Old 10-20-2002, 06:35 AM   #1
curvie
Member#: 11381
2008 sti
aw
Default LINK users...
Hello everybody,
Was just wondering what egt's you guys were getting during highway cruising? I just installed the Link and roughly tuned it to the best of my ability and knowledge. However, I think i'm running a bit rich, as my egt's are lower than what I'm used to seeing with the stock ecu..
Cruising along the highway at around 70mph... I see egt's of 550-690 celcius...
On another note... I was wondering if anybody knew who made a "bell-mouth" JDM downpipe for the wrx? Been trying to located one to mate with the SR series turbo and kakimoto gt1.0z exhaust. Any help would be appreciated!
cheers,
Victor
curvie is offline   Reply With Quote
Old 10-20-2002, 09:19 AM   #2
teiva-boy
Member#: 22825
Try a Cusco downpipe.
teiva-boy is offline   Reply With Quote
Old 10-20-2002, 12:00 PM   #3
Delicious Tuning
Member#: 1990
You are definitely running on the rich side. While cruising on the highway, you should be able to lower your fuel quite a bit.
On my RS-T my O2 (narrow band) sensor doesn't even go into the rich area at all, it always says lean. You are not always going to run in the rich area, as this would not really make sense. The stock O2 sensor you are using is not the best source for tuning highway driving. With enough tuning time, you can figure out where the fuel levels are suppose to be at cruising highway speeds.
Delicious Tuning is offline   Reply With Quote
Old 10-20-2002, 06:33 PM   #4
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Where is your EGT probe?
-Chav
Chav is offline   Reply With Quote
Old 10-20-2002, 08:08 PM   #5
Delicious Tuning
Member#: 1990
Yeah where is your EGT probe tapped in? Sometimes my mind just wanders, got to think simple first.
Old 10-20-2002, 10:03 PM   #6
curvie
Member#: 11381
2008 sti
aw
Thanks for the responses.
I have the egt probe tapped in the downpipe right after the turbo... Godspeed JDM downpipe.
Thanks,
Victor
Ps. Skywalker, I emailed you.
Old 10-21-2002, 04:32 AM   #7
HubbieScooby
Member#: 7088
Super Slow
hey skywalker
i also e-mailed you...did you get it??
hugh
HubbieScooby is offline   Reply With Quote
Old 10-21-2002, 12:40 PM   #8
Delicious Tuning
Member#: 1990
Thumbs up
Got them and will respond shortley.
Cheers,
Bill
Old 10-21-2002, 12:52 PM   #9
RS_NW
Member#: 2301
What are you using for a narrow band?
RS_NW is offline   Reply With Quote
Old 10-21-2002, 02:12 PM   #10
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default 2-3" off #3 port
At 2900Rpm's and 65mph (I add that because it changes with mph, even if the Rpm's are the same)I'm at 1450` or so. A/F is where it should be, using a GM O2 sensor off a 95 Camaro after the turbo. 2.5RSt
milkman is offline   Reply With Quote
Old 10-21-2002, 05:24 PM   #11
Delicious Tuning
Member#: 1990
I am using the OEM Stock O2 sensor. At cruising speeds on the highway I have no reading on the O2 stock sensor. My engine temps are reading ~1375 at 3500 RPM's and 75 Mph. My gas milage on the highway is about 28 miles per gallon. Around town with lots of stop and go traffic (with some boosting at 10 PSI), I get about 20 miles per gallon.
I know the O2 sensor is reading because every morning I get up turn the car on and watch the O2 readings slowly rise as the car warms up. I have noticed with my stock O2 sensor anytime the readings get in the high to middle part of stoich the readings, the value will drop off to 0, this is during normal daily driving with no boost. Under boost of course the car is running a little rich as it should be.
Dual fans for Link+ users... WRX 555 STi Normally Aspirated with bolt-on Forced Induction Powertrain 18 08-24-2004 03:59 PM
New Link user some ???'s mr2guru Engine Management & Tuning 10 08-10-2003 03:31 PM
Link users (cold start answers?) Soon2Bgreat Engine Management & Tuning 15 05-07-2003 03:27 PM
Any link users? mrtrex Tri-State Area Forum 1 08-12-2002 11:15 AM
Link users-What are good cruise egt's? paulw Engine Management & Tuning 3 07-29-2002 05:07 PM
