as well.
bmwrx06 is offline   Reply With Quote
Old 02-09-2014, 01:36 PM   #8
Shortpersonbk
Member#: 319017
91 Miata
slow sti 11.4 124
I was told by Eric (torqued performance) the only thing you can touch between s and s# is the boost and throttle position
Shortpersonbk is online now   Reply With Quote
Old 02-09-2014, 01:51 PM   #9
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
The difference in mode changes the requested torque by pedal angle. Boost and throttle position go off of requested trq. If the car hits more boost it will have a higher load which means it will change timing cells and thus lower timing for more boost. The different modes don't directly control timing, but they indirectly do it by the amount of boost/load the car runs.
bswilmington is offline   Reply With Quote
Old 02-09-2014, 08:12 PM   #10
subyro0
Member#: 125349
2014 WRX STi
World Rally Blue
Anyone have a baseline dyno that they know was using sport # they can post on this thread. Not to compare power, just want to see the graphs
Old 02-09-2014, 08:30 PM   #11
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
That dyno reads 16% lower than a dynojet. Hence why a mustang or dyno dynamics is refered to as heart breakers. So at 217hp that equates to around 250hp on a dynojet which looks like the numbers are right on par with previous year sti's.
Most dyno dynamics are ran on a correction factor of 1 which would put out around your same numbers for a stock sti. Ive seen stage 2 wrx's only do 190hp on a dyno dynamics which is normal for that dyno on a 1 correction factor.
fastblueufo is offline   Reply With Quote
Old 02-09-2014, 08:37 PM   #12
DansSpace
Member#: 157029
'13 Mazdaspeed3
Originally Posted by Ysidro View Post
217hp, really? wow! that dyno reads really low. If I were you, screw that place. .
Yeah forget those guys! Go somewhere that says your stock sti has 250whp and then you can brag about inflated numbers!
DansSpace is offline   Reply With Quote
Old 02-09-2014, 10:22 PM   #13
subyro0
Member#: 125349
2014 WRX STi
World Rally Blue
well, im going to go back on the same dyno next week when i throw on my cobb intake and tune (stage 1 i guess) so at least ill see the actual consistent results.
Old 02-10-2014, 02:02 PM   #14
DansSpace
Member#: 157029
'13 Mazdaspeed3
And this is exactly what dynos should be used for.
Old 02-13-2014, 10:42 AM   #15
super_subie
Member#: 344431
2013 WRX
Don't let a dyno put you down, some people are lucky and get a gifted motor while others don't. Look at it as an excuse to mod some more!!!
On a side note a few weeks back i was at a dyno and some lucky guy dyno 244whp on a stock 2011 wrx (via mustang dyno) I was quite jealous! But my 238whp was second best for stock so can't complain
super_subie is offline   Reply With Quote
Old 02-13-2014, 11:10 AM   #16
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Looks right for a lower reading dyno. They put down 200-205whp stock on our dyno on 91 octane. I imagine it would be right around this power on 93.
The guys saying to go elsewhere because the dyno reads low are clowns. There is nothing wrong with the dyno... It's just not inflated like most out there. If you want dynojet numbers, have the dyno operator apply a 1.15 correction factor.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 02-13-2014, 12:58 PM   #17
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
Depending on when the mustang dyno was recalibrated you may have some inflated numbers. The more recent calibration puts a mustang dyno almost on par with a dynojet (within 3-5%, instead of the 15% difference of the past). This is why you can't compare numbers from any two dynos, regardless of brand. I prefer a lower reading so I can embarrass people with their "400hp" cars.
JungleFevre is offline   Reply With Quote
Old 02-13-2014, 03:32 PM   #18
neorex
Member#: 106478
STi 1.5 xt-r
that factory AFR between 3-4k makes me cringe every time i see it...
neorex is offline   Reply With Quote
Old 02-13-2014, 04:38 PM   #19
Kuros
Member#: 328669
2011 STi
Red
Lol. Thats not low at all. Thats accurate.
Go get some inflated dynojet numbers and convince yourself your car makes more power than it really does.
Hell, on dynojet i make well over 400 wheel on 91 with an FP red...
I've seen stock STIs make 195-220 whp on 91.
Kuros is offline   Reply With Quote
Old 02-13-2014, 05:26 PM   #20
Ysidro
Member#: 197418
07 WRX Ltd
ha. ha. You guys got it all wrong. I said screw that place not because so he can get an inflated number but since he is in Texas, why not go straight to the mothership, Cobb Plano? Ive been here long enough to know that each dyno will always be different. Thus just pick one place to use as benchmark, and why not Cobb?
http://www.complex.com/rides/2013/04...ps-in-america/
Old 02-13-2014, 09:04 PM   #21
StackSmasher
Member#: 316928
2012 STI limited
The OP probably didnt want to drive 4 hours to get a dyno run.
StackSmasher is offline   Reply With Quote
Old 02-14-2014, 01:56 AM   #22
subyro0
Member#: 125349
2014 WRX STi
World Rally Blue
Exactly... I'll probably go there shortly after getting the downpipe, but not just for a dyno.
Old 02-15-2014, 11:40 AM   #23
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
Yeah, and get a new baseline if you want to continue to use that dyno.
Without a baseline you have no idea what kind of gains your making with your mods.
You need to stick with the same dyno (baseline and after mods) and don't let the baseline number bother you.
As mentioned, I know guys that search out the dynos that are known to be very generous with their numbers. Then they brag about how much HP/Tq their car is making.
Then they go to the track and run slower times than guys that dynoed much lower than them.
SGOSWRX is offline   Reply With Quote
