Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 04-17-2014, 02:31 PM   #51
ionoo
Member#: 317035
2015 STI
CWP
To confirm fitment, the dimple mag bolt is M20x1.5, the same as the 2011+ STI platform correct?? Any reason you are running the Prova filter over the OEM one? At oil change intervals of 2500 miles is the added micron filtering necessary?
ionoo is offline   Reply With Quote
Old 04-17-2014, 02:34 PM   #52
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Plugs should be the same, but I will be confirming that in about an hour when I do the oil change.
I personally am not a huge fan on the OEM USDM Subaru oil filter. From Japan they come with a Black Subaru filter which is super high quality and made in Japan, the USDM filters are rumored to be made by FRAM and are not constructed as nice as the JDM OEM filters.
These Prova oil filters are much higher construction quality then the USDM oil filter (almost look to be the same as the JDM OEM Subaru Black oil filters), so we use these PROVA filters or K&N oil filters on all shop cars.
A new motor produces a large amount of material as a result of the motor break in. We feel it is better to change the oil at 1000miles to reduce the amount of contaminants in the oil along with reducing the chance of clogging the oil filter with such debris. It has worked great for us in other shop and employee owned cars, so that is the break in that we procedure that we use.
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 04-17-2014, 03:10 PM   #53
ionoo
Member#: 317035
2015 STI
CWP
What is your oil change interval post break-in out of curiosity?
Old 04-17-2014, 03:19 PM   #54
RallySport Direct
Member#: 33174
We are Open Late!
We will do ever 3K miles or every 6 months.
Given that after break in the cars do not get driven very often (our 2011 STi only had 3300 miles after 2 years) we tend to change the oil due to time interval gap instead of miles.
With that being said, in personal cars I will go about 4-5K between oil changes when using a quality synthetic.
Kirill
Old 04-17-2014, 05:42 PM   #55
RallySport Direct
Member#: 33174
We are Open Late!
TOMEI 2011-2014 STi Sedan Exhaust FITS!
I just confirmed fitment, and there are no clearance or fitment issues
Hope that helps everyone out. We should have some quality images up in the next few days.
Link to the exhaust on our site
http://www.rallysportdirect.com/Tome...atback-Exhaust
Dimple Drain Plug also fit with no issues
Kirill
Old 04-18-2014, 01:19 AM   #56
Mitrofan
Member#: 233468
2008 wrx sti
black wraped in white :)
Kirill
Do Tomei TI exhausts has same issue that i experienced with Invidia n1 on GR hatch when black pretend diffusor on stock bamper was melting up even with carbon heat shields installed so bad that after 1k running i had to cut out nearly 1.5 inch?
Mitrofan is offline   Reply With Quote
Old 04-18-2014, 11:52 AM   #57
ionoo
Member#: 317035
2015 STI
CWP
I ran this exhaust on my 2013 STI with urethane hangers 1 inch from the bumper during auto cross and never experienced this. Titanium handles heat better and the metal is so thin that it disipates much easier than 304SS. Also the exhaust is so light that urethane hangers will stop all exhaust movement so there is slim to no chance it will ever contact the bumper, even under sideways Gs.
Old 04-19-2014, 11:54 AM   #58
RallySport Direct
Member#: 33174
We are Open Late!
The Tomei system uses slip joints and an adjustable clamp on the muffler to position the hanger. Due to all of these adjustments you can easily place the system such that there are no issues with contacting anything.
I also run a TOMEI on my own personal car, and I did install the Urethane hangers. Reason is this system only uses 2 hangers, so by having the UR units the exhaust is not able to move around at all.
Kirill
Old 04-22-2014, 03:30 PM   #59
goldchain69
Member#: 386708
2015 WRX
Dark Grey Metallic
Is this the same car if so can we get some updates on the mods? I found this posted by @stancedsubies on instagram
goldchain69 is offline   Reply With Quote
Old 04-22-2014, 03:33 PM   #60
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
its not real
Celery GT-5 is offline   Reply With Quote
Old 04-22-2014, 04:32 PM   #61
Andrewxxcarlson
Member#: 316415
2006 WRX
Yaaa saw this on IG too, doubt it's by rallysportdirect tho. They haven't gone that far.
