Old 04-26-2014, 12:48 AM   #1
xXOli450Xx
Member#: 362238
Default Engine won't go on tranny
my engine won't go in any furter, i have pulled it out at least 5 times but everything seems ok
anyone had this issue?
xXOli450Xx is offline   Reply With Quote
Old 04-26-2014, 02:24 AM   #2
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Originally Posted by xXOli450Xx View Post
my engine won't go in any furter, i have pulled it out at least 5 times but everything seems ok anyone had this issue?
Happens all the time. Check the bottom dowels and make sure the input shaft is lined up completely.
boosted25 is offline   Reply With Quote
Old 04-26-2014, 11:00 AM   #3
dustin434
Member#: 389064
I had this problem when i did my clutch. it sounds forceful. but when i split the tranny and engine i had to use a hammer and prybar. the dowels are snug. when i put it back in, made sure everything was lined up and had to tap it with a dead blow. thin sucked it in with the bolts. hope this helps
dustin434 is offline   Reply With Quote
Old 04-26-2014, 11:54 AM   #4
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
put the throw out bearing on the tranny, then push it in. it took me forever to figure out that the throwout bearing on the trans.
bigolrig is offline   Reply With Quote
Old 04-26-2014, 06:08 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Are you sure you don't have dowel pins in both the tranny and the block? If you had the clutch off, did you use an alignment tool align the clutch disc and pressure plate splines?
Old 04-27-2014, 02:19 AM   #6
xXOli450Xx
Member#: 362238
yep , the clutch is allign, the block have one pin and the tranny have none
Old 04-27-2014, 02:46 AM   #7
kellygnsd
Member#: 32669
LINK G4 hybrid STi
While you try and pull the motor together have someone jiggle the crank pulley bolt back and forth as you do.
Old 04-28-2014, 04:01 PM   #8
Member#: 301037
2004 Forester XT
Also make sure that you take out the alignment tool once the clutch is tightened. I would've normally played that off as obvious, but I myself forgot one time and it took about 30 frustrating minutes to figure out my own stupidity.
-Art
art@grimmspeed is offline   Reply With Quote
Old 04-28-2014, 09:55 PM   #9
kelvinzxcv
Member#: 285605
2004 WRX
Sand the dowel pins and attach the throwout bearing to the tranny side. The gap looks like the TOB isn't setting
kelvinzxcv is offline   Reply With Quote
Old 04-29-2014, 01:22 AM   #10
kellygnsd
Member#: 32669
LINK G4 hybrid STi
If the TOB is attached to the pressure plate, it's the clutch fork pulled up and out of the way?
Like said above, put the TOB on the tranny side, install the clutch fork, then bring the engine and tranny together.
Old 04-29-2014, 02:13 PM   #11
snobordboi
Member#: 149130
2002 WRB WRX
VF39 Brembos etc
How is the angle of the engine? Last time I had mine apart, I had a bear of time getting it back together, then I tilted the engine up from the front more using a jack, and it popped right in.
snobordboi is offline   Reply With Quote
Old 04-29-2014, 08:11 PM   #12
xXOli450Xx
Member#: 362238
angle is pretty the same on transmission and engine , the TOB is on the tranny with the fork on it but don't you have to wait till the engine is tightend on the transimission before clipping it on the pressure plate?
Old 04-30-2014, 11:03 AM   #13
dub1080
Member#: 331260
2002 wrx
there is a pin that holds the clutch fork in, did you put that back before attaching the tranny to the engine?
dub1080 is offline   Reply With Quote
Old 04-30-2014, 07:57 PM   #14
xXOli450Xx
Member#: 362238
no but the fork is not blocking i can move it!!
Old 04-30-2014, 08:30 PM   #15
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
Perhaps the splines on the input shaft are like this >< with the clutch splines, so it won't slide in?
super_usdm is offline   Reply With Quote
