Old 10-20-2002, 11:02 PM   #1
redline29
Member#: 14064
2005 STI
blue
Post Tec II help
redline29 is offline   Reply With Quote
Old 10-20-2002, 11:32 PM   #2
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Which sensors?
Your best bet is electromotive's web site.
http://www.emi.cc/sensors.html
Revision is offline   Reply With Quote
Old 10-21-2002, 08:17 AM   #3
Austin
Member#: 7089
2016 STi
If you're installing the crank trigger, coolant, or knock sensor, your best be is to go through Shiv at Vishnu Performance . He makes subaru specific mounting brackets and adapters that'll make life much easier.
Austin is offline   Reply With Quote
Old 10-21-2002, 11:11 PM   #4
redline29
Member#: 14064
2005 STI
blue
Default help
I tried going to vishnu web site but I will not let me email shiv
came some one got me his email!!!!!!!!
thanks Dave
Old 10-22-2002, 07:57 AM   #5
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
Unhappy
I called them early last week about getting a the pick up mount which they didn't have available and they told me that they're moving away from using the TEC in their setups. They want to use something more simplified, and they told me to go through Electromotive for the sensors. I don't know if there's anyone else that makes Subaru specific parts.
seven881 is offline   Reply With Quote
Old 10-23-2002, 03:31 PM   #6
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Vishny is trying to make obselete the TEC in their lineup?
This comes as a big suprise, especially since they have had so much succes with it......
Graham
Graham is offline   Reply With Quote
Old 10-23-2002, 03:46 PM   #7
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Exactly what I was thinking. And you called Vishnu and they couldn't provide you with the part numbers that they used to make up their kits? I should think they would provide the GM part numbers to make it easier for their existing customers to get replacements. I can understand about the custom crank pickup mount, but everything else was sourced and purchased.
SteveS is offline   Reply With Quote
Old 10-23-2002, 04:55 PM   #8
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
[quote]And you called Vishnu and they couldn't provide you with the part numbers that they used to make up their kits? [/QUOTE
No, I ment that I could not purchase the sensors directly from Vishnu. As far as the sensors, there are plenty of people to get those from since there not Subaru specific parts. I was more concerned with the pick-up mount since those are a PITA to make. I never asked for the GM part numbers, but that's a good idea, because I could walk into AutoZone and get most of the sensors.
The guy on the phone said that they wanted to use something "less intense" and more pug-n-play in their setups. I was suprised too when the guy on the phone told me too. I didn't get his name, but he had a british or australian accent.
Old 10-23-2002, 05:40 PM   #9
Austin
Member#: 7089
2016 STi
The guy you talked to is Brett. I just had a good 1/2 hour conversation with him.
Vishnu will continue to be a Subaru specific Electromotive dealer. Vishnu is still the place to go for things like the crank magnetic sensor mounting bracket, knock sensor adapter, and coolant sensor mount.
Vishnu is working on/testing several different engine management options. Most of those options are plug and play. There are plug and play ecu's which will perform most/all/more functions than the TEC3 for considerably less $$, which is why the TEC won't be the standard engine management option. It'll still be available though, you just have to ask for it .
Old 10-23-2002, 06:08 PM   #10
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
Smile
SWEET!
Old 10-24-2002, 06:53 PM   #11
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
So would they be able to provide me with a crank trigger wheel for a TEC-II? Does Vishnu or Electormotive make this?
Graham
Old 10-24-2002, 07:33 PM   #12
Austin
Member#: 7089
2016 STi
Electromotive makes a trigger wheel, but Vishnu machines their own trigger wheels, and it'll come centered on and attached to a stock crank pulley.
The trigger wheel is the single most important piece, so you need to get it exactly correct. Vishnu does.
Old 10-26-2002, 11:05 AM   #13
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
So does anyone know if what seven881 is saying is true? Can I still get the crank trigger wheel for a 2001 RS?
Graham
Old 10-26-2002, 11:16 AM   #14
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
Graham
What I said was true at the time, but apperently they made the decsion to keep supporting the TEC II after I talked to them, so yes you should be able to get one from them. Pick up the phone and give them a ring.
Old 10-26-2002, 11:30 AM   #15
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
Wanna buy my Tec-II? It's a complete Vishnu kit. Has all the sensors, injectors rails etc.
-Michael
d00f is offline   Reply With Quote
Old 10-26-2002, 11:44 AM   #16
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
-Michael
Wanna part out the Pickup Mount I'll give you $100 for it? Seriously, if you part it out, I'd take the PickUp Mount, Fuel Rails and Injectors if you decide to do it.
Old 10-27-2002, 01:57 AM   #17
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
How much do you want for it man?
Graham
Tec Ii Help maxiav Engine Management & Tuning 5 04-14-2004 12:44 PM
Need help with RS-T ECU Code Malfuctions, and if TEC II will Solve it. yebokmj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-31-2001 07:34 PM
TEC-II in hand, need install help bsquare North West Impreza Club Forum -- NWIC 2 04-06-2001 10:42 PM
TEC II Update. Thoughts on NA TEC II Kit installation. Imprezer Technical Forum Archive 30 05-26-2000 08:37 PM
TEC-II / TEC-II Connection Port STi Sev Technical Forum Archive 10 05-25-2000 07:28 PM
