Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 02-11-2014, 09:29 PM   #1
Alkaline198
Member#: 318472
Default Ej 207 build
2004 wrx ej205 to ej207
Hi all, im new and just wanted some opinions/ideas for my new engine.
My 04 wrx engine just died (combo of negative temp days, wrong oil maybe, improper upgrading by previous owner..) anyway, that shenanigans aside- i decided to go the ej207 route instead of finding another ej205 oem.
The day the engine arrived, the shop informed me that this engine came with a twin scroll turbo. They asked if i want to go ahead with the instal and recommended a tomioka TS usdm fit downpipe and a catless bell mouth downpipe. They also want to do an open source dyno tune instead of the Cobb accessport route.
Also a 76mm invidia q300 catback system
-- aem cold air intake
-- gates timing belt
-- they said a new uppipe is not needed
Any thoughts here, are these suggestions inline with what you guys have done?
Thanks in advance!
Im in Pa, usa by the way
Alkaline198 is offline   Reply With Quote
Old 02-11-2014, 09:48 PM   #2
207STi
Member#: 197062
1998 Swapped Impreza
black
well Im assuming its a v8 ej207 if it has a twinscroll setup. Everything the shop suggested makes sense and is pretty much standard operating procedure for these swaps. A solid stage 2 setup on a 207 should make some great power.
207STi is online now   Reply With Quote
Old 02-11-2014, 10:41 PM   #3
Alkaline198
Member#: 318472
Yes it was v8, do you know if they will run into issues with the avcs? Or will it go smooth as long as i have the ej207 ecu
Old 02-11-2014, 11:01 PM   #4
207STi
Member#: 197062
black
With the 207 ecu and the IAperformance avcs wiring harness you should have functioning avcs.
Old 02-11-2014, 11:02 PM   #5
02nismokiller
Member#: 322963
04 wrx
psm
They or you need to run a few wires or buy the pre made harness to make the avcs run
02nismokiller is offline   Reply With Quote
Old 02-11-2014, 11:06 PM   #6
Alkaline198
Member#: 318472
What are the pro/cons of wiring it vs not
Old 02-11-2014, 11:22 PM   #7
RexWagonWA
Member#: 221945
Do you need to pass emissions? Is there a visual inspection?
RexWagonWA is offline   Reply With Quote
Old 02-11-2014, 11:48 PM   #8
Alkaline198
Member#: 318472
I assume it will need to pass standard PA emissions
Old 02-12-2014, 01:51 PM   #9
207STi
Member#: 197062
black
I ended up having issues with my avcs that prevented me from using it when I initially had my car tuned. What I can say is the car felt extremely sluggish out of boost. I found myself downshifting into 5th on the highway to climb a hill. When I had the car re-tuned with avcs I picked up a very noticeable bump in torque in the low and mid end. If you don't wire it up you will be missing out on the real ej207 experience, trust me.
Old 02-12-2014, 06:16 PM   #10
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
1) Cobb has no maps for 16 bit ECU with AVCS. This is why the shop recommended open source. Cobb mapping will mean no AVCS
2) Will they run into issues? Ask them, not us. It's relatively simple to wire AVCS into the 02-05 USDM harness if you have the know-how. A wiring kit like IA makes helps if you don't know what you're doing.
To answer with / without AVCS it's about 500 RPM in spool and a subjective "ton" of off-boost torque. I'd equate the off-boost torque difference as roughly feeling like adding 0.3 to 0.5L displacement. It's big.
Concillian is offline   Reply With Quote
Old 02-12-2014, 08:34 PM   #11
Alkaline198
Member#: 318472
Thanks guys. Ill def have them get the IA harness and hook up avcs-- keep posted for updates and pics
Old 02-18-2014, 09:26 AM   #12
Alkaline198
Member#: 318472
Can i attach images from my computer
Old 02-18-2014, 10:11 AM   #13
181stLeader
Member#: 184183
1995 Impreza RSTi
Ver.8 EJ207 Bright Blue
^To my knowledge the USDM Cobb Acessport isn't compatible with the JDM ECU. Open source is the way to go!
