Old 04-29-2014, 06:28 PM   #26
b5rks
Member#: 280634
15 STi
ISM
Would love more information on camber settings......
b5rks is offline   Reply With Quote
Old 04-29-2014, 06:34 PM   #27
Nmullin11
Member#: 353683
2015 Wrx limited
Wrb
Pics from the front?
Looks great!
Must resist the urge of lowering my Wrx, lol.
Nmullin11 is offline   Reply With Quote
Old 04-30-2014, 02:21 PM   #28
cannon98
Member#: 187775
16 Sti
CWP
so no rear LCA needed ?
cannon98 is offline   Reply With Quote
Old 05-01-2014, 01:19 PM   #29
BLkdubRX
Member#: 229971
2009 WRX
w/ SF hotbox
Solid. looks great!
BLkdubRX is offline   Reply With Quote
Old 05-03-2014, 01:03 PM   #30
Nineteen
Member#: 376158
Don't buy a '15 they said....it would be ugly they said.....
Freakin' gorgeous color and wheel set up! Props!
Nineteen is offline   Reply With Quote
Old 05-03-2014, 01:50 PM   #31
Nmullin11
Member#: 353683
2015 Wrx limited
Wrb
Originally Posted by Nineteen View Post
Don't buy a '15 they said....it would be ugly they said..... Freakin' gorgeous color and wheel set up! Props!
I know right..
Old 05-03-2014, 05:11 PM   #32
Redeemed77
Member#: 378138
2015 WRX
CWP
^I 2nd that.....WORRRRDDDDD
Redeemed77 is offline   Reply With Quote
Old 05-04-2014, 11:38 AM   #33
Member#: 227025
2011 STI/GT-R/GT3
Getting caught up from tuning trip in Brazil My apologies for the delayed response.
Since my last post, I have corner balanced and lowered the rear a little bit more to settle things out. I also set the alignment. Without adding a camber kit in the rear, what you see pictured is -2.5 degrees camber in the rear. The front is currently running -2.75 front camber. The front doesn't rub at all, however, once I lowered the rear a little more, I started rubbing if I drive hard or carry passengers in the back.
Easy fix...did a gentle and carefully rolling of the rear fender, and a very slight trimming of the bracket that connects the rear bumper to the 1/4 panel. Now I can drive as hard as I want without rubbing and I think the stance is perfect at this point.
Here are my current final settings if anyone is curious.
Front Camber -2.75
Front Toe: 0
Front caster 8 degrees
Rear camber: -2.75 (will change to -2.0 once I install the camber adjusters)
Rear Toe: 1/16th inch toe in each side.
This is a great dual purpose alignment setup, IMHO. Tracks dead stable and straight and steering wheel has great return feedback and return to center.
Does anyone happen to have the official 2015 OEM STi alignment specs? I have everything through 2014 but I know Subaru made major changes to the rear alignment on the 15....haven't found any published data though.
Sharif@Forged is offline   Reply With Quote
Old 05-04-2014, 02:53 PM   #34
Stickers
Member#: 301428
2015 WRX
CWP
Sorry if this is a bit of a dumb question, but if the GR/GV suspension fits then the same would be the same for the rear camber bolts?
Also, do the hub bore sizes match? Did you swap over the hub rings?
Stickers is offline   Reply With Quote
Old 05-04-2014, 04:54 PM   #35
b5rks
Member#: 280634
15 STi
ISM
Front Camber -2.75
Front Toe: 0
Wow, thanks for the detailed response!
Old 05-04-2014, 06:47 PM   #36
Member#: 227025
2011 STI/GT-R/GT3
Yes, yes, and yes.
On a side note, Some of the GT Spec and Whiteline braces such as the rear tie braces, front and rear upper strut bars won't fit, and the front sway bar isn't cooperating either.
Happy to answer any other questions you all have.
Sharif
Old 05-04-2014, 11:58 PM   #37
Stickers
Member#: 301428
2015 WRX
CWP
Great! Thank you for the answers, look forward to seeing more of your STI.
Old 05-07-2014, 04:28 PM   #38
Elitedax3
Member#: 273166
2013 STi
SWP Wingless
Are you still entertaining the idea of trading your 15' wheels for oem 11+?
