Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 04-17-2014, 08:11 AM   #51
HMJBurner
Member#: 295809
2015 WRX Premium
How would running 245/40 tires on the stock 17x8 WRX wheels be? I'm keeping my snow tires instead of the stock summers since I still need them here for CO. I want to order a new set of summers.
HMJBurner is offline   Reply With Quote
Old 04-17-2014, 09:30 AM   #52
RavSpec
NASIOC Storefront Vendor
Member#: 26854
2002 Impreza
WRX
Just finished !! Rays gramslight 57c6 18x9.5 with 255/35 tires at NYIAS show now.
2015 STI launch edition
Come see us !! http://instagram.com/p/m5IHWjmSWk/
RavSpec is offline   Reply With Quote
Old 04-17-2014, 10:43 AM   #53
jgut12
Member#: 353036
2015 WRX
CWP
What offset are those?! Look amazing!
jgut12 is offline   Reply With Quote
Old 04-17-2014, 10:50 AM   #54
cannon98
Member#: 187775
15 Wrx
Crystal White Pearl
looks great! what drop is that ?
cannon98 is offline   Reply With Quote
Old 04-17-2014, 03:46 PM   #55
cannon98
Member#: 187775
15 Wrx
Crystal White Pearl
test fitted 18x9.5 38 work XT7 with 245/40/18 and it cleared
Old 04-17-2014, 03:55 PM   #56
jgut12
Member#: 353036
2015 WRX
CWP
Pics or it didn't happen! Lol
Also - do you think a lower offset like a 18x8.75 +20 would work too?
Old 04-17-2014, 04:11 PM   #57
Ultimateone
Member#: 48025
15 Mustang EB
9.5 38et probably will be the best fittment just like the GR but obviously we can push the limits with some fender rolling and coils etc
Ultimateone is offline   Reply With Quote
Old 04-17-2014, 04:34 PM   #58
jgut12
Member#: 353036
2015 WRX
CWP
Just used this calculator and seems like the +20 offset will just poke 10mm more than the above wheel http://www.willtheyfit.com/index.php...et2=20#content
Old 04-17-2014, 05:31 PM   #59
RavSpec
Member#: 26854
2002 Impreza
WRX
18x9.5 +38 / 255/35 tires
Old 04-17-2014, 05:49 PM   #60
Scoob1318
Member#: 352140
^What are you guys dropped on? Any fender modifications?
Scoob1318 is offline   Reply With Quote
Old 04-17-2014, 07:53 PM   #61
Sinsear
Member#: 373908
2015 WRX
Pearl White
Originally Posted by NIL8GM428 View Post
Offset is 53 for the WRX
http://forums.nasioc.com/forums/show...&postcount=271
According to that post, the stock ET is 55.
Sinsear is offline   Reply With Quote
Old 04-17-2014, 08:05 PM   #62
Sinsear
Member#: 373908
2015 WRX
Pearl White
I'm thinking of running 19x9.5" +42 ET RPF-1's on 265/30R19's: http://goo.gl/SwrAKJ
May have to roll the fenders a bit with that setup. The stock fenders can accommodate approximately an extra inch of width, so an extra 1.26" will be pushing it without any fender rolling.
The additional 6mm of inset is practically negligible; if it becomes an issue, I can add a 5mm spacer.
Old 04-18-2014, 03:40 PM   #63
arfrce
Member#: 126130
06 Subaru STi
So basically. For say 265x40x18 roll it , and may need a 5mm spacer?
arfrce is offline   Reply With Quote
Old 04-18-2014, 04:16 PM   #64
NIL8GM428
Member#: 126558
2015 WRX
ISM
265/40 18 would be a tall tire. I would think a 265/35 18 would be better suited. All speculation at this point though.
NIL8GM428 is offline   Reply With Quote
Old 04-19-2014, 01:18 AM   #65
Sinsear
Member#: 373908
2015 WRX
Pearl White
Actually, I think I settled on 18 x 9.5". Time to go to Discount Tire and do some fitment tests. I'm curious whether +38 ET or +45 ET will result in a better fit.
Old 04-21-2014, 12:50 AM   #66
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Good little vid I found on youtube:
https://www.youtube.com/watch?v=rLo-pMVgRks
DrDanimalSize is offline   Reply With Quote
Old 04-21-2014, 03:39 PM   #67
Sinsear
Member#: 373908
2015 WRX
Pearl White
Did some test fitting at Discount Tire. 18x9.5" ET+45 fits very well and looks spectacular. ET+38 will require some serious fender rolling (especially if you lower the car).
Purchased some black Enkei PF01's 18x9.5" ET+45 with Michelin Pilot Super Sport 265/35R18 tires. Looking forward to everything arriving by the end of this week/early next week.
Decided on the PF01's rather than RPF1's to allow for greater brake caliper clearance and larger rotors. The RPF-1's should clear the stock brakes, but if you ever decide to upgrade to high-end Brembo's or StopTech's at any point, RPF-1's won't clear (unless you install a massive spacer, in the 15-20mm range).
Old 04-21-2014, 04:19 PM   #68
Scoob1318
Member#: 352140
When you were test fitting the wheels, were you testing it with a tire on or just the wheel?
Old 04-21-2014, 05:57 PM   #69
Sinsear
Member#: 373908
2015 WRX
Pearl White
Tire + wheel.
Old 04-21-2014, 06:21 PM   #70
Ultimateone
Member#: 48025
15 Mustang EB
Seems the Rays on the RavSpec fit without any rolling or pulling with their coilover setup, 38et is hardly super aggressive
Old 04-21-2014, 06:41 PM   #71
Scoob1318
Member#: 352140
I was thinking the same thing... I think they also test fit 18x10 +20
Old 04-21-2014, 07:51 PM   #72
NIL8GM428
Member#: 126558
2015 WRX
ISM
Great! You just made my wheel choices just that much more complicated...lol. Thought for sure I was getting 18 x 8.5's.....now not so sure. So are you saying that et45 would not require any fender rolling? Would love to see some pics as soon as you get your set up on.
Old 04-21-2014, 11:13 PM   #73
Sinsear
Member#: 373908
2015 WRX
Pearl White
Yes, they did install 18x9.5" ET+38, but judging by the photos, unless the suspension has 1mm of travel, you're going to destroy your tires on the street with the setup that they're running. Keep in mind that they have a show car. Fitting some wheels and tires into a car that doesn't move and stays on a carpeted floor is very different than a daily driver for street use.
Old 04-21-2014, 11:19 PM   #74
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
So your saying Sinsear that 18x9.5 +38 will destroy the tires? or the 18x10 +22's would destroy the tires?
I'm wondering if it would be even possible to run the 18x10 +22's with a 275/40/18 rubber without having to run insane camber to make it fit (even with a full fender roll)... Not to mention running lowered springs or lowered coilovers.
spyrule is offline   Reply With Quote
Old 04-21-2014, 11:21 PM   #75
Sinsear
Member#: 373908
2015 WRX
Pearl White
If you want to do that setup, it'd be way easier to get a wide-body kit. Wait 6 months and somebody will surely have one.
