Old 10-17-2002, 11:51 AM   #1
tuca33
Member#: 24303
2002 Impreza WRX
Default I Installed a SBC-ID and Need Help.
Here are some pics of my install..
People say the T i used is not needed and is not good to have it..
What you guys think??
Thanks
TucaEngine Area
tuca33 is offline   Reply With Quote
Old 10-17-2002, 12:46 PM   #2
byrdman
Member#: 14228
2002 Impreza WRX
WR Blue
the small plastic line needs to be hooked up somewhere. if it is not hooked up your boost controller will have not no idea of what it is doing. there are two places to tap in for the t-fitting. one is at the blow off valve, the other is at the intake manifold just below the throttle cables. only tap a line once if you have a boost gauge that is tapped in at the blow off valve you will need to use the other location.
byrdman is offline   Reply With Quote
Old 10-17-2002, 12:58 PM   #3
tuca33
Member#: 24303
2002 Impreza WRX
The small pastic line is installed somewhere,,but we cant see cause its black..
Its a very tine line..
I think is not showing cause its black and i didnt remember of it when i took the pics..
Anyway that T is hooked up and my system is working Fine..
People said that this other Metal T i used in the last pic is not good to have it..any problems?
Thanks
Old 10-17-2002, 01:16 PM   #4
codean
Member#: 10186
Yeah, that last picture is not right. There should not be a tee there. You should connect the purple sbc-id right to the turbo (using one of the gray tubes as a reducer). Then remove the tee and cap off the line that runs to the stock solenoid.
codean is offline   Reply With Quote
Old 10-17-2002, 01:34 PM   #5
hman
Member#: 3747
2002 Impreza WRX
Platinum Silver Metallic
I hooked my blue input and output hoses from solenoid strainght to the wastegate and turbo. Once it is on those area, i used hose clamps to tighten it down. The clamps that came with the kit is alittle too big, so I got new smaller clamps.
Basically, I did not use any connectors for the hoses.
Once that is done, I plug up the OEM solenoid hose.
Where did you mount your solenoid and display?
What do you mean by "T?"
Are you refering the the brass hose connector or the "T" on the OEM hoses?
Cheers
hman is offline   Reply With Quote
Old 10-17-2002, 01:49 PM   #6
tuca33
Member#: 24303
2002 Impreza WRX
Thanks for the help ,,now i understood..
Take a look at my Web page..there you have WRX interior,exterior and motor..
Tuca33
Old 10-17-2002, 02:03 PM   #7
codean
Member#: 10186
hman: You might want to go check you clamps. I did the same thing you did and found that the sbc-id tubes are cheap and crumble with use of a hose clamp. This is why you use the grey stock lines with the plastic reducers that come in the box.
Old 10-17-2002, 02:33 PM   #8
tuca33
Member#: 24303
2002 Impreza WRX
What is a capped off tube??
what i do with it???
and isnt the leftover tube wider than the other ones??
the other end where the leftover tube was connected ,,will it stay with nothing??nothing even to protect the entrace??
Thanks
Tuca
Old 10-17-2002, 02:54 PM   #9
codean
Member#: 10186
Cap off means close the end of it off so no air can get in or out.
Im not pointing to the large black tube. I'm pointing to the gray one behind it.
Old 10-17-2002, 03:18 PM   #10
tuca33
Member#: 24303
2002 Impreza WRX
Now i understood....
about the capped off tune,,how do i cap it off???
glue??sealant???
duct tape??
what??
Thanks
Tuca
Old 10-18-2002, 12:21 PM   #11
hman
Member#: 3747
2002 Impreza WRX
codean, thanks for the suggestion. I will re-examine the hose connections.
BTW: Where did you guys mount the solenoid?
This is how I "capped off" on my car:
-I used the little pastic connector that is on the OEM hose.
It is the gray looking.
-I plug that into the OEM solenoid hose. The hose in the pix above where it say "cap off."
-I go to the auto store and buy and small hose plastic cap. Zip tie it down and you are all set. If you need to drive your car to the auto store, use a small screw and plug it up until are able to buy the plastic cap. Make sure to take out the gray connector. Stick the screw straight into the hose to plug it up. Make sure you use a screw that is big enough to make it fit pretty tie. Do not use to big of a screw so that you rip the hose.
Hope that make sense.
Cheers
Old 10-21-2002, 11:16 PM   #12
tuca33
Member#: 24303
2002 Impreza WRX
So i have to buy a Small hose plastic cap to fit straight at the end of the hose???
Should it be metal or plastic??
So i wont need the plastic T???
Thanks
Tuca
Old 10-22-2002, 12:18 AM   #13
tdxflex
Member#: 13634
Mine's here, snug fit but the hose length is fairly short and it's covered.
tdxflex is offline   Reply With Quote
Old 10-22-2002, 12:24 AM   #14
tuca33
Member#: 24303
2002 Impreza WRX
Tdxflex.
mine is in the same place as yours =)
Thanks
Tuca
Old 10-22-2002, 02:46 AM   #15
hman
Member#: 3747
2002 Impreza WRX
My is in the same location, but I drilled to two holes and mounted it down.
Old 10-22-2002, 03:06 AM   #16
tuca33
Member#: 24303
2002 Impreza WRX
Mine is only secured by zip cable ties..
Its very secure i think.
Should i secure more by drilling holes and securing down with bolts??
Thanks
Tuca
Old 10-22-2002, 09:30 AM   #17
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Mounted mine off the IC bracket with an aluminum heat shield lined with auto-grade insulation...
def
dug-e-fresh is offline   Reply With Quote
Old 10-22-2002, 04:07 PM   #18
hman
Member#: 3747
2002 Impreza WRX
Zip tie is will do. I just wanted a clean look, so I bolted it down.
dug-e-fresh, nice engine.
Old 10-22-2002, 09:16 PM   #19
tuca33
Member#: 24303
2002 Impreza WRX
Dug e Fresh...COOOOOOL..
The Yellow look is awesome.
Do you have any closer pic of the engine bay area???
what are those blue hoses???Tell me about this Awesome beautifull engine??
Thanks
Tuca =)
Old 10-22-2002, 10:33 PM   #20
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
Thanks guys... I am glad you like it.
I used to have more pics... however my computer crashed and I lost them.
Some of the blue is hoses, some is tubing. All in all I think it turned out pretty well.
As for the yellow... its VHT Brake Caliper paint I had leftover. I started spraying stuff and didn't stop!
Its hard to get started, but with a couple layers leaves a really high gloss finish. Most people think its either powder coat or professionally done... just paint by me though.
Since this pic I have added the STi radiator cap, removed the K&N sticker (running an STi filter), added some Vishnu stickers... 1 black one on the belt cover and one white/reflective in the scoop.
I have also rerouted my IC sprayer lines, made them look cleaner and such...
thanks again!
def
Old 10-22-2002, 10:43 PM   #21
tuca33
Member#: 24303
2002 Impreza WRX
What that means??
what do you have??oil catch can??
do you have the water spray mod??
Thanks
Tuca
SBC-iD and Radio install... now electrical issues Oo DaRk StAr oO Electrical & Lighting 10 05-02-2003 01:35 AM
Installing a boost gauge and need help! Jase Texas Impreza Club Forum -- TXIC 4 08-20-2002 11:13 PM
Anyone with SBC-id and PM-id use the RPM Boost function?? Need Help!! smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-16-2002 10:20 AM
Blitz SBC-ID and power meter id installed DreamWalker Interior & Exterior Modification 0 10-31-2001 12:39 PM
Blitz SBC-iD and Power Meter installed on WRX. shawrf1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-19-2001 11:40 PM