Which style 15' do you have?
Elitedax3 is offline   Reply With Quote
Old 05-15-2014, 01:51 AM   #39
Stickers
Member#: 301428
2015 WRX
CWP
Okay, straightening out my questions. Did you notice a big difference between this setup on your "11 vs the "15? Would you say it reacts better with the new STI or with the older one?
Thanks in advance!
Old 05-18-2014, 06:08 PM   #40
Matt S.
Member#: 382003
Had the opportunity to see this on the Tail of the Dragon yesterday, unfortunately not under the best circumstances. Glad to see your friend was alright. Wish I could have done more to help. It looks and sounds incredible!
Matt S. is offline   Reply With Quote
Old 05-18-2014, 09:27 PM   #41
MightyMouse87
Member#: 375777
2014 WRX
Ice Silver
At the Dragon this weekend by chance?
MightyMouse87 is offline   Reply With Quote
Old 05-19-2014, 01:03 AM   #42
MikeWNc
Member#: 390316
2013 BRZ Limited
Still searching for STI
I am in the process of taking all of our go-fast-goodies off my 2011 STi and transferring them over to my new 2015....
Drool. Volks, Ohlin's. You are doing it right sir. Beautiful car. What other bits are you finding that will transfer from the last gen to the new one?
MikeWNc is offline   Reply With Quote
Old 05-19-2014, 02:18 AM   #43
Akrexak
Member#: 100607
2015 DGM STI-His
'14 FXT Touring-Hers
Looks pretty damn good. I might have to look into these for my DGM.
Akrexak is offline   Reply With Quote
Old 05-26-2014, 03:24 AM   #44
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
Looks great, keep it up!
And 8 degrees of castor? Do you have castor adding parts on this car already?
Boxer4u is offline   Reply With Quote
Old 06-02-2014, 09:42 AM   #45
Member#: 227025
2011 STI/GT-R/GT3
Smile
To clarify a few more things on the parts swap over from the 2011 STi:
1) Rear sway bar works just fine, as do the rear end links and Whiteside sway bar support bracket. I haven't tried putting the WL front bar, but probably won't...IMHO the front OEM bar is fine.
I was at the Dragon the week of May 17th through Sunday for ZDAYZ. Did you see me up there?
Running the Whiteside Caster/Anti-Dive solid bushings up front. Probably the single best suspension mod anyone can do to their Subaru. Increasing front caster is one of the best things you can do to improve handling without any negative consequences to tire wear. And the WL solid bushing result in zero increase to NHV.
Speaking of the Dragon: Pics from Tail of the Dragon. :
Old 06-05-2014, 04:01 PM   #46
wstaab
Member#: 390627
Default 2015 WRX and STI aglinment specs
2015 STI launch edition with 300 miles and full fuel tank.
wstaab is offline   Reply With Quote
Old 06-05-2014, 05:09 PM   #47
Member#: 227025
2011 STI/GT-R/GT3
Thank you for posting your results with the 2015 STi off the shelf. Do you happen to have the official 2015 spec sheet for alignment? If I am not mistaken the reference page you posted is for a a pre-2015 or is it actually for the 15?
Old 06-05-2014, 06:09 PM   #48
wstaab
Member#: 390627
The page is out of the online 2015 service manual.
I will email you all 9 pages referencing suspension.
Old 06-05-2014, 07:51 PM   #49
Member#: 227025
2011 STI/GT-R/GT3
Old 06-07-2014, 12:58 PM   #50
Member#: 227025
2011 STI/GT-R/GT3
Unless I am miss reading that specification (I had to read it a bunch of times since some values are in degrees, some in mm, inches, and then minutes), the 2015 has double the rear toe-in verses the 2014 specification. I had heard that Subaru increased the toe in dramatically to help offset the quicker steering ratio. The 15, even stock is way less darty than the 08-14 and has much better on-center feel in steering wheel. Looks like caster is the same as 2014, so that centered straightline and mid corner stability is likely coming from the increased rear toe-in, coupled with the longer wheelbase and stiffer chassis.
Makes we wish I did some tracking testing with the 15 when it had the bone stock suspension. But then again, I can't recall ever setting up a Subaru...or any car for that matter...to OEM alignment specs...haha.
