Old 04-26-2014, 01:01 PM   #1
loofer
Member#: 342743
Default Initial Boost is good, but when I shift it falls on it's face!
So randomly last night I started making no boost on my 2002 WRX.
Here's the skinny:
As I start from a dead stop, I punch it and it holds perfect boost through 1st gear. Then as I shift into 2nd the suby literally falls on it's face and I making barely over zero PSI. But, if I decelerate (let off the throttle) then accelerate again boost is back. Then I go to shift and nothing.
It is extremely consistent, so here are the list of my mods:
2.1 Stroker (Forged internals)
11mm STI Oil pump
HKS SSQV Original Blow-off valve
3 inch BPM exhaust from the Turbo back with High flow cat.
The Turbo is the stock bugeye turbo
Stock fuel system
Stock intake
Any ideas on what this issue might be or where I should start looking? It feels like boost leak, but then again why does it hold boost until I shift every time? Could it be the Blow-off valve remaining slightly open after I shift? Wastegate Spring issue?
I would love to hear your input! Let me know Friends!
loofer is offline   Reply With Quote
Old 04-26-2014, 01:26 PM   #2
Andrewxxcarlson
Member#: 316415
2006 WRX
I'd start lookin at that bov
Andrewxxcarlson is offline   Reply With Quote
Old 04-26-2014, 02:04 PM   #3
loofer
Member#: 342743
Ya good call, I'll give the throttle cable a few pulls and see if their are any gaps as it closes. If that is the case should I try and lube the shaft in the HKS?
Old 04-26-2014, 05:02 PM   #4
loofer
Member#: 342743
So I revved the suby a few times, drove it down the rode an back. I didn't notice any issues with the HKS BOV, but no I hear some small scretching from the turbo
It's a sad day.. .. ...
Any recommendations for a turbo for a 2.1 build, lol? Only looking for around 300hp and would like to keep the fuel system stock if possible.
Old 04-26-2014, 08:15 PM   #5
Shiftace420
Member#: 383633
2002 Impreza WRX
I second the BOV. You would hear extra spool from the turbo if its leaking. Also if your turbo is bad, its probably bad all the time and will not get better after you let off.
Sounds like the BOV is sticking after shifts and is seating when you let off(go into vacuum mode)
I don't think this is your issue but if it is: If your going to vary from the stock turbo plan on getting fuel system upgrades. You can cheat a little with fuel pressure and injector duty to a point but your best off to just do it right. Should pull the downpipe and check the shaft play before you condemn the turbo.
Shiftace420 is offline   Reply With Quote
Old 04-26-2014, 09:12 PM   #6
loofer
Member#: 342743
Solid advice! I'll probably do that tomorrow to check. I truly was hoping it was the bov, but when I started hearing what sounded like ball bearings going.
Here check it out:https://www.youtube.com/watch?v=0d7j-_yhzVo
Old 04-26-2014, 10:39 PM   #7
Shiftace420
Member#: 383633
2002 Impreza WRX
Does sound a little odd. Video helps alot thanks for posting. Better pull the DP and check for sure.
I have never seen a turbo boost like that lol. Most I see are pretty much destroyed and don't boost at all or have terrible sound while boosting but still boost everytime not interminantly like that.
If its your turbo i would recommend you send it in to a good rebuilder. Usually the cheapest option to get a brand new rebuilt turbo with piece of mind. Otherwise the TD04 is widely availble used but your still guessing at condition or rebuilding it anyways.
Old 04-27-2014, 01:13 PM   #8
loofer
Member#: 342743
So I pulled the downpipe off after church. The turbine shaft is not loose at all! Woot! Zero play, however, the wastegate vlave next to the turbine is quite loose. Check the picture out to see what I'm talking about.
I am guessing that is suppose to seal really nice and be tight. Any ideas how to get that wastegate valve fixed?
[IMG][/IMG]
Old 04-27-2014, 02:16 PM   #9
Shiftace420
Member#: 383633
2002 Impreza WRX
Adjust the preload on the spring? Should see about 7psi to crack and 10psi to open full if you hook a mityvac in pressure mode to the diaphram.
Is the arm still hooked up? They can strip out or fall off after time.
Old 04-27-2014, 02:24 PM   #10
loofer
Member#: 342743
By arm I'm assuming the arm from the spring down to this valve? And their is suppose to be no play on that valve correct? So for the Noob questions. I know motors, but not internal workings of the turbo.
Old 04-27-2014, 03:03 PM   #11
loofer
Member#: 342743
I just pulled on the wastegate arm and it does not function smoothly. I simulated it opening and closing multiple times and it would leave the valve open sometimes and other times it would close. very inconsistent! Sound like a bad waste gate?
Old 04-27-2014, 03:57 PM   #12
Shiftace420
Member#: 383633
2002 Impreza WRX
Yup that's your problem. Also the arm can be turned and cause binding with the diaphram. You should disconnect the arm and move the wastegate. If its crusty or sandy feeling your wastegate is sticking for sure.
Old 04-27-2014, 04:31 PM   #13
loofer
Member#: 342743
Ya I just removed that C clip on the actuator arm, and the Wastegate flap itself seem to stick a lot as I freely moved it back and forth. How would I go about actually replacing that wastegate flap?? I can easily replace the actuator, but I'm not sure on the flapper.
Old 04-27-2014, 05:49 PM   #14
loofer
Member#: 342743
Or is there a way to polish up the "seating" of that flapper to the turbo housing and smooth out the opening & closing action of that flap?
