#1 |
Member#: 19876
Vehicle:2009 Forester XT ltd Ich bin verdammt Teufel! |
Wondering if I can use the same wiring/tubing from the factory gauge to wire up a mechanical Omori boost gauge. Anybody do this?
#2 |
Member#: 13634
Vehicle:2002 WRX WRB |
you can use the same vacuum line i'm pretty sure as long as the omori uses a restrictor too, but the power harness will probably not work because the plug for the oem will most likely be different than the plug in the back of the new omori.
#3 | |
Member#: 19876
#4 |
Member#: 13634
cutting and splicing will work, but you might want to just run new wire so you can sell your old boost gauge. the vacuum wire you can just substitute the stuff that the omori came with.
#5 |
Member#: 19876
sell it? i wouldn't screw somebody like that.
seriously, it does not read 0 when the engine is off. the install manual says that this can be expected due to differences in manifold pressure between cars. so that was my dealer's excuse for not replacing it. what a crock. my blitz dtt tells me that the OE gauge is off by as much as 0.2kPa during boost/idle. |
#6 |
Member#: 16071
Vehicle:2005 G35 Sedan Twilight Blue |
I did this exact swap.
I used the stock vacuum hose, for mine the stock hose has the correct restrictor attached. For the wiring, I stripped the Omori side with about 1/4" of wire showing. I plugged them right into the stock plug and secured with electrical tape. No splicing required. Oh, you are comparing the accuracy of your mechanical boost gauge versus your electrical blitz dtt gauge. Well you dtt gauge could be wrong also. Anthony |
#7 | |
Member#: 19876
#8 |
Member#: 17642
Vehicle:02 wrx mbp |
anyone know how to get the factory boost gauge out of the rubber pocket w/o tearing it up?
#9 | |
Member#: 25254
Vehicle:2003 WRX wagon |
#10 | |
Member#: 19876
#11 |
Member#: 17642
cool, thanks guys!
bille |
#12 |
Member#: 17439
Vehicle:2002 x2 Silver WRX Sedan, White WRX Wagon |
I hunt "Phillywrx's" for a living
I ordered my gauges from kastleskorner.com -- should be here in a little bit. I too will let you guys know how the "swap" went. Also, check this thread out if you haven't already done so! http://forums.nasioc.com/forums/show...hreadid=255631 |
#13 |
Member#: 26974
Vehicle:2003 WRX WR Blue |
What happens when you remove the boost gauge's restrictor and replace it with, say a 3/16" coupler?
#14 |
Member#: 26974
#15 | |
Member#: 17439
Not exactly sure what you mean - if you mean the 3/16"s mod, then I would say you might be confused. It was my understanding that the 3/16th mod comes into play here: I'm also pretty sure there is no reason to tap off of this thing for a boost gauge, but I could certainly be mistaken. Also, WebKris (on the forums) had tried all sorts of different configurations for the 3/16ths mod, so it IS possible he tried what you may be suggesting and came up with no benefit. (If THAT's what you are saying.) |
