Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 10-20-2002, 11:36 PM   #1
2.FIVEL
Member#: 23317
red, er blue, no black!!
Default Link Plus ECU; worth it on a NA?
Would it be a worthwhile investment, combined with injectors, larger pump and a FPR, while NA? It would seem to allow for some more aggressive fuel mapping, and take full advantage of the other fuel mods. Perhaps something else can be used with the same results more affordably? Input, anyone?
2.FIVEL is offline   Reply With Quote
Old 10-21-2002, 12:16 AM   #2
zzyzx
Member#: 815
2013 Boss 302 White
2000 2.5 RS Coupe Silver
What are your goals?
This question aside, unless you do other major internal mods, you won't need an FRP/larger fuel pump/injectors. These parts would be a waste of money.
- Steve
zzyzx is offline   Reply With Quote
Old 10-21-2002, 01:03 AM   #3
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
Sorry to hijack, but I have been wondering this for a while as well.
I plan on having head work done in a year or so, but I'll be leaving the other stuff alone. For a while.
tcs007 is offline   Reply With Quote
Old 10-21-2002, 05:44 PM   #4
2.FIVEL
Member#: 23317
Goals... well, I am not opposed to a full out NA built motor, so lets say that long term wise, I run cams, and heads and then need to introduce upgraded fuel delivery. Would the Link be a wise way to manage it?
Old 10-21-2002, 05:59 PM   #5
8Complex
Member#: 922
04 FXT
Red
Well, take a look over here... http://www.8complex.com/rdruns/index.html. Note all of that is WHP.
Those are a few RoadDyno runs I did with some minor mods, stock injectors, SVX FPR (lowers FPR to ~31-32psi at idle with fuel pump), and Walbro fuel pump.
My car runs very strong right now... I'd say I got another few HP out of my last tuning session after a few recent mods. My total mod list as of right now :
ACT Clutch
JUN Flywheel
Stromung non-resonated midpipe
WRX backbox
Knife-edged throttle body
TB Coolant Bypass mod
RC 440cc Injectors
Parallel fuel line mod (a'la my own creation as I think other do it differently)
Removed injector air bypass solenoid & related equipment
Haltech E6K
Not a whole lot of stuff, certainly not enough to net the HP gains I do with the stock ECU. I probably tune up and gain an extra 15-20HP with the ECU.
Oh, and this is in preparation for turbo, so it's not just a waste of spending. Otherwise I'd have cams, built motor, etc. as well.
Old 10-21-2002, 06:47 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
i am also looking into getting this in preparation for turbo. Tom at ludespeed said it would probably be wise to get it while NA and learn how to tune it while i cant break anything. thing is what will it replace in terms of other engine management that i will need? will it replace everything else? like a J&S safeguard? S-AFC? also where is a good place to get these and how much should i look to pay? any problem with getting a used one? thanks, sorry to hijack.
Ben
Old 10-21-2002, 07:07 PM   #7
2.FIVEL
Member#: 23317
Just a note on cost, PHAT, Tom quoted me $1300 for the Link w/ the PClink, from him.
Old 10-21-2002, 07:21 PM   #8
8Complex
Member#: 922
04 FXT
Red
In the ECU forum I made a ECU FAQ and Comparison post (it's up at the top) with details on most of the ECU's.
The Link will fully replace your stock ECU and will have some sort of knock correction in it. You shouldn't need anything other then that to run perfectly (well, other then patience and tuning knowledge). Injectors and a pump come later if you plan on going turbo, as well.
Old 10-21-2002, 09:15 PM   #9
2.FIVEL
Member#: 23317
Awesome info, 8. But could it be applied to nitrous applications, like a different fuel map when using it?
Old 10-21-2002, 09:50 PM   #10
8Complex
Member#: 922
04 FXT
Red
I'm not entirely sure about the Link, but I know that some ECU's have N2O related fuel corrections. My Haltech, for instance, has an input that will control the N2O and retard timing accordingly. Not exactly adding fuel, but I'm sure you could pull something off like that with some circuitry and the fuel trim knob input.
I think that if an ECU senses the cooler intake air, it will utilize it's Intake Air Temp maps and add fuel accordingly.
does the link plus have 10deg advance on an rs statically ? White 2.5rs Engine Management & Tuning 2 09-19-2004 07:22 PM
A Spray Kit Worth It On A Stock Wrx wrxturbo17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 03-28-2003 12:15 AM
Rear camber adjustment bolts worth it on stock suspension? Tex-WReX Brakes, Steering & Suspension 2 11-08-2002 10:47 PM
Cold air intake's. Are they worth it on a WRX? GIXER Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-20-2002 04:56 PM
Turbo upgrade worth it on stock fuel system? Mephisto318 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-03-2002 12:10 AM
