Old 03-10-2014, 05:00 PM   #1
AZWagon
Member#: 377153
2004 WRX Wagon
Default I am a noob. Need tuning advice. WRX protune?
Okay so I have tried researching this quite a bit. I came to the conclusion that a protune is the way to go. I am going to buy an accessport and get it protuned. Now heres my question. After I get the car protuned- Do I need to get it dynotuned after??
Accessport + Protune + Dyno time = Very expensive.
Would it be fine to just get a protune and go have some fun? or must it be dyno'd also?
Thank you
AZWagon is offline   Reply With Quote
Old 03-10-2014, 05:02 PM   #2
AZWagon
Member#: 377153
2004 WRX Wagon
Just incase this will help. I have a 2004 wrx, installing an uppipe, Down pipe, Short ram intake, and still debating on the 50/50 bpv.
Old 03-10-2014, 05:04 PM   #3
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
You need to understand what you're asking. A "Protune" is a tune that is custom to your car. This can be done via a roadtune, a dynotune, or an e-tune.
An e-tune will typically be the cheapest because it requires more work on your end. You are sent a basic map for your parts. you run it and then do some datalogs. Send these back to your tuner who tweaks them, wash, rinse, repeat until everything is lovey dovey.
A road/dyno tune requires the tuner to be with you in your car. They run the car up and down viewing live data and taking logs, make adjustments, wash, rinse, repeat until everything is lovey dovey.
So no, you don't need a protune AND dynotune. Have you decided a tuner yet? That may be a good place to start and then ask them what they think would be the best. They may not even require you to get an accessport. Save you even more money.
You need to do more research. And fill in your profile. I can presume you're in Arizona, but possibly not. Fill that in and we could recommend a local tuner for you. Also, what year WRX? That matters too. This may shock you, but if your profile was filled in, we wouldn't have to ask that either.
Ninja Edit: beat me to telling us what year WRX.
Loyale93 is offline   Reply With Quote
Old 03-10-2014, 05:16 PM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
You don't need an accessport to have a protune.
You also don't need a 50/50 bov.
If you can't afford to mod it right, don't mod at all.
Old 03-10-2014, 05:23 PM   #5
AZWagon
Member#: 377153
2004 WRX Wagon
I knew that the protune is a custom tune to my car. What I did not know was how they did it. So now that I know they just use the logs and tweak them. I have contacted Clark Turner because ive heard great things about his tuning. He recommended getting an accessport and his protune. I was just not aware that I had to get my own logs and send them to him. So the only thing different about a dyno tune is that the logs are taken live and tweaked and than can see actual horse power to the wheel. So I can get it protuned and whenever I want to find my actual whp just go to a dyno ( probably goodspeed) and just run It and see what it is VS them having to sit there for hours and tweak it in person- basically just dyno'd not dyno "tuned" after the protune?
Old 03-10-2014, 05:31 PM   #6
AZWagon
Member#: 377153
2004 WRX Wagon
It is not that I can not afford it, just do not want to spend more money than is necessary.
Overall I could just get a tactrix cable and run my own logs and send them to him and then upload to the ecu myself via opensource and just not have all the fancy features of an accessport?
And I bought the bpv but I think im going to just sell it because ive heard nothing but bad things with them
Old 03-10-2014, 05:33 PM   #7
AZWagon
Member#: 377153
2004 WRX Wagon
Am I starting to get on the right path here?
BTW I filled my info in
Old 03-10-2014, 05:35 PM   #8
meat_WRX
Member#: 96919
2004 sti
black
if it aint broke dont fix it, right?
meat_WRX is offline   Reply With Quote
Old 03-10-2014, 05:41 PM   #9
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
Based on your initial post and your response to Loyale93 I suggest you schedule an appointment with a reputable tuner near you and just let them do it.
Don't take this the wrong way but you don't seem to understand how an e-tune/datalogging works so I would avoid that completely or until you've done more research. Plus, knowing how Clark is, after you send him your initial logs he will most likely tell you that you have an issue with a boost leak or something else that needs to be "fixed" before he continues to tune it. This will likely send you on a wild goose chase. Also, he doesn't take well to working with people who know very little and can come off as a pretty big ***hole. So that might frustrate you pretty quick.
In your case, if you are determined to install the mods you have listed, definitely pay the money to have a local tuner get the car dialed in properly for them. You'll thank yourself later.
Also, listen to HinshawWRX and forego the 50/50BOV. It's completely unnecessary.
sc00ter is offline   Reply With Quote
Old 03-10-2014, 06:17 PM   #10
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Save up and spend the extra money on getting it tuned by Clark in person at Goodspeed. Arrange for Joe to go over the car to certify it has a clean bill of health with no overlooked boost leaks, etc, etc..before the actual tune.
