#1 |
Member#: 24399
Vehicle:2003 A. White WRX 2006 Yamaha "Raven" R6 |
Ok, so i'm trying to wire in a relay so that it cuts the security/keyless wires during count down, and keeps them together at all other times. Is there a line of the timers that is only active during count down? Specifically the HKS type 1, but it should be the same.....does the timer ignition wire only active during countdown? If so that wire would be perfect....
Thanks! |
#2 |
Member#: 24399
ok so i found a new problem.....my speed on the turbo timer is almost double what the actualy speed is...and I know its in kilometers, but its still says i'm doing 100km/h when i'm doing 50km/h.....is there a resistor that I need to put in there or something? Anyone else having this problem?
Thanks... |
#3 |
Member#: 24399
ok, I am a little dumb, i just needed to recalibrate the speed function....hehe w00t......back to the original question...
#4 |
Member#: 24399
bump....i need to know so that I can wire my relay in....also this will help all new turbo timer guys....
#5 |
Member#: 6000
Vehicle:2000 GC8 STi V4 swap BRP |
Electronically a turbo timer detects when the ignition is switched off and uses a relay to keep the ignition in the "on" state as though the key were not switched off at all. I've designed my own turbo timer/EBC unit so I use a few special things that others do not seem to use but in principle it's the same.
-Michael |
#6 |
Member#: 24399
ok, so if I tap the ignition wire off the timer, it should be logic low when the car is on through the key, and logic high when its counting down?
If so that would be perfect for what I am using my relay for....Also, tell me more about your custom design...i'm curious ![]() |
