Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 10-14-2000, 04:56 PM   #1
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Question 0-60mph times for high altitude
Guys,
I've got a 99 auto RS and when I time my 0-60mph I average 10secs! What is up with that? I'm not power braking just jammin' the pedal until 60. I've tried this with JC's intake and I get 11 secs. Tried my own DIY intake and got 11 secs. Put the stock back on and I get 10 secs. Can I knock a second off cuz of the high alt.? I replaced the plugs and fuel filter thinking that was causing my high times. No dice... still the same. *sigh*
spshultz is offline   Reply With Quote
Old 10-14-2000, 06:26 PM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
My MY00 with 5 speed ran a 8.98 on g-tech pro on my second try, although using a stop watch I had obtained an 8.2 once. All I had on it when I did this this week was a Larry's cold air intake - NO exhaust mods at the time.
After only 4-5 more tries, the best I could manage was an 8.38 second, which I am told would be a tad under 7.4 - 7.5 seconds at sea level. This was with under 3,000 rpm launches because I have a freshly rebuilt tranny I don't want to hurt.
I suspect your 0-60 time suffers because of loss of torque, and an UD pulley would help, and certainly an AFC will help if you don't have one for your MY99.
Larry
[This message has been edited by ImprezaRS dot com (edited October 14, 2000).]
ImprezaRS dot com is offline   Reply With Quote
Old 10-14-2000, 07:00 PM   #3
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Post
Thanks Larry. Yeah, the AFC has been hot on my mind. I'm thinking that with AFC the JC intake should really help the car come alive.
But, Kevin mentioned cams one day and now all I can think of is JC Cams and AFC w/JC intake. Add a larger throttle body and those new borla headers (unless JC's finally gets theirs done) and it should make for a nice HP improvement in my auto. (already have the Stromung dual w/mid pipe).
I wish I had more money!!
Shawn
Old 10-15-2000, 02:01 AM   #4
JC SPORTS
Guest
Member#:
Post
Shawn, did you shift the trans manually or just put it in "D"? Make sure you got the slack out of your throttle cable at the pivot point or try the high volume fuel pump along with the S-AFC. Maybe one of these will help decrease your 0-60 times.
Kevin
Old 10-15-2000, 07:59 AM   #5
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Post
Kevin,
Yeah, just "D". It shifted into 2nd @ 6K and then into 3rd @ 5K. Never made it to "OD" before I hit 60mph. But, something I've noticed recently is that if I bring the gas down a bit from WOT I can feel the car pick up a little. Why is this? Is it to lean @ WOT?
Shawn
Cobb Stage 1 0-60mph Time f4phantomii Proven Power Bragging 12 01-20-2005 09:57 AM
post your best 0-60mph times streetspanker Proven Power Bragging 16 09-29-2003 02:05 PM
0-60MPH time on 92 Legacy turbo!! Ben Legacy Forum 1 04-02-2001 07:20 PM
0-60mph time on 92 Legacy turbo!!! Ben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-02-2001 05:55 PM
Mile high 0-60mph times? spshultz Rocky Mountains Impreza Club Forum -- RMIC 1 11-19-2000 06:19 PM