This will save you any headaches, and could probably save you another tune if something has been overlooked.
fastnoypi is offline   Reply With Quote
Old 03-10-2014, 08:24 PM   #11
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
A dyno is used for one thing and one thing only. Run a load on the vehicle to measure power output. There is very little difference between a dyno tune and a road tune, except that a dyno tune allows more control. For instance, if the tuner wants to keep the car at 3500rpm for some reason at full load, they can on a dyno. That's difficult on the road.
Yes, you can get it tuned or not, and then go to a dyno to get your whp/wtq.
But I have to agree with Scooter there, it sounds like you have a lot more reading to do and learning. Maybe try and find a local group that's doing a dyno tune and hang out there.
Old 03-10-2014, 09:28 PM   #12
AZWagon
Member#: 377153
2004 WRX Wagon
Yeah I really have no idea what I am talking about LOL. Just trying to get a basic knowledge so that I can even talk to someone about getting it tuned. I will take your advice and see if I can get Joe at goodspeed to look at my car and see if I can get clark to actually tune my car in person. I want it done right the first time, so ill leave it to the professionals
As for the BPV, I guess it is an inner ricer thing lol I know it doesn't do anything performance wise expect hurt my car. but I like the noise and figured if I can get it tuned correctly it wont hurt my car, especially since its a hybrid. I could use the extra cash to get it tuned by Clark though..
Thanks for pointing me in the right direction.. Hopefully soon I can figure something out
Old 03-11-2014, 05:42 AM   #13
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
Have you read Unabombers manifesto? It gives pretty clear descriptions about what tuning is. And how it works.
Old 03-11-2014, 12:57 PM   #14
boost-o-matic
Member#: 248364
2010 Huevos grandes
WRX Dom 1.5XTR E85 silver
If all you have is a Cobb AP and a crappy BPV...that isn't worth doing a protune on. Get at least a downpipe (catless preferably) and a cat-back exhaust before the protune. 50/50's or full "vent to atmosphere" BPV's sound cool, but the ECU thinks all that air is going back into the car. So, unless you want to lose power...keep your oem unit. If you end up getting a lot higher boost (like with a larger turbo, injectors, etc)...then you can swap out the BPV, but only for a full recirculating one. If you want to hear the BPV, get a cold air intake also. But even at that point, I would simply use the base maps supplied with the access port. But, check the basemaps first, and/or load some fresh ones onto your AP. If they don't make a basemap for catless DP's (which last time I checked they didn't), you'll either need to get it custom tuned, or go catted DP. At stg 2 levels, a catted DP isn't too big of a hinderance to power...you'll be making somewhere around 300/340 hp and tq to the wheels.
=) Good luck, and enjoy the car!
boost-o-matic is offline   Reply With Quote
Old 03-11-2014, 01:00 PM   #15
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
And a good tuner would/should do a little road tuning after the dyno tune to get everything fully dialed in anyway.
... There you go!
Originally Posted by boost-o-matic View Post
If all you have is a Cobb AP and a crappy BPV...that isn't worth doing a protune on. ...
His parts list is in the second post.
Old 03-11-2014, 01:43 PM   #16
boost-o-matic
Member#: 248364
2010 Huevos grandes
Ok, do a CAI preferably if you are going to change the intake...stay away from short RAM's as they suck in hot air from the engine compartment. Also, a CBE will help...I know the DP is a much larger restriction, but doing a tune without a CBE seems a bit silly to me.
Old 03-11-2014, 08:57 PM   #17
AZWagon
Member#: 377153
2004 WRX Wagon
oh crap I totally forgot to add that I have an Invidia N1 Street catback idk how I forgot that!
and I don't want to go CAI because of the risk of water/mud get sucked into the engine. But with the Cobb Short Ram, I got the box and left the air ram so it gets cold air. Works good for me!
[quote=boost-o-matic;41596564]If all you have is a Cobb AP and a crappy BPV...that isn't worth doing a protune on. Get at least a downpipe (catless preferably) and a cat-back exhaust before the protune. 50/50's or full "vent to atmosphere" BPV's sound cool, but the ECU thinks all that air is going back into the car. So, unless you want to lose power...keep your oem unit. If you end up getting a lot higher boost (like with a larger turbo, injectors, etc)...then you can swap out the BPV, but only for a full recirculating one. If you want to hear the BPV, get a cold air intake also. But even at that point, I would simply use the base maps supplied with the access port. But, check the basemaps first, and/or load some fresh ones onto your AP. If they don't make a basemap for catless DP's (which last time I checked they didn't), you'll either need to get it custom tuned, or go catted DP. At stg 2 levels, a catted DP isn't too big of a hinderance to power...you'll be making somewhere around 300/340 hp and tq to the wheels.
AND to what you said about the 300whp/340tq to the wheels with a "stage 2" 2.0 wrx with a stock turbo and injectors.. Is NOT true. Lol your a bigger noob than me
Old 03-11-2014, 08:58 PM   #18
AZWagon
Member#: 377153
2004 WRX Wagon
Thanks though everyone, I got enough information from this thread to arrange getting my car tuned
