Old 04-29-2014, 05:28 PM   #1
hoffmanEstates
Member#: 122043
04 wagonier
psm
Default looking for 16" size options.
I am kicking around the idea of running 16" stock wheels with a dedicated summer tire. Now do I stay 205/215 on 55/50 or go wider in a 225/50-55. I seen thus years back in a wagon and had a beefy look, its just a occasional DD. Maybe tirerack can chime in with any deals.....
hoffmanEstates is offline   Reply With Quote
Old 04-29-2014, 07:15 PM   #2
flukewrx
Member#: 75081
2003 WRX
If you're running the stock 16 x 6.5" wheel, then you're probably better off sticking with the 205/55/16 tire size.
If you're running a wider 16" wheel (like the old RS wheels that are 16 x 7.0") then 225/50/16 is fine to run.
flukewrx is offline   Reply With Quote
Old 04-30-2014, 06:24 AM   #3
hoffmanEstates
Member#: 122043
04 wagonier
psm
Could I do 215/55?
Found some dz102 rubbers decently priced
Old 04-30-2014, 06:05 PM   #4
flukewrx
Member#: 75081
2003 WRX
http://www.miata.net/garage/tirecalc.html
If you're lowered (a fairly drastic amount as a mild drop shouldn't really encounter an issue) you may end up rubbing as the 215/55/16 is a slightly taller tire.
The taller tire may give a slightly more comfortable ride, but the trade off is that you would introduce a bit more sidewall flex into the setup.
Can you run it? Sure, but do note that your speedometer will be slightly off based on the different tire sizing.
Old 04-30-2014, 08:04 PM   #5
hoffmanEstates
Member#: 122043
04 wagonier
psm
Ah yes spedo, I am stock height,
Old 05-01-2014, 10:01 AM   #6
Tire Rack Moderator
Member#: 1215
ext. 4362
correct
Old 05-05-2014, 09:37 PM   #7
Android287
Member#: 180861
2005 cammed Hybrid
2.5xtr E85
I have 225/50r16's on my stock 16's. The feeling is kind of mushy and there is a decent amount of sidewall bulge.
Android287 is offline   Reply With Quote
Old 05-06-2014, 03:27 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i was gonna do 16's but the tire size and wheel size choices suck compared to 17's
you can get a set of 17x8's and use a whole buncha different size tires on them, depending on the particular tire and how it is 'sized'.....you could put 215, 225,235 or 245's(and maybe even a 205) on in 40 or 45 or maybe even 50 series
