Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 05-02-2014, 10:34 PM   #26
sebhockey
Member#: 138957
2016 WRX STI Limited
Originally Posted by Silver15wrx View Post
I haven't tried to reassign the Call buttons yet, just haven't had time. Yea it seems as though everyone seems to be getting that message. Strange that you don't, if you happen to find out why by all means let me know!!
Looks like SVXdc already found the answer with the Foresters, found while googling it.
You just need to temporarily disconnect power, to reset your MFD (to make it forget it had ever seen your factory HU). You can do that by any of these methods:
Unplug the power harness from the MFD
Disconnect the fuse for that harness, #15 (I think that's on the fuse block inside the cabin, but don't yet have the full service manual. Can someone else confirm?)
Disconnect the negative terminal from your car's battery
If you don't want to open up the MFD (which really isn't that hard), I'd go with method "B", so you don't reset everything else in the car (such as your ECU).
Makes sense, because I had my battery disconnected while I installed everything.
sebhockey is offline   Reply With Quote
Old 05-02-2014, 11:13 PM   #27
Silver15wrx
Member#: 388403
2015 Wrx
Ice Silver
Awesome I'll try it this weekend!!! Good to know!
Silver15wrx is offline   Reply With Quote
Old 05-04-2014, 11:50 AM   #28
Redeemed77
Member#: 378138
2015 WRX
CWP
Default Please be kind to newbs...lol
Well, all I have is time before my WRX gets here so I decided to start collecting mods and/or parts needed for the mods along with installation details. Rims and tires are pretty straight forward while the TPMS is something I still have to research, part number, best price, etc.
After reading the great post by BuckiWRX and ae64.com's parts needed web page...
http://ae64.com/aftermarket-HU-insta...Impreza-BT.htm
As far as this thread is concerned, and forgive my many questions but I have NEVER installed a aftermarket radio myself of this complexity...at least superficially, with steering wheel controls, integration with existing OEM inputs, etc etc
My goal is to NOT cut ANY wires...is that possible?
How does my list look, am I missing anything? Please continue reading my list so you can point out things I might be missing.
1) HU PIONEER AVH-4000NEX
What's in the box:
2) Mounting Bracket for aftermarket HU & OEM plug
When I had my 2011 WRX I ordered this years ago and at this point I don't have all the details but does this look like the 20 pin connector I will need?
UPDATE: Based on the picture I will need a new plug because mine is missing the SWC wires, BuckiWRX mentioned in his post:
http://ae64.com/20-pinfwdharness.htm
3) Metra ASWC-1 steering wheel
http://www.ebay.com/itm/181363549622...84.m1497.l2649
4) Parking break bypass
When I take trips I want the ability to stream TV/DVD for my boys
http://www.ebay.com/itm/251511635963...84.m1497.l2649
5) iPhone Pioneer adapter CD-IH202 & Apple Lightning to AV adapter
I can't believe they nickel and dime you with this.
http://www.ebay.com/itm/321379590324...84.m1497.l2649
http://www.ebay.com/itm/111305217355...84.m1497.l2649
6) Axxess AX-TOYUSB
To retain the center storage USB.
http://www.ebay.com/itm/321350474955...84.m1497.l2649
7) Tools? Remember I'm a newb...
I think that's it, please share your thoughts.
Redeemed77 is offline   Reply With Quote
Old 05-04-2014, 11:56 AM   #29
Redeemed77
Member#: 378138
2015 WRX
CWP
BTW: How do I get a hold of SVXdc? He does not allow PM's on NASIOC???
EDIT: Disregard, found it on his website.
Old 05-04-2014, 02:16 PM   #30
Mrlaigle
Member#: 357654
2015 WRX
Waiting to go in my 15 when it's delivered.
Thanks to SVXdc for knowledge and selling me the pass through harness and USB adaptors.
Mrlaigle is offline   Reply With Quote
Old 05-04-2014, 03:22 PM   #31
sebhockey
Member#: 138957
What's in the box: http://youtu.be/16JgX6z8Mhs
6) Axxess AX-TOYUSB
Definately possible to not cut any wires, I did not cut any with my install. You will need a different mounting bracket Metra 99-8905B or Scosche 2029B for the dash. You may need to trim to fit slightly. Your 20 pin connector from you 2011 will work. If you don't have the extra wires added for steering wheel controls you will have to add them, splice into the harness, or buy one from SVXdc.
