Old 02-09-2014, 05:53 PM   #1
nonameasian
Member#: 380119
2008 Sti
Default First Tune Ever!
Went to dyno comp in scottsdale and have them install a Tsudo Catless DP to match my Tsudo S2 Catback and AEM CAI. End results are...
300 Tq and 275 Hp at the wheel. So 405 Tq and 371 Hp at the crank.
Video
nonameasian is offline   Reply With Quote
Old 02-09-2014, 08:51 PM   #2
DansSpace
Member#: 157029
'13 Mazdaspeed3
275/300 at the wheels is a little low for a stage 2 STi, but solid numbers nonetheless.
Also, be careful throwing around those crank horsepower numbers you calculated, you'll have some big shoes to fill once you say you drive a 370hp STi, because most guys that know about modded cars are going to assume whp numbers.
Being the owner of a 280whp speed3, I think I'd about die laughing if I were at the 1/4mile and was trapping the same speeds as the guy saying he had a 370hp sti. I always quote whp numbers if anyone asks about my car.
DansSpace is offline   Reply With Quote
Old 02-09-2014, 09:41 PM   #3
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
how the hell did you calculate those crank #s? lol
BigRob74 is offline   Reply With Quote
Old 02-09-2014, 10:35 PM   #4
subyro0
Member#: 125349
2014 WRX STi
World Rally Blue
Did you do a baseline on the same dyno before? Im curious to see the increases on the same model dyno.
subyro0 is offline   Reply With Quote
Old 02-10-2014, 12:27 AM   #5
nonameasian
Member#: 380119
2008 Sti
I posted "crank" numbers to see what you guys thought. calculated those numbers from what dyno comp said to use. They said take wheel numbers and multiply by 1.35. I'm not sure on the method, they claim the awd dyno setup has a 35% loss factor. But I'm just doing what they said. What numbers should I be seeing? If there's a better way calculate crank numbers I'm open. Unfortunately I did not do a baseline.
Old 02-10-2014, 12:03 PM   #6
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Actually about 20-25% loss...
rexworx is offline   Reply With Quote
Old 02-11-2014, 01:57 AM   #7
DansSpace
Member#: 157029
'13 Mazdaspeed3
If you use 25% drivetrain loss and work backwards, the numbers you posted are pretty accurate if you want to use crank numbers.
Multiplying by 1.35 doesn't mean they have a 35% loss factor. Most AWD cars will be around 20-25 percent as stated earlier. So just do WHP/(1-AWDLOSS).
So in your case, take 275 divided by 1-.25. So 275/.75. Gives you about 366.6 crank hp.
A 35% loss (which is way too high) would be 275/.65, which comes out to 423. Sorry, you don't have a 423 hp car though.
If you need proof of that, find a 425hp camaro SS that's stock and weighs at least 500 lbs more than your car. It'll put bus-lengths on you on the freeway.
Old 02-11-2014, 04:43 AM   #8
nonameasian
Member#: 380119
2008 Sti
no i completely agree. but the 275*1.35 = 371.25 isnt far off from the 275/.75 = 366.66 . anyone know why dynocomp would tell me to use X x 1.35 equation?
Old 02-11-2014, 01:48 PM   #9
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Cause they know two things.
1. There's no exact number since you're guessing.
2. The outcome will NEVER matter and crank numbers are utterly pointless and used by the ignorant or marketers anyway.
ProfessWRX is offline   Reply With Quote
Old 02-11-2014, 01:51 PM   #10
nonameasian
Member#: 380119
2008 Sti
fair enough. thanks for all the input guys
Old 02-11-2014, 06:46 PM   #11
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
right??? thats what i was thinking please do not say that around anyone. HP numbers are BS
bmxhotsauce is online now   Reply With Quote
