Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 05-12-2014, 03:12 PM   #26
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Originally Posted by Ultimateone View Post
Why are some vendors going so slow on testing parts, you would think you guys would be testing products all day long to get things rolling for the 2015's
I think most companies want to check and double check before they confirm and release products for the new platforms to ensure perfect fitment.
Originally Posted by MikeWNc View Post
Can't wait to see what you guys are going to do with these. Having a BRZ now I know how fast it seems that tons of options came to market for coilovers, wheels, etc. I am new to the Impreza/WRX world, does it look like currently available products for this platform will work or will require wait times to make new one's? Personally I hate the tail lights. Are companies working on things like that already? Just wondering if you and other vendors are hearing support like this is already in the works for this body style?
Thanks! I have nor personally seen any new tailights for the new body style, but I can't imagine new products like this being too much further down the line. I know for the BRZ it was about 6 months before we started to see a decent selection of aftermarket parts for the new platform.
Originally Posted by documentarian View Post
Hey Rick,
I am loving the write up on both of your guys' cars so far. I apologize for the slew of questions but I haven't seen an update from you guys some days now so I'm just wondering how things are going.
How has the WRX been performing as of late? Are you still as happy about the car as you were early-mid April?
Have any things cropped up recently which you consider to be annoyances or things that you do not particularly like about the car?
Have you been able to go over the break-in period yet? If so, how does the car feel/perform above 4k?
Thank you guys! Please keep up all the excellent work!
It's been crazy busy around here, but soon you should start seeing regular updates, as we do have some things in the works And I am still loving this car. I actually had the change to take the STi out for awhile and I am so impressed with the new FA engine in the WRX, as well as the chassis in both cars. The STi does feel more manly with the heavier and quicker steering, but both cars feel so much better than the previous generations. I'm still having a hard time not buying one lol.
The only thing I did not like about the WRX was the super-low RPM power, but it seems like since it has been broken in, that has been much less apparent, but I do notice it. Not near as bad as when the car was new.
And yes, both care are 100% broken in so we have been able to have some real fun with them. I took both for a cruise up our local canyons and was all smiles the entire way.
Thanks guys!
Rick
RallySport Direct is offline   Reply With Quote
Old 05-14-2014, 05:58 PM   #27
RallySport Direct
Member#: 33174
We are Open Late!
Hey guys,
We installed the Tomei Titanium Catback on our 2015 WRX and it looks great and sounds even better. Check out the video below
Thanks,
Rick
Old 05-14-2014, 08:20 PM   #28
JustinTimeBoost
Member#: 389296
2015 WRX Limited 6MT
ISM
This is the best sounding exhaust I've heard on the 2015 yet.
JustinTimeBoost is offline   Reply With Quote
Old 05-15-2014, 12:16 PM   #29
Sinsear
Member#: 373908
2015 WRX
Pearl White
Originally Posted by RallySport Direct View Post
Hey guys,
http://youtu.be/a7lO9RTpZ5U
Thanks,
Rick
So I'm assuming you guys have yet to update your website so that the Tomei exhaust shows up when you select the '15 WRX as your vehicle?
Also, is it a perfect fit, or did you guys have to finagle it to get it to work?
Sinsear is offline   Reply With Quote
Old 05-15-2014, 01:43 PM   #30
RallySport Direct
Member#: 33174
We are Open Late!
Correct, the website will be update here very soon And it is a 100% direct bolt on with no modifications needed.
Thanks,
Rick
Old 05-15-2014, 01:44 PM   #31
JustinTimeBoost
Member#: 389296
ISM
They said no modifications were required to make it fit in their other thread.
Old 05-15-2014, 01:44 PM   #32
RallySport Direct
Member#: 33174
We are Open Late!
The sweet little WRX is all broken in and it’s time for its first mod, and what is that you ask? And oil change! Okay, not exactly a modification, but it excites me all the same as this is our first step before we start the real modifications.
Those with a BRZ/FR-S will be very familiar with changing the WRX’s oil, and really this is one of the easiest oil changes I have ever done. Let’s get started!
What we used:
5.4 Quarts of Penrite Racing 5W30 oil
Prova Oil Filter
Dimple Magnetic Drain Plug M16x1.5x12
Note* if re-using your factory drain plug, make sure to pick up a new crush gasket for it
Tools needed:
14mm wrench
15mm wrench (required for new Dimple Drain Plug)
Oil Filter Wrench (not usually required, but someone at the factory ate their Wheaties that morning)
Clean Funnel
A few rags or paper towels
First I like to remove the oil fill cap, this helps the oil drain a bit quicker when you remove the drain plug.
Now get under the car, and get your 14mm wrench, you will see the drain plug exposed at the bottom of the pan, horray for nothing covering the drain plug!
Place your oil drop pan/catch under the drain plug and you will need to use a bit of force to remove the drain plug as it seems like Subaru paints over these and employs He-Man to torque these down.
