Old 05-13-2014, 02:59 PM   #51
slide
Member#: 1130
2013 STI Hatch
No, just the newer ones with vdc
slide is offline   Reply With Quote
Old 05-13-2014, 03:27 PM   #52
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
Awesome! I was planning on going to a GD STi rack on my 05 WRX but not if the '15 steering rack fits!
Honest Bob is offline   Reply With Quote
Old 05-13-2014, 05:01 PM   #53
salvi
Member#: 188132
waiting on results to buy one for my RS :0
salvi is offline   Reply With Quote
Old 05-14-2014, 07:18 PM   #54
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
There are a couple of us here that are pretty darn curious about this swap. We have a 2015 STI Steering rack, and for starters, we grabbed a 2002 - 2004 WRX front cross-member to see how close they would be.
We are most likely a little ways out on actually putting this into a car or two, but we'll let you know how it goes.
FlatironsTuning.com is offline   Reply With Quote
Old 05-15-2014, 06:09 AM   #55
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Hell yes I was hoping a shop would step up and do this. In for fitment on GD.
A-man07 is online now   Reply With Quote
Old 05-15-2014, 11:14 AM   #56
dobie0791
Member#: 72713
2005 STi
Same here.
If it turns out this rack works for the GD/GG and GR/GV, SOA should have FHI fill a shipping container with these to send stateside because the demand will be huge! SOA blog are you reading this?
dobie0791 is offline   Reply With Quote
Old 05-15-2014, 12:09 PM   #57
almostJDM
Member#: 163239
2013 STI
This is getting me all antsy now lol
almostJDM is offline   Reply With Quote
Old 05-15-2014, 12:25 PM   #58
salvi
Member#: 188132
looks like the mounting points for the front crossmember are the same.
Old 05-15-2014, 01:16 PM   #59
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
curious as to why flatirons didn't just throw 4 bolts in there...
Old 05-15-2014, 01:49 PM   #60
FlatironsTuning.com
Member#: 171650
It might be a little hard to tell from the picture, but the spacing of the two main holes in the crossmember are a little smaller than the rack needs. There would definitely need to be some material removed to get the rack to go through.
This is a brand new crossmember that we just grabbed off the shelf, so we can't grind on it.
We have a 2014 WRX that we will most likely be trying to install this in, but it will have to wait until July, as it is being prepped for the Pikes Peak Hill Climb at the moment, and we have a lot of bigger things to get sorted before then.
Old 05-15-2014, 03:09 PM   #61
slide
Member#: 1130
2013 STI Hatch
How different is the '04 crossmember from the 08+ GR's?
Maybe ill ask Mert at rbms if he will work a deal with me to test run a rack and steering angle sensor...
Old 05-15-2014, 03:15 PM   #62
Serkan
Member#: 180514
2004 Sti
I don't understand why you tried it on 02-04 wrx crossmember instead of 05-07 sti
Originally Posted by FlatironsTuning.com View Post
There are a couple of us here that are pretty darn curious about this swap. We have a 2015 STI Steering rack, and for starters, we grabbed a 2002 - 2004 WRX front cross-member to see how close they would be..
Serkan is offline   Reply With Quote
Old 05-15-2014, 03:51 PM   #63
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
^^^ The 02-04 crossmember and the 05-07 STi/WRX crossmember are essentially the same. There are very minimal differences.
Surfer Steve is offline   Reply With Quote
Old 05-15-2014, 04:05 PM   #64
salvi
Member#: 188132
The first pic does seem now that the mounting holes from the rack are hitting the crossmember preventing to fully seat inside the crossmember and reach the mounting holes.
Can the rack mounting hole brackets be ground down instead?
Old 05-15-2014, 04:14 PM   #65
Serkan
Member#: 180514
2004 Sti
I thought driver side steering rack mounting points were different.
Old 05-15-2014, 05:07 PM   #66
FlatironsTuning.com
Member#: 171650
There are a number of reasons.
First is that we had this sub-frame on hand.
Second is that the 02 - 04 sub-frame is going to be the most different from the 2015 sub-frame, so if the rack can be made to fit into this one, the rest should be easier (in theory of course).
Last is because there are 2 people here that have this sub-frame, and really want a 13:1 rack, so that may well be one of the first cars that we try to put this into, so we wanted to see what we were up against.
Suffice it to say, this is not going to be a super simple install into this sub-frame. Modifications will be necessary, but we are still trying to figure out how substantial they are. I'd say that at this point there is a 50% chance that it may be easier to simply replace the sub-frame with a newer one (05-07) than trying to modify the existing one... But that is a good deal of work as well.
Yes they are different.
I'll also mention that the tie-rod ends look a good deal longer, as this is for the wide-body sedan, that is not too much of a surprise. However, there is a good chance that these will need to be swapped out for a narrower track instillation as well.
Old 05-15-2014, 06:53 PM   #67
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
thanks for the first hand info flatirons.
much appreciated!
ken
Old 05-15-2014, 07:04 PM   #68
Serkan
Member#: 180514
2004 Sti
Yes, thanks a lot for sharing your findings.
Please keep us updated. It would be great if you can also mock it on the 05-07 sti crossmember.
Did you get a chance to check if the splines match with the 02-07 steering U-joint ?
Old 05-15-2014, 08:31 PM   #69
Bikelok
Member#: 254851
2002 WRX wagon 5mt
As an 02 owner, THANK YOU!!!!!!!!!!!!!!!
Bikelok is offline   Reply With Quote
Old 05-15-2014, 09:56 PM   #70
69subaru360
Member#: 159682
1995 WRX
2015 F150
Wonder if the internal part would swap over into an older rack? Have they changed much over the years?
I can get my subaru parts at dealer cost now. $500 isn't bad, but say $100-200 for just the rack and pinion gears and a few seals would kick ass.
I really wanted a 11.5 Qrack, but they are no more new.
Old 05-16-2014, 12:29 AM   #71
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
subscribed
codesoccer is offline   Reply With Quote
Old 05-16-2014, 05:47 PM   #72
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
Can't wait to see the results of someone trying this out. Thanks, Flat Irons Tuning for your info so far.
As for the wider track, can't one simply turn the rod ends until they matched the width of their respective racks?
kenliu84 is offline   Reply With Quote
Old 05-16-2014, 06:15 PM   #73
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
It kinda looks like the inner tie rod ends are longer than normal to me. If there is enough adjustment in them, turning might work though.
T-37 is online now   Reply With Quote
Old 05-16-2014, 07:02 PM   #74
69subaru360
Member#: 159682
1995 WRX
2015 F150
Worst case you just tap more threads and cut a bit off the ends. Or swap the inners from your old rack over if they fit. Knowing Subaru they will. The thread on the inners has been the same since the late 80's.
Old 05-19-2014, 11:08 AM   #75
VincenzoL
Member#: 134843
2013 STi hatch
Plasma Blue Pearl
Subscribed. Hoping it can fit the GR chassis.
VincenzoL is offline   Reply With Quote
