Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 04-28-2014, 11:54 AM   #151
Mishimoto
NASIOC Manufacturer
Member#: 207954
Originally Posted by Redeemed77 View Post
Heck yes it would!
Without a tune making 25HP is just bonkers! Where are you going to find 25HP for $300?
Mishmoto, question:
I noticed when I let my Pontiac G8 GT breath better (an engine is essentially a pump) that I actually gained about .5-1mpg along with better sounds and snappier acceleration. Was it a placebo or can an air intake that is helping your engine breath easier in term provide some fuel saving capabilities?
Very excited for my WRX and your products!!! Now....where to find the money...lol
Thanks for the kind words! The intake we designed is very impressive in terms of output, induction noise, and ease of installation.
An intake can certainly result in improved engine efficiency and mileage. Depending on the season, this could have also been a result of temperature change. Often times an aftermarket intake will provide slightly leaner A/F ratios which will result in improved fuel mileage.
We are still hard at work on the 2015 WRX, more updates in the near future.
Originally Posted by aSquard View Post
Subscribing :-)
Thank you!
Mishimoto is offline   Reply With Quote
Old 04-28-2014, 07:45 PM   #152
RTFM
Member#: 389314
2015 WRX
Dark Gray Metallic
Default differential housings
Any idea if the 15WRX differential housings are the same as the old ones?
I'm looking to buy a Quaife helical LSD up front, and do the install before my old car sells.
This link makes it sound like they were all the same in the past
Quaife ATB Helical LSD Differentials - STi, RS, Legacy!, but no one is advertising compatibility with the '15 model year.
RTFM is offline   Reply With Quote
Old 04-29-2014, 12:15 AM   #153
-vanguard-
Member#: 379708
2015 WRX Limited Nav
You guys think you can get the LED C's to light up as the only DRLs for the car?
-vanguard- is offline   Reply With Quote
Old 04-29-2014, 03:07 AM   #154
WestLoopWRX
Member#: 386574
2015 WRX Limited CVT
Red
I would be curious too since I want to do the same.
Rear differentials in the WRX were historically R160's (160mm ring gear) and STIs used an R180. However, it sounds like some of the drivetrain from the STI may now be used on the WRX so it isn't clear what differential the 2015 WRX has (r160 or R180). Unfortunately, the factory service manual does not clear this up either. All it says is the new housings are "B1" or "B2." While "B" housings have usually been R160s, I'm not confident enough to go out and buy a Quaife (or even an OBX + belleville washers). Never mind that we don't know if the new WRX axle stubs are the same as in years past.
WestLoopWRX is offline   Reply With Quote
Old 04-29-2014, 11:36 AM   #155
Mishimoto
NASIOC Manufacturer
Member#: 207954
The rear differential on the 2015 WRX is an R160! We have yet to confirm any information regarding the front differential.
Old 04-29-2014, 11:38 AM   #156
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Such as?
The hubs?
SoapBox is offline   Reply With Quote
Old 04-29-2014, 12:59 PM   #157
MaddMax
Member#: 9264
2012 WRX 5dr
Ice Silver
I'm still trying to figure out how their intake gains 25whp/wtq on a stock tune EJ, much less a tuned one. Has anyone done a third party dyno to verify the claims? I understand the improved readability of the MAF due to the revised channel in the intake, but that won't account for those gains. Sorry for being critical, but I've been down this road MANY times with vendor power claims. Third party before and after dynos are the only way to go, IMO.
MaddMax is offline   Reply With Quote
Old 04-29-2014, 02:02 PM   #158
jonoc4
Member#: 387455
2015 WRX Limited
Crystal White Pearl
so aftermarket rear LSD for previous gen will work on the 15?
jonoc4 is offline   Reply With Quote
Old 04-29-2014, 07:11 PM   #159
Traumlik
Member#: 248805
For the 2015 WRX, how do you suppose a front or rear LSD would change the driving dynamics of the car?
Traumlik is offline   Reply With Quote
Old 04-29-2014, 07:24 PM   #160
Sabo1886
Member#: 388969
Hi guys, I know that the new 2015 WRX is 5x114.3 +55 for the offset. I was wondering if the gold BBS with 115 bolt pattern would fit safely if not is there a kit to change them?
