Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 02-12-2014, 06:35 PM   #26
gfx2043
Member#: 205174
As stated above just over 350 AWHP on 93 at 21-22 psi and 437 AWHP on 24 psi and E85. Motor has over 22K on the clock now and consumes very little oil ~.25 qt per 3K miles.
gfx2043 is offline   Reply With Quote
Old 02-12-2014, 09:52 PM   #27
rymaggi
Member#: 253442
I too have been looking into the 4032 piston options, ended up going with 9:1 4032 wossner pistons. They literally just showed up at my door step.
rymaggi is offline   Reply With Quote
Old 02-13-2014, 02:35 AM   #28
Sivandor
Member#: 272632
2005 STI
Oh sorry didn't realize you were the same person, awesome, thanks for the feedback
Sivandor is offline   Reply With Quote
Old 02-13-2014, 10:43 AM   #29
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Wossner? I'm not familiar with them. Got a link?
Old 02-13-2014, 10:59 AM   #30
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
http://www.wossnerpistons.com/produc...=Sport+Compact
When I was researching piston options for my EJ207 it seemed like some guys over the pond have good experiences with em
Old 02-13-2014, 11:00 AM   #31
rymaggi
Member#: 253442
Here are some pictures of them.
Purchased them through built industries.
Old 02-13-2014, 11:12 AM   #32
Sivandor
Member#: 272632
2005 STI
Ive heard good things about them to, just think i will go with male because they are almost exact stock forged replacements, which is the route id like to go, but the wossner's look really nice, def give us feedback once they are in the car
Old 02-13-2014, 11:15 AM   #33
rymaggi
Member#: 253442
We went with them because the ring lands looks a bit "beefier"
Also, didn't find any bad reviews, as with the Mahle's there are mixed, but usually there is always mixed reviews.
A little comparison.
vs
Old 02-13-2014, 11:17 AM   #34
rymaggi
Member#: 253442
There is some info in my "threads started" under "piston with least piston slap"
Old 02-13-2014, 01:26 PM   #35
Sivandor
Member#: 272632
2005 STI
just read, awesome stuff, hmm, now i would consider the wossner's to, they seem like a really nice piston, plus, who does't like fine german engineering , mahle are certainly a good piston from what I've read, and considering there factory and race use throughout the world in F1 and by audi as there motorsport piston
Old 02-13-2014, 01:34 PM   #36
atomicfire
Member#: 136296
2005 STi
I have a set of Mahle pistons on my desk with shattered and melted ringlands but besides that I don't have a lot of experience using them. My understanding of them is that they are a quiet economical piston good for slightly higher than stock power levels.
atomicfire is offline   Reply With Quote
Old 02-13-2014, 01:45 PM   #37
Sivandor
Member#: 272632
2005 STI
yea, i read a few posts that say this, i believe that is due to a tune which wasn't very good, seems like they don't take lightly to too much power and set, which is fine considering my car is gonna stay on 93 with a VF turbo
Old 02-13-2014, 11:12 PM   #38
Sivandor
Member#: 272632
2005 STI
how did yours fail?, curious as to why, what power levels were you at etc?
Old 02-14-2014, 09:46 AM   #39
atomicfire
Member#: 136296
2005 STi
I really don't know, I bought it from someone else. The engine had 17k on it when it blew up. I bought the entire shortblock for $150. Rod and mains bearings looked great. The STi rods in it looked straight and clean. Two ringlands shattered on a one piston only. The other 3 looked reasonably good. The cylinder the piston came out of is ruined and the block is only good for sleeving, which is why I bought the block.
Old 02-14-2014, 12:57 PM   #40
gfx2043
Member#: 205174
Shattered and melted is a sign of detonation. Pitting/melting is a sure sign of it. All pistons will fail under detonation regardless of the material they are made from. To me this is more of of how they fail under detonation.
Old 02-14-2014, 01:09 PM   #41
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Im currently running the Mahle 4032 with 6500 miles around 380whp/380wtq on Dom 1.5. About to finish the tune if this new South Bend Clutch can take the abuse. They are quite pistons even though I do have little higher than normal PTW.
On those wossner pistons above. Do they have gas ports on the oil ring? Also is the wrist pin force feed oil? I can't tell by the pics
bswilmington is offline   Reply With Quote
Old 02-14-2014, 01:42 PM   #42
atomicfire
Member#: 136296
2005 STi
Very likely so, but with such severe detonation to crack a ring land on a forged piston, the bearings looked great. Again, not my engine when it was tuned so I have no idea how bad it was.
Old 02-14-2014, 09:52 PM   #43
Sivandor
Member#: 272632
2005 STI
Hmm, you may never know, hoping I get more posts in here on them
Old 02-14-2014, 10:22 PM   #44
atomicfire
Member#: 136296
2005 STi
Let us know how it goes. I'm genuinely interested in how they perform. They seem like a great piston for stock-like quiet performance at slightly higher-than-stock power levels.
Old 02-15-2014, 12:40 AM   #45
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
My issue with 4032 is what happens when they fail. They crack, shatter or pretty much disintegrate on heavily boosted applications increasing the probability of a catastrophic failure. Damage in 4032 also continues to spread out from the area it occurred. If the day will NEVER come where you say, "Lets see what she can do" i say go for it. They are perfect for normal applications.
2618 on the other hand will bend without shattering since its the softer metal. These are way more forgiving of a bad tune They don't have to be diesel loud if the machining is right. My car probably makes a little bit of noise below freezing but it isn't even audible from the outside of the car. Unless you have a racecar there really is no reason to run such loose tolerances which makes 2618 a serious choice for normal folks. 2618 has gotten a bad rep for daily's but the problem is really the machine shops doing the work.
Purpose_Built is offline   Reply With Quote
Old 02-15-2014, 01:05 AM   #46
Sivandor
Member#: 272632
2005 STI
Originally Posted by Purpose_Built View Post
My issue with 4032 is what happens when they fail. They crack, shatter or pretty much disintegrate on heavily boosted applications increasing the probability of a catastrophic failure. Damage in 4032 also continues to spread out from the area it occurred. If the day will NEVER come where you say, "Lets see what she can do" i say go for it. They are perfect for normal applications. 2618 on the other hand will bend without shattering since its the softer metal. These are way more forgiving of a bad tune They don't have to be diesel loud if the machining is right. My car probably makes a little bit of noise below freezing but it isn't even audible from the outside of the car. Unless you have a racecar there really is no reason to run such loose tolerances which makes 2618 a serious choice for normal folks. 2618 has gotten a bad rep for daily's but the problem is really the machine shops doing the work.
Definitely a good opinion, I'm sure they are ideal, especially if you are a power fiend then it's the smarter choice, me personally I've had 2 subarus over the past 3 years and both have made me quite happy at stage 2, I really don't have any desire to go past that, it makes the sti the perfect daily, reliable and fast, hence why I think 4032 really is perfect for my build
Old 02-18-2014, 12:21 PM   #47
Sivandor
Member#: 272632
2005 STI
bumpppp
Old 02-18-2014, 03:33 PM   #48
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
Are you going to run forged rods?
Old 02-18-2014, 04:01 PM   #49
Sivandor
Member#: 272632
2005 STI
No, brand new Oem shortblock
Old 02-19-2014, 05:31 PM   #50
EMS
Member#: 14116
I have disassembled an engine with VERY strong Roger Clark Motorsport Omega forged pistons COMPLETELY destroyed by detonation (mixture way too lean by failing fuel pump and motorsport ECU without knock control) all bearings looked like new.
After this experience, to me all stories about bearing damage caused by detonation are complete BS!
EMS is offline   Reply With Quote
