Old 10-15-2002, 08:48 PM   #1
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Default How do you check the fluid in the rear differential?
My car has this aweful noise coming from the rear over 30 MPH, I'm guessing it's either the rear axle bearings or the differential.. DOH!
Either way, how can I check the fluid in the rear differential?
Bry.
BrysImpreza is offline   Reply With Quote
Old 10-15-2002, 09:06 PM   #2
SJwrx
Member#: 14970
1997 GF8
multi
Park it on a level surface, AKA 1/2 way out of the drivway. Use a 1/2 inch wrench to pull the top bolt on the rear diff.. On a perfecty level surface, you should be full of diff. fluid until it starts dripping out the top of the top hole. Thats how much. So, thats it.
Might as well change out the fluid while you are at it.
Rich
SJwrx is offline   Reply With Quote
Old 10-16-2002, 04:53 PM   #3
tdxflex
Member#: 13634
i just changed mine out last weekend, 11800 miles and it was disgusting. i couldn't even imagine what it would look like at 15k. i probably would have changed mine out closer to 10k. it's really cheap, you should just change it out.
tdxflex is offline   Reply With Quote
Old 10-16-2002, 05:03 PM   #4
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
What do you change it with, standard Gear Oil? Brand, type, etc?
Bry.
Old 10-16-2002, 05:08 PM   #5
tdxflex
Member#: 13634
i used Redline 75w90, bought it for $8 from summit racing along with other stuff to save on shipping. you can also use a 1/2 ratchet for the bolts. mine were on really tight, i actually used my 1/2 breaker bar for extra leverage over my ratchet.
Old 10-16-2002, 07:13 PM   #6
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Mine was "disgusting" at 3,000mi. Made me cringe to look at it. I changed it at 15k again and it was a clean as new. Considering I used synthetic I may not change it for a while.
mr2guru is offline   Reply With Quote
Old 10-16-2002, 07:16 PM   #7
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
damn, my bolts have square holes, so I can't use a wrench or hex wrench
Maybe I'll just ahve subaru check it when I bring it in to have my wheel bearings changed
Bry.
Old 10-16-2002, 07:22 PM   #8
tdxflex
Member#: 13634
yeah, a 1/2" drive wrench fits in there fine. it's actually a little on the small side, but it works fine.
Bry.
Old 10-31-2002, 04:57 AM   #9
SJwrx
Member#: 14970
1997 GF8
multi
smells like crap too!
Old 10-31-2002, 10:31 AM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I don't believe that the dark fluid in the differential is actually dirty, when I drained mine at 3500 it looked the same as everyone is describing here, but I think it's from additives used in the fluid at the factory and not contamination. I'm willing to bet that if the diff fluid was drained from a car with zero miles it would look the same.
Old 10-31-2002, 11:31 AM   #11
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
I have to agree with Mulder. I believe factory recommendation for change rear diff fluid is either 30k or 60k miles.
Foxbat is offline   Reply With Quote
Old 11-14-2002, 02:44 PM   #12
97itr153
Member#: 17887
05 LGTW Ltd AT
05 Evo RS
unless you drive hard like most WRX owners do, in which case the factory recommendation is to change every 15000 miles (severe driving maintainence schedule).
97itr153 is offline   Reply With Quote
Old 11-14-2002, 03:41 PM   #13
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
BrysImpreza,
have you ruled out the possibility of a bad wheel bearing?
I changed my tranny and differential fluid at ~12K. There were more of the fine metal pieces on the magnetic drain plug of the differential than on the tranny's drain bolt, which is not what I would have intuitively guessed. I would have guessed the opposite, given the greater volume of fluid and more moving parts in the transmission as compared to the rear differential.
Stanley is offline   Reply With Quote
How do you check boost fluid level? Cobra's WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-05-2009 03:37 PM
When posting log files, how do you put a table in the post that you can scroll throug sburck Newbies & FAQs 4 04-12-2009 10:31 PM
How do you cope with driving in the city? gongzero Off-Topic 29 10-07-2004 04:06 PM
How do you mount a camcorder in the car? IBO Vancouver Impreza Club Forum -- VIC 18 09-28-2001 02:30 AM
How do you mount a camcorder in the car? IBO Motorsports 7 09-28-2001 12:54 AM