181stLeader is online now   Reply With Quote
Old 02-18-2014, 10:57 PM   #14
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Or ecutek
spoolinsti05 is online now   Reply With Quote
Old 03-07-2014, 10:53 AM   #15
Alkaline198
Member#: 318472
Well i got the car back- its got some issues- does anyone know if the 04wrx TCM needs a jumper or something modified to work with JDM v8 ej207 engine?
Old 03-07-2014, 11:01 AM   #16
canada88
Member#: 216089
I just did this swap into my 04 WRX.
but I used a Ver9 JDM STi motor with a Ver8 ecu non-immobilized.
got the motor install last weekend Firday and Saturday it was done.
On Monday I wired up the avcs and was running great.
Also installed a Exedy Lightweight Flywheel, and Exedy stock clutch kit.
and because I love the Opening Ceremony, I got a Ver8 JDM Cluster and installed that with very easy install.
Very pleased with the way it turned out.
Great increase compared to the crappy ej205 lol.
Wanting to get some 750-850 injectors, turbo inlet and downpipe before I tune it.
but running the stock downpipe with gutted cats right now.
It pulls pretty good.
canada88 is offline   Reply With Quote
Old 03-10-2014, 07:29 PM   #17
Alkaline198
Member#: 318472
My at oil temp light is flashing and the car shifts at high revs and jerk motion. No cel or obd codes showing. Replaced tcm with new one same issue... Any ideas what might be wrong? I know they had to instal the ia harness for avcs- would this be anything? Also they had to custom wire the ej207 v8 ecu to work with the car. Ideas????
Old 03-10-2014, 08:26 PM   #18
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
what did the shop that did the swap suggest so far?
fastnoypi is offline   Reply With Quote
Old 03-11-2014, 02:42 AM   #19
Alkaline198
Member#: 318472
I replaced the tcm but they think the maf sensor wire requires pin work on the ecu and testing to be sure the voltages are correct
Old 03-11-2014, 07:40 AM   #20
some dude
Member#: 100300
06 WRX
CGM
I would be thinking about the shop working out the bugs. You payed them to install it and they didn't do it right.
They want you to pay more money for them to get in there to test voltages on individual wires on the install job they did?
You don't pay for their mistakes / incompetence. If they think it's the wiring they need to fix the job you payed them to do. The job they said they could do and took your money to do. You already payed for it.
That's what I'm thinking right meow.
some dude is offline   Reply With Quote
Old 03-11-2014, 09:09 PM   #21
Alkaline198
Member#: 318472
Ok.. So now i have the two green/white wires pin 28 tied back together and tapped into the maf signal wire the pink-blue. After i drove it seemed to shift normal again but the at oil temp still flashing. The car started sputtering like out of gas and shortly after it would not move forward... Any ideas at this point, almost seems like the transmission fluid burnt up? Would this be the problem and/or also cause the flashing light?
Ideas?
Old 03-12-2014, 07:55 AM   #22
baldhooter
Member#: 124201
04 wrx
I could be entirely wrong but that sounds remarkably similar to when I spun a bearing in my RS several years ago.
baldhooter is online now   Reply With Quote
Old 03-12-2014, 02:59 PM   #23
rdieder
Member#: 257818
2007 STi
CGM
Why are you messing with wires when you paid a shop to do the swap? If you do blow up from fiddling around, they are completely off the hook.
rdieder is offline   Reply With Quote
Old 03-18-2014, 10:40 AM   #24
Alkaline198
Member#: 318472
Its back at the shop. The transmission line pressures are very low. What normally causes that
Old 04-20-2014, 03:44 PM   #25
Alkaline198
Member#: 318472
Had the 4eat rebuilt and upgraded the clutch holding capacity. Also put in a shift timing kit to make it shift nice and firm. Loaded the AT roms from a jdm non sTi WRx. They didnt work correctly. Went back in and repinned the ecu/tcm to run the at load off the maf signal. Also repinned some wires to get the correct torque signals.
Car runs great now- very quick.
Recap:::
Ej207 swap into 4eat 2004 WRX
Downpipe
Twin Scroll
Cat back
Air Intake
Dyno tuned
285/320 whp/wtq
