Old 10-16-2002, 12:43 PM   #1
wrxxtc
Member#: 11556
2002 impreza wrx
blue
Default will getting a new front sway and endlinks get rid of softness in steering?
wrx sedan....my friend has a cusco rear sway and mrt endlinks on middle setting and stock front sway and endlinks....17 inch rims and 225/45/17 tires...suspension is stock otherwise....i drove it and i also agree the steering is very soft...not sure if this will help.
thanks in advance
wrxxtc is offline   Reply With Quote
Old 10-16-2002, 02:23 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The correct alignment will have the greatest affect over how soft or firm the stearing feels. Id get a real alignment done first (no not at joes tires).
Old 10-16-2002, 02:23 PM   #3
Barry
Member#: 11554
2016 STI
Ice Silver Metallic
You may want to look at a Cusco lower arm brace. Firms up chassis and steering nicely.
Barry is offline   Reply With Quote
Old 10-16-2002, 06:12 PM   #4
wrxxtc
Member#: 11556
2002 impreza wrx
blue
what allignment specs would you go with having just rear sways and endlinks...he may get the front sways also and i'll let him know about the lower arm brace
Old 10-16-2002, 07:42 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
It depends on your driving conditions. Personally I wouldnt follow most of the recomendations on the club unless the person really competes (not just an ocasional weekend autocross). A real alignment shop intended for performance should conduct and "interview" and determine the most likely best specs.
Personally? I have a legacy and my most recent alignment (in short) was
-1.3 camber front
0.01 toe front
2.1 caster
-0.3 camber rear
0.01 toe rear
all but 2 (within 1/100 of a degree) spec was perfect side to side match and a perfect 0 thrush angle.
This made as much difference or possible more than when I switched from 185 70 14 wal mart tires to 205 50 16 kuhmo's
Old 10-17-2002, 11:27 AM   #6
wrxxtc
Member#: 11556
2002 impreza wrx
blue
anybody with a wrx that could give me good allignment specs...for some good back road driving on the weekends and weekly driving back and forth to work.
thanks in advance
Old 10-17-2002, 02:33 PM   #7
Davenow
Member#: 23676
Default Well..
I didnt have it done yet BUT
I am planning on getting as close as possible to 1 1/2 deg negatice camber front like 1 deg neg rear, no toe in/out
Unless someone can give me a good reason not to
I had a VW fox that I had set up pretty well, I ran
2deg negative camber front
1 deg toe out front
factory rear settings
I realize that isnt MUCH help but hey its a free bump anyway
Prosport boost gauge/ sti front sway and endlinks meat_WRX MAIC Private Classifieds 15 01-20-2008 01:33 AM
FS in Bay Area CA: BRAND NEW Whiteline 24mm Front Sway and Kartboy Endlinks fatcircles Suspension/Brakes/Handling 2 07-24-2007 12:34 AM
how did you get rid of moisture in gauges? iloveturbos Interior & Exterior Modification 1 12-13-2002 09:56 PM
Getting rid of scratches in the car majglow Interior & Exterior Modification 2 09-16-2002 10:13 PM