Get yourself a set of plastic trim panel tools, the panels in this car are tighter than in the past and you don't want to scratch them up. They will pay for themselves whether you go cheap or expensive. Beyond that, tool wise depends on your comfort level, soldering iron or crimp tools as both has their ups and downs. I would suggest crimping if you are a newbie to electronics, just remember to get the right size butt splices for the gauge wire and tug on the wires slightly to make sure it's a good crimp.
Old 05-04-2014, 04:39 PM   #32
Redeemed77
Member#: 378138
2015 WRX
CWP
Thanks sebhokey!
Old 05-04-2014, 05:55 PM   #33
BuckiWRX
Member#: 294409
2016 Econobox Turbo
Rock Chip Pearl
Google avic411 and go to the NEX subforum. They have a very easy mod for the parking brake bypass without using any ebay stuff. I have an NEX receiver and it worked flawlessly. Good luck with the install!
BuckiWRX is offline   Reply With Quote
Old 05-04-2014, 09:53 PM   #34
Redeemed77
Member#: 378138
2015 WRX
CWP
Thanks, a new forum to learn from...THANKS!
Old 05-04-2014, 10:18 PM   #35
Schmidtzngiggles
Member#: 384073
2015 STI Limited
Ice Silver Metallic
Originally Posted by intence01 View Post
Did the text naming get retained in the upper dash display (the one with the boost gauge). Is there anything that didn't work? I'm debating on whether to just swap speakers, or do the headunit as well If everything works, getting a better headunit would be a great option.
Hangup button and the voice activation button doesnt work. Lose the text on the top HUD but im happy because i use it for other things now.
Schmidtzngiggles is offline   Reply With Quote
Old 05-05-2014, 03:32 PM   #36
martialbob
Member#: 387487
2015 WRX Limited
WR Blue
I'm starting my Head Unit Swap project in my 2015 Subaru WRX. I pick the car up in a week and a half but already gathering parts. I'll give updates as I start the install in a few weeks.
http://www.ctsubaru.com/forum/showthread.php?t=11246
just realized you can't view CTSubaru without being a member. Posting my thread below
First off, this video is my end goal.
End Goal Video
Stuff you need for the 2015 WRX head unit swap:
Head Unit
Appradio 3 - $350
Pioneer App Radio Head Unit
SWC Module SWC Module
$50
Amazon.com: Metra Axxess ASWC-1 Universal Steering Wheel Control Interface: Car ElectronicsAmazon.com: Metra Axxess ASWC-1 Universal Steering Wheel Control Interface: Car Electronics
Center Dash USB $12 THE CENTER USB ON THE 2015 WRX IS THE SAME AS IN THE BRZ SO IT'S TOYOTA BASED, hence the TOYUSB and not SUBUSB
Center Dash USB
Center Dash AUX $12
Dash Double DIN Mount Kit $12
Double DIN Mount KitDouble DIN Mount Kit
wiring harness $30
Wiring Harness
USB to HDMI Adapter 30
http://www.walmart.com/ip/21648657?w...599990&veh=sem
USB Female to Micro USB Male $20
http://www.samsung.com/us/mobile/cel...ET-R205UBEGSTA
Female Micro USB to Female USB
http://www.cellphoneshop.net/usbmv9f...FaZlOgodXW8AjA
Parking Break Bypass Switch
misc tools, crimping, solder, shipping i forgot, booze for friends helping with install, etc ~$100
With this I should be able to just plug a USB cord into my center console and it will act as a HDMI mirror
Total: ~$600
Wiring Layout
Need a rooted android phone with this app http://forum.xda-developers.com/show....php?t=2451980
Already starting to buy the parts, once I get the car I'm swapping this out my first weekend.
I'll update with lots of pictures
martialbob is offline   Reply With Quote
Old 05-05-2014, 08:42 PM   #37
sebhockey
Member#: 138957
End Goal Video
Head Unit
Appradio 3 - $350
SWC Module $50
Center Dash USB
Center Dash AUX $12
wiring harness $30
Wiring Harness
Total: ~$600
Wiring Layout
Highly suggest you rethink the way you plan to connect you phone. Not sure on the specs with the Note2, but if its anything like the S3/S4 you will need a 11pin MHL adapter. From there it just gets annoying as most the MHL adapters suck or just simply don't work at all. On top of that when connected to a MHL device most androids have their GPS signal drop out.
I suggest checking into a miracast device to connect wireless. I used a genuine Samsung Allshare cast hub, powered by the head unit's USB. Still able to use second USB port for the wired USB port in the car. This route also allows me to charge my phone (doesn't work with most MHL adapters), have full GPS reception all without having to fumble with any extra wires. My hub is tucked inside the dash, so unless you know about it, you can't even tell.
