Old 04-12-2014, 05:36 PM   #26
Noone99
Member#: 217245
2015 WRX
Red
I had talked to wheeldude a few weeks ago. One of the teams they sponsor has a STI on order and planned on running 18x9.5 +38.
But they were still waiting on someone to bring a actual car in to take measurements
Noone99 is offline   Reply With Quote
Old 04-12-2014, 08:53 PM   #27
sc00by4life
Member#: 97135
Originally Posted by RavSpec View Post
Confirmed fitment , best with spring drop 18x9.5 +38
Originally Posted by DrDanimalSize View Post
also in for what tire size
x345.
Old 04-12-2014, 10:24 PM   #28
How168
Member#: 387574
What is the wheel offset of 2015 wrx? I've heard 48, 45, even 53?
How168 is offline   Reply With Quote
Old 04-12-2014, 10:51 PM   #29
NIL8GM428
Member#: 126558
2015 WRX
ISM
Offset is 55 for the WRX
NIL8GM428 is offline   Reply With Quote
Old 04-13-2014, 10:51 AM   #30
mysterybus
Member#: 123041
2011 sti
About the 2015 Sti base wheels...
has anyone pulled one off (dark grey wheels) and checked if its an Enkei MAT wheel? My 2011 Sti wheels are. I expect the offset is still 55. Anyone done this yet?
mysterybus is offline   Reply With Quote
Old 04-14-2014, 04:39 AM   #31
Scino
Member#: 381623
2015 Subaru WRX
I want Kojin 18x9.5 et30, but I think I will go with Raijin 18x9.5 et35 to avoid more work. I'm new the low offset thing, can anyone tell me what should be done on both set ups? I just want to drop it on lowering springs, something like RCE black.
Scino is offline   Reply With Quote
Old 04-14-2014, 11:13 AM   #32
sc00by4life
Member#: 97135
This is a brand new chassis. There isn't much information, but for a 9.5" wheel any offset north if 40 shouldn't be too difficult and will give you more flexibility in tire sizing.
Old 04-14-2014, 04:29 PM   #33
Scino
Member#: 381623
2015 Subaru WRX
I also think that et40 wouldn't be bad, but the wheel I want is highest at et35. I don't want to get rfp1 et38 like every other Joe.
Old 04-14-2014, 04:50 PM   #34
cannon98
Member#: 187775
16 Sti
CWP
What about 17x9 35 or 17x9 45 with stock tires 235/45/17? would these clear with NO modifications ?
cannon98 is offline   Reply With Quote
Old 04-14-2014, 06:36 PM   #35
willimprez
Member#: 91655
15 STI
CWP
While out at a client's place today had a chance to test fit his wheels.
Rota G-force
18x8.5
Offset 48
Tires : Yoko s drives 255/35/18
There isn't as much space as I was hoping for.
I think I'm going to try 18x9 et38 & 245/40/18 but I'm expecting some clearance issues.
willimprez is offline   Reply With Quote
Old 04-14-2014, 07:13 PM   #36
Scoob1318
Member#: 352140
2015 WRX
Once you start lowering the car those wheels will tuck in more. Several people have test fitted 18x9.5 and 10. This will all change when coilovers and suspension options come out
Scoob1318 is offline   Reply With Quote
Old 04-14-2014, 09:19 PM   #37
sc00by4life
Member#: 97135
You'll gain camber but the wheels won't "tuck in more".
Old 04-14-2014, 10:56 PM   #38
Scoob1318
Member#: 352140
2015 WRX
What do you think camber does?
Old 04-15-2014, 06:27 AM   #39
sc00by4life
Member#: 97135
for starters, it doesn't "suck the wheels in". the wheel stays in the same place.
and the amount of clearance you'll gain from OEM camber adjustment isn't much at all, in addition to the natural camber needed from a drop.
see how even narrower fitments with properly sized tires that normally wouldn't need fender modification, DO need modification once you start to lower the car.
Old 04-15-2014, 10:35 AM   #40
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Looks great
Completely off topic
Can you post a picture of your headlights with just the led lights on at night to show what it looks with an led bulb?
Rota G-force
18x8.5
Offset 48
Subie FA20 is offline   Reply With Quote
Old 04-15-2014, 11:14 AM   #41
willimprez
Member#: 91655
15 STI
CWP
Old 04-15-2014, 11:26 AM   #42
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Yeah I checked out the gallery on Facebook. Do you have any shots from like 15 feet away from the car at night time?
Fanx!
Old 04-15-2014, 12:39 PM   #43
AFP520
Member#: 102932
2014 STI Sedan
Yes. http://forums.nasioc.com/forums/show...&postcount=267
AFP520 is offline   Reply With Quote
Old 04-15-2014, 02:22 PM   #44
Its Twix
Member#: 345242
'15 LE WRX ordered
WiIl 18 x 9 55 fit without rolling and still be able to be flush with the body? I saw a new WRX with 18 x 8.75 33 and they stuck out too much for my liking. Sorry for the noob question, I just don't know how much offset affects the look. I read the Wheel FAQ and it doesn't really touch on this.
Its Twix is offline   Reply With Quote
Old 04-16-2014, 01:13 AM   #45
NIL8GM428
Member#: 126558
2015 WRX
ISM
Here is a good wheel/tire comparison calculator. Might add some clarity to how offset works.
http://www.rimsntires.com/specspro.jsp
Old 04-16-2014, 01:47 AM   #46
Its Twix
Member#: 345242
'15 LE WRX ordered
Got it! So by moving the offset lower you're able to go wider without problems because it moves the mounting pad closer to where the mounting pad would be with the stock size and offset.
Guess no 18 x 9 OZ Ultraleggaras for me then. Bummer!
Thanks for your help!
Old 04-16-2014, 09:34 AM   #47
cannon98
Member#: 187775
16 Sti
CWP
17x9 45 enkei rpf1 stock suspension clears brakes barely
17x8 45 enkei rpf1 stock suspension clears
Old 04-17-2014, 12:18 AM   #48
willimprez
Member#: 91655
15 STI
CWP
Picked these up today , not aftermarket but still quite happy with the way it looks.
Thinking 5mm spacers will bring them out just enough. :wink:
Old 04-17-2014, 12:26 AM   #49
NIL8GM428
Member#: 126558
2015 WRX
ISM
Looks good Will. What size wheels/tires/offset?? I pick up my new silver WRX next Wednesday from Ottos. Cant wait.
Old 04-17-2014, 01:33 AM   #50
shippy1
Member#: 7070
I'm kind of liking the look of enkei tsp6 in hyper silver for silver 15. Thinking 18x8.5 with 50 mm offset with 245/40 tires. How do you guys think they will match up with stock ride height. 235 tire change look? Not looking for any rim poke.
shippy1 is offline   Reply With Quote
