Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 10-16-2002, 01:09 AM   #1
ryuwrx
Member#: 26714
2002 Spec C
LUR LUR
Post CEL Dumb Question?
I just registered on I-club today. I was told that I could find a solution to a p-0420 code causing my cel. Obviously I'm a little behind on the TXS tech talk. So here's my deal. Stage 2 TXS Unichip, filter, Catless turbo back and an annoying cel. I read threw a lot of the forums and the UTEC seems to be the best solution, however, I'm looking for the alternate (financially suitable) solution. I think this subject has been beat to death before, but like I said I just got here.
ryuwrx is offline   Reply With Quote
Old 10-16-2002, 09:02 AM   #2
TurboXS
Member#: 4143
2002 WRX Wagon
WR Blue
Default Re: CEL Dumb Question?
Welcome to the i-club! Now to answer your question:
The UTEC will not eliminate the P0420 (Cat System Efficiency Below Threshold CEL). You can choose to turn the CEL off with the UTEC so as not to be annoyed by it, but codes are still stored in the ECU until they are cleared. To eliminate this CEL cheaply go here: http://www.ponyexpressperformance.co...liminator.html
As an aside, you can use the Search function on these forums to look up a ton of info on a variety of topics.
Mark
TurboXS
TurboXS is offline   Reply With Quote
Old 10-16-2002, 10:29 AM   #3
nekard
Member#: 12927
2002 Impreza WRX
How and where in the UTEC do you turn this off?
nekard is offline   Reply With Quote
Old 10-16-2002, 11:58 AM   #4
TurboXS
Member#: 4143
2002 WRX Wagon
WR Blue
1. Go to Edit Maps
2. Go to Parameters
3. Go to User Constants
4. Go down to CEL (Disable = 0; Normal =1)
5. Change it from the default of 1 to 0
Your CEL will now turn off a few seconds after you start your car. If you get a new CEL, the light will not turn on, but the code will be stored and can be retrieved via the OBD2 port.
Mark
TurboXS
Old 10-16-2002, 12:59 PM   #5
nekard
Member#: 12927
2002 Impreza WRX
Thanks a bunch Mark!
Old 10-16-2002, 02:11 PM   #6
ryuwrx
Member#: 26714
2002 Spec C
LUR LUR
I knew there had to be an easy solution. Thanks a lot Mark.
Looking for dumb answer to a dumb question (HD DVD related) L Bo Off-Topic 15 05-09-2007 11:42 PM
A few Dumb Questions, but still Questions... ScubyMedic Normally Aspirated Powertrain 7 06-08-2006 10:39 AM
CEL problem...can i pull the code with a utec? dumb questions inside... M32WRXin3seconds Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-12-2003 12:41 PM
Dumb question about strut compatibility... Velocity Legacy Forum 10 09-15-2000 08:26 AM
Dumb question - Why not an "i club"? DoctorMoo North West Impreza Club Forum -- NWIC 2 04-12-2000 10:33 AM
