Welcome to the North American Subaru Impreza Owners Club Sunday April 20, 2014
Old 10-20-2002, 08:02 PM   #1
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Default Camber Bolts Install
Does anyone have pics of their rear camber bolts installed. I jsut want to make sure I get the washer in the right location and everything.
Also, how dangerous are the camber bolts? I'v heard they can loosen up...and loose suspension components are BAD!.
Thanks,
Dan
DDMan is offline   Reply With Quote
Old 10-20-2002, 11:18 PM   #2
DDMan
Member#: 11221
2002 2.5 RS
come on!
bump
Old 10-21-2002, 02:44 PM   #3
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
as long as they are tightened ... you shoudl be fine ...
the alignment shop will change the washers anyway to get the desired camber
you ARE planning on getting it aligned riiiight?
one thing you can get tooo much camber and rub the tire on the strut .. bad .. bad it makes shiny sport (i know )
Old 10-21-2002, 06:26 PM   #4
DDMan
Member#: 11221
2002 2.5 RS
Oh yes...i plan on getting it aligned tomorrow...i will only have them install the camber bolts if it isnt the same L/R or the camber is more than -1.3 deg.
Eibach rear camber bolt install DamnYank! Brakes, Steering & Suspension 1 06-20-2005 02:08 PM
Camber bolt installation? subieworx Brakes, Steering & Suspension 5 07-06-2004 11:04 AM
camber bolts install on my04 wrx Trip McNealy Brakes, Steering & Suspension 2 07-01-2004 02:13 PM
Rear Camber Bolt Install Silver04WRX Brakes, Steering & Suspension 11 06-20-2004 07:14 PM
Camber bolt install? NicGordon Brakes, Steering & Suspension 1 09-29-2003 07:10 AM
