Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 05-04-2014, 05:23 PM   #26
Serkan
Member#: 180514
2004 Sti White
Can someone with a 2015 sti crawl under the car and take some pics of the steering rack for us. So can know if it is even close to make it fit.
Serkan is offline   Reply With Quote
Old 05-07-2014, 06:55 AM   #27
almostJDM
Member#: 163239
2013 STI
thie is from the thread over at IWSTI
2013-----------------------------------2015
34430FG040------ PUMP-POWER STEERING ---- 34430FG040 Same
34160XA000------ TIE ROD COMPLETE Outer--- 34160XA000 same
34166AG050------ CLAMP-GEAR BOX PINION---- 34166AG030 not
34161SA001------TIE ROD END ASSEMBLY------34161SA001 same
34115AG010------rack bushing-----------------34115AG010 same means same diameter tube
34166AG030-------CLAMP for rack bushing -----34166AG050 different consistent with different body
34170FG011------UNIVERSAL JOINT ASS--------34170VA030 not but may just be longer shouldn't be required for swap
901000372-------FLANGE BOLT Mounting--------901000372 same mounting bolts
2011 Rack http://subarupartsheadquarters.com/?...tsheadquarters
2015 Rack http://subarupartsheadquarters.com/?...tsheadquarters
http://www.iwsti.com/forums/2015-sti...rack-swap.html
almostJDM is offline   Reply With Quote
Old 05-07-2014, 10:46 AM   #28
slide
Member#: 1130
2013 STI Hatch
What about the steering angle sensor? I'm a complete idiot when it comes to how the steering system and vdc work together. Is the 2015 able to retrofit into a 08+?
If this can work I want one.
slide is offline   Reply With Quote
Old 05-07-2014, 11:58 AM   #29
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
thankfully i don't have any of that fancy **** on my bugeye.
Old 05-07-2014, 12:30 PM   #30
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
Based on the above, it sounds like a very doable swap for the GR, the question is who will be the first to try it on the GD?
If it works for the GD, I'll take 2. SRSLY
T-37 is offline   Reply With Quote
Old 05-07-2014, 03:22 PM   #31
onerazorsharp
Member#: 347837
2010 WRX STI
I've been waiting to find a thread on this, thank god this conversation has been started. Does anyone know if the L&E quick gears will cause the issue with the sensors as well? Frankly, I would like to keep my yaw control available for street driving, but also have a shorter ratio....
The L&E option is not an actual rack, it is a set of shorter ratio gears for the rack.
Hi *****, we do not sell a quick steering rack. We modify the steering column with a 1.5 quickener. This provides a 1.5 times faster steering ratio with a slightly heavier steering. My son has this installed on his Impreza for 10 years of street driving. As with any faster steerings you have to be aware of the faster steering so you do not over correct.
Hope this helps.
Best Regards Larry
onerazorsharp is offline   Reply With Quote
Old 05-07-2014, 04:30 PM   #32
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
based on my prior research, the second gen gd/gg subframe will accept third gen gr/etc racks.
the 2nd gen steering column side U strap has been replaced by flanges cast into the 3rd gen rack housing. fitting the new rack housing requires longer bolts to reach the captive nuts on that side as a result, but no other modification is necessary.
there is also an additional mounting bracket which is used on the 3rd gen that utilizes two extra bolt holes, but the bracket and the two bolts can be left off.
that's my understanding at least. it's pretty recent as i have a failing rack on my bugeye...
Old 05-07-2014, 06:24 PM   #33
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
Thanks for the info.
So if my car uses the "square" bushings it is a gen 1 GD, Meaning I'd need a gen 2 GD subframe from an 05+? Am I interpreting correctly?
Old 05-07-2014, 06:31 PM   #34
Serkan
Member#: 180514
2004 Sti White
So I guess we wait till someone wrecks their 2015 sti (without dying) and someone buys the steering rack to fit on their GD or GR.
