Old 02-12-2014, 12:22 AM   #1
aftalifex
Member#: 330635
WRC blue
Default quick question about a head rebuild
My 02 wrx valves got all bent, engine is out and I am beginning the teardown, heads will need a rebuild and I can't seem to find a complete list of the components I will need for the rebuild. I am a noob, first engine pull ever. I am going to have a shop rebuild and machine it but I need to buy the parts.
I know I will need...
valves
shims
buckets
springs
retainers
Can anyone add to the list? Any help is appreciated.
aftalifex is offline   Reply With Quote
Old 02-12-2014, 12:43 AM   #2
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
valves
shims
buckets
springs
retainers
better check and replace the valve guides.
use OEM valve seals too, and new keepers.
-Phil
PM me if you have questions.
Heads should be pressure tested, and I ultrasonic clean them.
Flat 4 Motorsport is offline   Reply With Quote
Old 02-12-2014, 08:31 AM   #3
Barney145
Member#: 376219
1977 5.4L MGB
You may want to ask, not tell (they don't like that) your machine shop to be sure to remove the oil galley plugs in the heads. They come out fairly easily once the heads are hot from the cleaning tank or spray wash cabinet.
Barney145 is offline   Reply With Quote