Let all of the oil drain, clean the drain plug, apply the new crush gasket and thread it back into the oil pan. Don’t quote me on this yet, but the Torque specs should be 30.8 ft-lb for the oil drain plug. We used the Dimple drain plug, which required a 15mm wrench.
Now we move to the top of the engine. You will see the oil filter is incredibly easy to get to. We had to use a filter wrench to remove it, but normally you can get these off by hand. Once removed, I like to clean up any oil on the top of the oil cooler.
Make sure to lubricate the O-ring on the new filter, once done we can install the new filter with a toque spec of 10.3 ft-lb(Black OEM Filter) or 8.9 ft-lb(Blue OEM filter), but I always go off the German standard “GuttenTight” which is roughly hand tight plus about turn.
Use a clean funnel and pour in 5.4 quarts of oil. Put on the oil cap, start up the car, and make sure the oil light on the dash turns off. Get out of the car and visibly check for any leaks. Shut down the car, and check the dipstick to make sure the oil level is correct. Is it? Yay!
You've just completed your first oil change on your new WRX. Not only will your friends be impressed, but the car will now have more respect for you as well. Now go enjoy the car with a nice drive!
Thanks,
Rick
Old 05-15-2014, 04:46 PM   #33
Sinsear
Member#: 373908
2015 WRX
Pearl White
Are there other Tomei Ti exhausts that fit on the '15 WRX? For example, on the BRZ/FRS, there are three different versions of exhausts, which have different amounts of flow and muffler deletes.
Old 05-15-2014, 04:48 PM   #34
Sinsear
Member#: 373908
2015 WRX
Pearl White
True, but their other thread is for the '15 STI, not WRX. Hence I wanted to make sure.
Old 05-16-2014, 07:54 PM   #35
RallySport Direct
Member#: 33174
We are Open Late!
Happy Friday! Hope everyone has a great weekend! Enjoy this picture from last weekend at our annual RallysportDirect.com Car Meet.
Thanks,
Rick
Old 05-16-2014, 11:51 PM   #36
documentarian
Member#: 382402
Awesome write up! And that exhaust sounds great! Loving the updates!
documentarian is offline   Reply With Quote
Old 05-19-2014, 03:35 PM   #37
RallySport Direct
Member#: 33174
We are Open Late!
Thanks!
Rick
Old 05-19-2014, 09:45 PM   #38
TheRoyalDoyle
Member#: 391161
Cant wait till this is a monster
TheRoyalDoyle is offline   Reply With Quote
Old 05-19-2014, 10:24 PM   #39
cmejatt
Member#: 389886
nice write up
cmejatt is offline   Reply With Quote
Old 05-21-2014, 12:26 PM   #40
RallySport Direct
Member#: 33174
We are Open Late!
Thanks guys! And make sure to check out this video of my review of both the WRX and the STi Sometimes my job is really really awesome!
Thanks,
Rick
Old 05-21-2014, 03:20 PM   #41
08Legacy-GT
Member#: 325949
http://youtu.be/ZEUGYnjePsQ
Thanks,
Rick
"It's just really stiff"
Hey you're the dork in all the pictures! you do exist!!
08Legacy-GT is offline   Reply With Quote
Old 05-21-2014, 03:53 PM   #42
RallySport Direct
Member#: 33174
We are Open Late!
HAHA Yes! I actually do most of our videos such as the What's in the Box series, but do expect to see more of me and this smiling face in our future videos. I can't wait to get back out there and make some more videos for you guys.
Oh and yes, I wear my dork badge with pride
Thanks,
Rick
Old 05-21-2014, 04:02 PM   #43
08Legacy-GT
Member#: 325949
Thanks,
Rick
I think your picture from the chat window should be the default avatar/profile picture for RSD. Just saying !
Old 05-21-2014, 07:44 PM   #44
RallySport Direct
Member#: 33174
We are Open Late!
I agree 100%
Rick
Old 05-28-2014, 02:05 PM   #45
RallySport Direct
Member#: 33174
We are Open Late!
Edited
Old 05-28-2014, 09:33 PM   #46
Brandon2k13
Member#: 376571
I drive a car,
and I quite like it.
^ I like it!
Brandon2k13 is offline   Reply With Quote
Old 05-29-2014, 02:44 AM   #47
Hoon_2013
Member#: 390879
2015 WRX
The tomei sounded much better than the perrin.
Hoon_2013 is offline   Reply With Quote
Old 05-29-2014, 08:54 AM   #48
Aphex28
Member#: 11506
2015 WRX
I like the quieter volume & look of the perrin, but the tomei does sound better.
Aphex28 is offline   Reply With Quote
Old 05-29-2014, 09:49 AM   #49
italianmafia070
Member#: 196111
2015 WRX
CWP
Subaru does recommend 5w30 for this car.......
italianmafia070 is offline   Reply With Quote
Old 05-29-2014, 10:17 AM   #50
Aphex28
Member#: 11506
2015 WRX
Just kidding! I lose this internet argument! Mixed my oil cap up with my brother's.