Old 05-07-2014, 07:54 PM   #35
salvi
Member#: 188132
What is this steering angle sensor and is it needed if going onto a GD subframe? I have my RS swapped, so if it fits the GD, it fits my RS
salvi is offline   Reply With Quote
Old 05-08-2014, 06:52 AM   #36
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i do not believe you need to swap the subframe, as the "strap" holes are in the same spot as the "tab" holes.
see http://forums.nasioc.com/forums/show...9#post29914989
Old 05-08-2014, 06:54 AM   #37
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i don't know/remember where i scraped the following quote, as it's just in my evernote folder, but it may be of assistance.
apologies that it is not properly cited:
The 05+ wrx and sti steering rack can be mounted without the newer crossmember. I know that they can be mounted to the pre 05 wrxcrossmembers. They will bolt "incomplete" using 4 bolts instead of 6, but that is sufficient because it is the same positioning and design of how our steering racks mount right now. Two bolts will need to be replaced with longer bolts however. The bolts will be M10x1.25x50mm
So recap and extra clarification:
- 05+ WRX and STi come with 15:1 ratio steering racks and newer cross members
- Newer racks can fit with older Impreza cross members with 4 bolts (replace 2 with longer ones)
- The newer cross members are nicer because of less lateral movement from the two extra bolts, but they are not needed.
Old 05-08-2014, 01:02 PM   #38
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
Awesome info. The shop a buddy of mine is working at is prepping a Pikes Peak car for this year. They've got a '15 STi rack on the way, and should be able to confirm fitment on their GR. Hopefully he, or someone else from that fairly popular shop, will chime in.
Old 05-08-2014, 01:04 PM   #39
almostJDM
Member#: 163239
2013 STI
Looks like someone called Subaru directly and they confirmed it would be a direct swap with minimal modifications, which I'm hoping just means that clamp and they said the VDC would continue to work with the angle sensor, if it turns out to be true looks like I'll be ordering a new rack in 2 weeks haha
Old 05-08-2014, 01:08 PM   #40
slide
Member#: 1130
2013 STI Hatch
I so hope this is true!
Old 05-08-2014, 04:53 PM   #41
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
good info almostjdm!
thank god i never went for those overpriced quickracks.
Old 05-08-2014, 08:57 PM   #42
Serkan
Member#: 180514
2004 Sti White
If it fits GR, it will fit 05-07 sti as well.
Only difference between the GR and 05-07 sti is the passenger side bushing.
OD of the passenger-side bushing is same for both, so I am assuming if you use KSR207 bushings with GR bracket (or modify 05-07), all should work fine for 05-07 crossmember
Old 05-08-2014, 10:07 PM   #43
JonnyV2889
Member#: 197384
2006 WRX Ltd
I have read the coupler spline count is different on the GR vs GD. Not sure if this in on both ends? Could be a minor issue though.
JonnyV2889 is offline   Reply With Quote
Old 05-08-2014, 11:08 PM   #44
Serkan
Member#: 180514
2004 Sti White
Hmm I thought Subaru would have kept that part same. That might be a problem if steering column splines don't match the U joint.
Old 05-08-2014, 11:11 PM   #45
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
swap steering column..
murrdogg24 is offline   Reply With Quote
Old 05-10-2014, 08:44 AM   #46
101101
Member#: 260658
2011 STI Sedan
Do you have a link to this?
Just to confirm, are you saying that if I buy a 15+ rack and a 15+ steering angle sensor then the stability control, DCCD, ABS, etc will function properly with the new rack ratio?
101101 is offline   Reply With Quote
Old 05-10-2014, 09:06 AM   #47
almostJDM
Member#: 163239
2013 STI
http://www.iwsti.com/forums/2015-sti...rack-swap.html DCCD and ABS will work without any issues, it's the VCD that's going to go crazy if anything
Old 05-13-2014, 01:15 PM   #48
t0wardseternity
Member#: 241221
2004 WRX Wagon
Java Black Pearl
34110VA120 is the part number for the 15 sti rack assembly. MSRP is $712.34 and dealer cost is $548.50. Only two available in the country through subarus warehouses right now though...
t0wardseternity is offline   Reply With Quote
Old 05-13-2014, 01:48 PM   #49
slide
Member#: 1130
2013 STI Hatch
Hopefully some one figures out te steering angle sensor and if it works with the vdc. Then I am in!!!
Old 05-13-2014, 02:42 PM   #50
salvi
Member#: 188132
What is this steering sensor you all speak about? Will this matter if going into an older 02-03 WRX?
