Old 10-21-2002, 07:16 PM   #1
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
Angry link help!!!!!
can some nice person out there help me ??
i need a base map for the link..
or a minor mod map
this is what i have :
vf24
blitz sus power intake
blitz fmic
3 downpipe
blitz full exhaust
no cats
godspeed uppipe
thx ..
please help....
gabewrx is offline   Reply With Quote
Old 10-21-2002, 09:01 PM   #2
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
Anyone please!
Old 10-21-2002, 09:01 PM   #3
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
Anyone please!
Old 10-21-2002, 09:05 PM   #4
skywalker
Member#: 1990
The base map that comes with the WRXLink will get you up and running fine, as it is very similiar to the base map of the WRX.
Just do a "reload" and that will get you the base map you need to start running. If you have not changed any of the fueling then the car should actually run similiar to a stock WRX.
From there you can advance the timing and adjust whatever needs to be adjusted.
skywalker is offline   Reply With Quote
Old 10-21-2002, 10:24 PM   #5
christoph1371
Member#: 1090
gee that skywalker guy is soooooo smart
christoph1371 is offline   Reply With Quote
Old 10-21-2002, 10:45 PM   #6
gldenchld
Member#: 19994
I wouldnt really want to advance timing unless going down the strip. For a street map try retarding the timing a few degrees.
gldenchld is offline   Reply With Quote
Old 10-21-2002, 11:17 PM   #7
skywalker
Member#: 1990
I understand you would want to retard timing if the MAP is already optimal but the MAP is not in any case optimal. The ECU runs pig rich under boost and causes the car to run slow. I guess my explanation was very uninformitive the first time through as i was in a rush as always. Let's try again...
The reason you put a Link in is to get more power. The only way to get more power is to raise timing (or raise boost or lower fuel). Of course along with advancing the timing you should raise your fuel levels. There is a point where advancing the timing does no good anymore and a lot depends on you O2 readings, EGT temps, knock count etc.... But between the stock ECU MAP and a tuned Link MAP there quite a few degrees of adjustment (and added fuel) that can be reached with the stock WRX. Still is still running on 91 octane also.
Any person can easily make an extra make 30 hp gains but just putting the in the Link. This will still keep you in a very safe range and give you a lot more fun. Of course your gas mileage will drop if you are boosting all the time. But you bought the Link for a reason right.
In the end it does help to have experience in tuning. But of course this takes a lot of time and patience.
Old 10-22-2002, 09:06 AM   #8
gabewrx
Member#: 14688
04 EVO!!!!
white i think!
Default hey skywalker
hit the default tab and click reload????? i`m kindof slow today..
well if so it tells me "error" no temp file found"
what do i need to do??
sell the link?
Old 10-22-2002, 01:06 PM   #9
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
Default Re: hey skywalker
sell the link?
Ok.. I think he meant.. turn car on, load link software, open the base map, goto the connection menu, on the top right side select the option that says download map to link, then click online, then click OK. Wait 15 seconds.
Evaider is offline   Reply With Quote
Old 10-22-2002, 01:49 PM   #10
skywalker
Member#: 1990
Sorry about that... I just hate explaining this a million times over. I guess I should just make a website or something to keep track of this stuff.
Anyway here goes.
Open the PCLink Software.
Connect to the Link
Goto Link Controls on the Menu
Then select reload and click yes.
This will reload the base map that came with the Link you have.
LINKS...help me lilrex Engine Management & Tuning 1 06-06-2003 03:18 PM
Cusco rear adjustable arms/links help wlelandj Brakes, Steering & Suspension 4 04-07-2003 09:13 AM
Link help Skulltoy Engine Management & Tuning 0 03-30-2003 10:40 PM
link help mkbvictory Engine Management & Tuning 5 01-15-2003 01:46 PM
Link help Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 51 05-22-2002 02:18 AM
Message Board Statistics All times are GMT -4. The time now is 08:56 AM.
