Old 10-17-2002, 07:28 PM   #1
shortlid
Member#: 10297
2003 Legacy GT Sedan
Silver, 4EAT, 42k
Default '98 L Legacy Wagon hard to start today?
Our '98 Legacy L wagon with EJ22 did something weird today. It had sat for two days, in the rain. When I went out to start it I cranked for a minute it would cough a few times and try to catch so then I used the gas petal. It final sputtered to life. But did not sound or smell like it was flooded? It has 84,000 on it I just replaced the spark plugs the air filter is good. So I just put fuel system cleaner in it and got fuel filter from the autoparts store for $15. The fuel filter has never been changed. How hard is it to replace? Should I know anything before doing the filter replacement?
shortlid is offline   Reply With Quote
Old 10-17-2002, 07:53 PM   #2
MugenNeuspeed
Member#: 22232
fuel filter is really easy
i am assuming it is the ej22t motor?
PVC can be a bitch to change though
MugenNeuspeed is offline   Reply With Quote
Old 10-17-2002, 08:28 PM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
PCV valve is a lot easier than the fuel filter if the EJ22s is in the same place as the 2.5L
The fuel filter isn't all that hard. Wait and let the car sit overnight to let the pressure in the system bleed down. After you undo the hose clamps you'll need to twist the hose back and forth on the filter to brake it loose. I find this the toughest part. Sometimes it's a bugger to get them free.
How old is your battery? Did it crank over quick or slowly? When it starts getting colder out it will tax an old battery. Just wondering.
Peaty is offline   Reply With Quote
93 legacy hard to start when cold diaper eater Service & Maintenance 3 11-08-2004 09:36 PM
Damn car is stalling and hard to start sometimes! crimedog Service & Maintenance 14 04-21-2003 01:07 PM
Car hard to start the spacecowboy Normally Aspirated with bolt-on Forced Induction Powertrain 0 12-20-2002 01:27 AM
Hard to start ImpreziveTurboWagon Service & Maintenance 2 04-18-2002 02:20 AM
94 Impreza hard to start when hot davy94 Technical Forum Archive 0 10-10-2000 01:21 PM