Old 05-05-2014, 10:43 PM   #38
Redeemed77
Member#: 378138
2015 WRX
CWP
I was reading up on connection types...from best to worst...
1) soldering
2) Scotchlok connector
3) crimp connections
4) wire twist/electrical tape
As a newbie I leaning to the Scotchlok connector type, thoughts?
http://solutions.3m.com/wps/portal/3...=5430181&rt=c3
Old 05-05-2014, 10:46 PM   #39
cpalada
Member#: 349476
2015 WRX Premium AU
1) soldering
I would look at Posi-lock range before the Scotchlok's...Posi-taps are much better than Scotchlok's from my experience.
http://www.posi-lock.com/
cpalada is offline   Reply With Quote
Old 05-05-2014, 10:48 PM   #40
WrxN2Wallz
Member#: 379501
2011 Wrx Hatch
1) soldering
I would crimp before I ever did the scotchlock but I soldered mine and I had never soldered anything it's really easy once you get the hang of it just practice a few runs on some speaker wire you don't want
WrxN2Wallz is offline   Reply With Quote
Old 05-06-2014, 12:16 AM   #41
martialbob
Member#: 387487
2015 WRX Limited
WR Blue
The HDMI to mobile HDMI is the MHL adapter. This adapter has a HDMI input that will go from the MHL adapter to the back of the HU, the USB out for power will come from the HU with a USB to Micro Adapter. From there it is powered USB micro.
I'll have to do some testing on the GPS signal dropping out. If this happens I can use GPS injection and pull the GPS signal from the HU into my phone.
Old 05-06-2014, 12:21 AM   #42
Redeemed77
Member#: 378138
2015 WRX
CWP
Thanks guys! For error correction I think posi-lock makes the most sense. I'm in research faze so thanks for all the input.
Now, what wire gauge posi-lock should I get? I'm thinking 14-16 is what I will need to match what's on the car and the wiring harness.
Btw, I have not heard back from the ae64 guy...should I be worried?
Old 05-06-2014, 12:34 AM   #43
sebhockey
Member#: 138957
I'll have to do some testing on the GPS signal dropping out. If this happens I can use GPS injection and pull the GPS signal from the head unit into my phone.
http://www.pioneerelectronics.com/PU...+Compatibility
Just a FYI before you start your purchases. Note 2 does in fact require the Samsung adapter. The standard MHL converter won't work.
Old 05-06-2014, 10:51 AM   #44
gregonfire
Member#: 181047
2015 CWP WRX Limited
2010 WRX 310/345 - Sold
Lots of great info in here, thank you all for posting. Subscribed.
gregonfire is offline   Reply With Quote
Old 05-06-2014, 12:12 PM   #45
martialbob
Member#: 387487
2015 WRX Limited
WR Blue
thanks for the heads up, already ordered the other MHL adapter so we'll see which one works better.
Old 05-06-2014, 07:54 PM   #46
cpalada
Member#: 349476
2015 WRX Premium AU
I think stock gauge wire is 18? wouldn't quote me on that though...
AE64 (David) said he's got a long backlog of emails he has to reply to...I've been in touch with him recently and it took about a week to hear back - I wouldn't expect instant replies.
Old 05-06-2014, 09:05 PM   #47
Redeemed77
Member#: 378138
2015 WRX
CWP
Ok,thanks for the update
Old 05-08-2014, 10:20 AM   #48
Revelator
Member#: 387207
2015 STI Limited
Ice Silver Metallic
Awesome install pics, the HU's look great. I have a 2015 STI Limited (w/ HK audio) and looking to replace the HU later this summer. For those that have the HK speakers, how big of an improvement is there in terms of sound quality compared to the factory (piece of crap) HU?
Revelator is offline   Reply With Quote
Old 05-08-2014, 01:32 PM   #49
martialbob
Member#: 387487
2015 WRX Limited
WR Blue
Got an e-mail from AE64 earlier today, he is alive just busy
he is out of AUX jacks to the center console, unknown when he will get more, in the mean time find an alternate AUX jack method. I'll probably just run one to the passenger floorboard for guests in the car, I'll be using my HDMI/USB setup.
picked my car up yesterday, as soon as I get my parts ordered/delivered from AE64 and everything else arrives I'll start my install and update
Old 05-08-2014, 03:16 PM   #50
Redeemed77
Member#: 378138
2015 WRX
CWP
I got the same email, all I need is the wiring harness. That poor man needs some help lol.
I hope I can get it ordered soon.
