Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 03-27-2001, 10:10 AM   #1
Diz
Member#: 874
2015 WRX STI
2004 Mazdaspeed MX-5
Post Old Teins DON'T FIT!
Ok, now you all have been warned. The Tein coilovers from the old Impreza DO NOT fit the new model. I just got off the phone with Firestone and they said the car will NEVER align properly with the coilovers. Luckily, JCSports is being very supportive and said they could yank out coilovers and put my OEM struts back on. DAMMIT! Looks like I'll have to wait for a new suspension.
I'll keep you guys updated.
-Paul
Diz is offline   Reply With Quote
Old 03-27-2001, 10:42 AM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
Any chance you'd sell them?
Sorry to hear about your troubles...
DLC is offline   Reply With Quote
Old 03-27-2001, 11:18 AM   #3
El Kabong
Member#: 625
2005 STi
WRB/Gold
Post
ack!! That sucks... well, if you need to unload them for 1/5th the cost, I'm your man... hehehe...
El Kabong is offline   Reply With Quote
Old 03-27-2001, 11:22 AM   #4
Spectre23
Member#: 311
2013 STi
CBS
Post
What part of the alignment doesn't work? Are you just getting too much negative camber? They are supposed to work. Does Firestone even have the right specs for the WRX or are they trying to align it to factory RS settings? Firestones around here are very incompetant. I would take it to a place that only does alignment and is good at it and see what they say.
Spectre23 is offline   Reply With Quote
Old 03-27-2001, 11:40 AM   #5
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
Spectre23, DMS has already published that suspensions from the old body will transfer over to the new body correctly. I wonder what part of the alignment isn't working though
Strepto is offline   Reply With Quote
Old 03-27-2001, 11:45 AM   #6
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
I would quite literally drive to Denver to get these, i'm so crazily desperate!
They really should work...gtguy had troubles with some clowns at a Firstone place with his DMS Gold, but found a shop that knew what they were doing and got them on right.
Old 03-27-2001, 06:48 PM   #7
DaveK
Member#: 2338
1988 323 GTX
black
Post
Looks like the current best offer is 1/5th.
I'll double the bid and take it up to 2/5ths
Although, let us know what you're asking, I'm very interested, as are some others.
DaveK is offline   Reply With Quote
Old 03-28-2001, 07:00 AM   #8
Diz
Member#: 874
2015 WRX STI
Wink
Vultures, the lot of ya...
Anyway, I have come to the conclusion that Firestone is incompetent. I am having the service department at the dealer look at it and if that doesn't work, I'll see if I can find some adjustable pillow ball mounts. I'm not giving up on this yet. In fact, I'm going to ride this one to the bloody end. If I have to buy a beater Impreza to put those damn coilovers on, so be it. They're going to bury me with those damn things.
Old 03-28-2001, 07:10 AM   #9
MstrDC
Member#: 366
2013 Subaru WRX
Post
Like everyone said, best bet is to take it somewhere else. Firestone doesn't know what they're doing at all. Firestone is right up there with Jiffy Lube. You don't want to mess with those guys!
MstrDC is offline   Reply With Quote
Old 03-28-2001, 08:16 AM   #10
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
I know gtguy had a lot of problems with getting the dolts at one of those places to get his DMS sorted out, so he talked to DMS and they told him to find a more specialized shop.
He did, and they got it right.
Old 03-28-2001, 10:23 PM   #11
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
Paul, I told you two months ago they wouldn't fit and to sell em to me, before you ever pulled them off your car
Interestingly enough, I just spent today at Firebird Raceway in Phoneix thrashing the WRX, and it is more competant on stock suspension than I ever expected! Those BBS wheels with RE011's are incredible!
More on that story tomorrow - I am beat.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 03-29-2001, 06:19 AM   #12
Diz
Member#: 874
2015 WRX STI
Talking
I am exploring a couple of options. My main problem is that I have too much camber in the rear (both sides). I was hypothesizing that it is the result of the mount point for the coilover being slightly offset (towards the inside of the car) from the stock mount points. I am using the Tein pillow balls, Legacy application.
There are three options:
1. Find a way to use the stock mounts. This would keep the geometry pretty much the same.
2. Use the adjustable Tein pillow balls. This would allow me to put the mount point back to stock location. This may not be a viable option because I'm not too sure they even make these for my car.
3. Get a hold of some camber bolts. Brett at Flatirons suggested this. That way, we can adjust the camber without causing excessive toe-out.
If anyone has any intelligent suggestions (not 'sell them to me for a fraction of the price'), please let me know. I'd like to hear opinions. Cheers.
-Paul
Old 03-29-2001, 07:29 AM   #13
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
out of curiosity, does the shop you've taken it to have the correct specs for the WRX? Possible that Subaru has changed the specs on the 2002 model. If the shop doesn't have them I'm sure Bret can get them for you. Just wondering because all the pics of lowered MY02 WRX's I've seen on this board show a lot of rear negative camber.
Also, I don't know if this is possible but DMS' suspension uses washers to adjust camber. Maybe you could get a hold of them and see if you can use the same washers on the Teins
Old 03-29-2001, 07:36 AM   #14
Diz
Member#: 874
2015 WRX STI
Question
Ro -
Where are the washers used on the DMS setup? At the mount point on the body? I have washers and spacers for the Teins. We may want to try those, too.
Old 03-29-2001, 08:12 AM   #15
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
honestly I don't know. I thought they used them on the big bolts at the bottom, but I don't know for sure. The USA rep for DMS is on the board (DMS-USA is his username, real name is Dave), you may try asking him.
Old men don't like imports Drink Off-Topic 28 10-04-2006 11:59 PM
Yep. Prodrive mud flaps don't fit '05 STi bumpers, so you MAKE them fit. supermarkus Member's Car Gallery 17 04-27-2006 02:46 PM
Why Tein don't comprehend? mattjk Off-Topic 24 10-31-2003 03:09 AM
weedeaters and old men don't mix Ryan Smith North West Impreza Club Forum -- NWIC 18 07-13-2002 05:20 AM
Mud Flaps don't fit!!!! paultg General Forum Archive 4 05-27-2000 12:31 AM