Andrewxxcarlson is offline   Reply With Quote
Old 04-22-2014, 04:37 PM   #62
Celery GT-5
Member#: 98210
2002 WRX SRP
its photoshop
Old 04-22-2014, 06:49 PM   #63
mbhammerbro
Member#: 344521
2013 STi
You can see that it looks photoshopped from the front tires.
mbhammerbro is offline   Reply With Quote
Old 04-22-2014, 07:10 PM   #64
BlueMan05
Member#: 129934
2015 STi LE
Wrb
Was thinking the intake may be a bit different on 15 sti do to that sound generator that brings intake sound into car cabin. Aftermarket intake with that will prob sound amazing
BlueMan05 is offline   Reply With Quote
Old 04-22-2014, 10:26 PM   #65
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Can you guys do the question everyone has been asking for?
Swap the headlights with the sti and see if they actually work?
Subie FA20 is offline   Reply With Quote
Old 04-23-2014, 01:04 PM   #66
RallySport Direct
Member#: 33174
We are Open Late!
The housings should swap right over, but the wiring does look completely different on the back of the housings. I would imagine it will work, but would take some custom wiring.
Thanks,
Rick
Old 04-23-2014, 07:15 PM   #67
Moneym3593
Member#: 157376
2015 CWP STI Sedan
Ordered June 3rd, 2014
Any pictures with the tomei exhaust installed? Also will you keep us updated as to what parts will work on the 15 that also work on 11-14.. for example accessport, intake, etc.... thanks
Moneym3593 is offline   Reply With Quote
Old 04-23-2014, 07:37 PM   #68
BlueMan05
Member#: 129934
2015 STi LE
Wrb
Intake is different on 15' sti with the sound tube
Old 04-24-2014, 05:04 PM   #69
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
The generator plumbs into the tube between the airbox and the inlet tube that runs under the manifold. If you swap for an after market intake you have to toss the generator. The inlet tube can be swapped with one from a 2014, and the silencer bottle under the airbox can be removed from the top after taking out the airbox.
Then it sounds better and throttle response is improved.
Generator removal how to with part number for intake for you, or anyone that cares.
2subiesinyard is offline   Reply With Quote
Old 05-07-2014, 02:06 PM   #70
endlesss
Member#: 196720
2015 WRX STI
Dark Gray Metallic
RallySport: Any chance you guys could test fit some 15 or 20mm spacers on these stock wheels? I really like the look of them, just wish they filled out a bit more.. Wondering what the best size to go with is...
endlesss is offline   Reply With Quote
Old 05-08-2014, 06:29 PM   #71
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
Interested as well, please check.
Old 05-12-2014, 03:32 AM   #72
MikeWNc
Member#: 390316
2013 BRZ Limited
Still searching for STI
....The car has a big blind spot on both sides around the rear 1/4 panels, I find myself checking them 2-3 times before I change lanes...
Had an issue like that on my BRZ, I ended up with the (not sure on brand, had a blueish tint to them) wider field of view outside mirror replacements. Will something like help this issue on this car? Even in my BRZ every time I merge or switch lanes I am checking and re-checking due to the rear body lines.
I am also 6'4, 200 and this is the exact car I am finding out about ordering today so I should ride the same in the car as you are describing. I haven't gotten any real seat time in this car. I got to sit in a LE for about 10 min's before it left the dealer to be sold and that's it so I did not get a real sense on the wing or anything else creating blind spots.
MikeWNc is offline   Reply With Quote
Old 05-15-2014, 04:27 PM   #73
RallySport Direct
Member#: 33174
We are Open Late!
Check out the new video of the Perrin Catback exhaust on our 2015 STi!
Thanks,
Rick
Old 05-16-2014, 08:02 PM   #74
RallySport Direct
Member#: 33174
We are Open Late!
Happy Friday!!!! Hope everyone has a great and safe weekend!
Thanks,
Rick
Old 05-20-2014, 09:14 AM   #75
endlesss
Member#: 196720
2015 WRX STI
Dark Gray Metallic
Any chance?
Also, will you guys be carrying the Nameless catback for the 2015? I noticed you only carry the axleback for the 11-14..