I put a link to the wheels I would like to buy.
http://www.hubcaphaven.com/mm5/merch...egory_Code=753
Sabo1886 is offline   Reply With Quote
Old 04-29-2014, 07:28 PM   #161
Ultimateone
Member#: 48025
15 Mustang GT
Those are stock STI wheels, they will fit
Ultimateone is offline   Reply With Quote
Old 04-29-2014, 07:35 PM   #162
Sabo1886
Member#: 388969
Thank you very much for the information. So even though its a 115mm bolt pattern there is no issues with it fitting correctly on the 2015 hub with out modification?
~Thanks again
Old 04-30-2014, 10:53 AM   #163
Mishimoto
NASIOC Manufacturer
Member#: 207954
Check out our build-thread for the intake on our engineering blog below. This highlights the design and testing process for this particular product and will explain how we managed to pull so much power out of the intake.
http://engineering.mishimoto.com/?cat=85
Thanks
It appears so!
Old 04-30-2014, 01:01 PM   #164
aSquard
Member#: 387864
2005 TF Civic Si
2015 DGM WRX Limited
There is a relay that was unplugged near the horn in the engine bay that accomplishes this and still allows the high-beams to function ::Linky::
aSquard is offline   Reply With Quote
Old 04-30-2014, 01:40 PM   #165
jgut12
Member#: 353036
2015 WRX
CWP
Yeah but this does not make the led c's run as the DRL . I'm waiting for someone to allow the c's to be on while driving around
jgut12 is offline   Reply With Quote
Old 04-30-2014, 01:50 PM   #166
Lminette
Member#: 138923
2000 2.5RS Coupe
Satin Green Metallic
Front LSD's tend to induce understeer so I would think the same would be the case if a front LSD was added to the new WRX. However that understeer could probably be dialed out with some suspension tuning. If anything I'd go for a rear LSD as that will enhance the dynamics of the car.
Lminette is offline   Reply With Quote
Old 04-30-2014, 01:56 PM   #167
Traumlik
Member#: 248805
^^ Thinking out loud here. At the end of the day, minimizing the loss of traction is probably why we want to install LSD in the first place. So it seems like the logical thing to do is to first determine which axle / wheel tends to lose traction first in aggressive driving, and then we slap an LSD on that end, followed by some suspension tuning to adjust the handling behaviour.
Does that sound about right? And if it does, I wonder which end should the LSD go into first...
Old 04-30-2014, 01:56 PM   #168
Traumlik
Member#: 248805
Old 04-30-2014, 02:20 PM   #169
RTFM
Member#: 389314
2015 WRX
Dark Gray Metallic
with a 50/50 bias for power, and the old rule of steering radius vs pedal position for traction, the front should lose traction first in nearly all situations.
Also the torque vectoring via using the brakes only happens on the front wheels of the wrx. An LSD up front should reduce the inner wheel braking often responsible for bogging the engine.
Old 04-30-2014, 02:29 PM   #170
Traumlik
Member#: 248805
^^ Thank you for the simple but crystal clear explanation!
Old 05-01-2014, 01:41 AM   #171
WestLoopWRX
Member#: 386574
Red
When we are talking about the front LSD, we need to be more precise. A torque biasing LSD (e.g. TorSen, Quaife) shouldn't induce understeering since it will do its own equivalent of torque vectoring. Clutch-type LSDs, though, are trouble on the front wheels because they lock the axle, inducing scrubbing and understeer.
Old 05-01-2014, 01:55 AM   #172
WestLoopWRX
Member#: 386574
Red
Originally Posted by SoapBox View Post
Such as?
The hubs?
From page 2:
Sorry, it appears that none of these drivetrain components are compatible with previous generations.
That was why I asked.
So are the rear axles are the same as the 2014 axles? If the splines match up, that would be great!
Old 05-01-2014, 03:15 PM   #173
Mishimoto
NASIOC Manufacturer
Member#: 207954
From page 2:
Thanks for catching this! The rear axles appear to be the same as the 14 WRX, although we cannot confirm 100%. We are hoping to inspect this further soon!
Old 05-01-2014, 05:09 PM   #174
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
I think I know the answer, but is there any chance some vented rotors off of a Legacy would fit on the rears? Or would it require the typical "H6" rear rotors *and* calipers?
MRT in OZ is saying (video) that the vented rear rotors from a BRZ could fit a 2015 rear; swap calipers and rotors & done. if true...
oaklandish_WRX is offline   Reply With Quote
Old 05-01-2014, 05:10 PM   #175
05WrB WRX
Member#: 82019
will 08+ sti brembos bolt up to 2015 wrx?
05WrB WRX is offline   Reply With Quote
