Old 10-18-2002, 12:49 PM   #1
2000vfr800
Member#: 15599
Default Intake manifold Gaskets?
I am getting ready to install my STi injectors and Samco turbo inlet hose and it sure looks like it would be easier if I removed the intake manifold.
Question I have is are there any gaskets that would need to be replaced if I remove the manifold?
Thanks!!!
2000vfr800 is offline   Reply With Quote
Old 10-18-2002, 01:01 PM   #2
paul99se
Member#: 17822
Yes, 2 intake manifold gaskets should be replaced. They are cheap, I don't see any reason to risk a problem when the labor to pull the IM is far more than the few $ for the gaskets.
paul99se is offline   Reply With Quote
Old 10-18-2002, 01:16 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
The short answer is yes. This thread has service manual scans which shows an overview of the intake manifold and related parts, as well as removal/installation instructions:
http://forums.nasioc.com/forums/show...hreadid=134006
Any item shown in the diagram with a "star" should be replaced if you expose it during removal.
Jon [in CT] is offline   Reply With Quote
Old 10-18-2002, 01:21 PM   #4
2000vfr800
Member#: 15599
Man...you are my hero.
Thanks a ton. However, I want to do this tonight and none of my local dealers have the gaskets.
So, I don't think I am going to remove the manifold. I'll get the intlet tube and injectors in somehow...
Should I apply gasket sealant on intake manifold gasket? gopsu Newbies & FAQs 0 07-30-2009 11:54 PM
Hondata "heatshield" intake manifold gasket for WRX BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 09-03-2004 06:18 AM
Intake manifold gaskets, to replace or not, plus detonation? IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-02-2003 06:28 PM
TB/intake manifold gaskets or seals? danci1973 Normally Aspirated Powertrain 1 09-29-2002 08:22 AM
Intake manifold gasket whoring around? Puckaveli Normally Aspirated Powertrain 5 07-09-2002 02:54 PM
