Old 10-21-2002, 09:45 PM   #1
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Default Good Tec3 map for a 2000 RS Vishnu kit
Anyone have a TEC3 map that is tuned well on a 2000 RS with the following.
Vishnu RS turbo kit
550 injectors.
If you do maybe you could email me a copy of them.
Thanks
Dave
david2z4 is offline   Reply With Quote
Old 10-21-2002, 10:20 PM   #2
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
want to add that I had it tuned pretty good, then when I put it the 12 lb flywheel and new up and down pipe on, now it runs way different.
It is really rich and I can't get it to run good with the normal adjustments that I have made in the past.
Pulled the spark plugs and they are clean. Wonder what I am doing wrong.
Dave
Old 10-22-2002, 07:53 AM   #3
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
When does it run differently? Cold start? Warm up? Steady state cruise? In boost?
Can you not get it to idle now, or does the car surge?
Austin is offline   Reply With Quote
Old 10-24-2002, 12:55 AM   #4
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
I get lean lope at idle when warm but it is not lean.
It starts harder cold and warm
about the only time it seems to run good is under boost.
gas mileage is way down.
I think I blew another O2 sensor to due to being to rich. the voltage just started oscillating from .2 to 4.5. but it ran bad before that went out again. May have to buy them by bulk the rate I go through them.
Old 11-15-2002, 09:45 PM   #5
RS_NW
Member#: 2301
I think my o2 went too. It reads 0-5 mostly. It is supposed to be reading anywhere between 80-95.
What about your battery Dave? Now that I think about it... it makes sense. I remember you telling me that the TEC3 is voltage dependant. So at idle, it could idle funny because you aren't getting juice to the battery because the engine isn't spinning the alternator fast enough. At boost your car is spinning the alternator fast so it compesates for the fact that the battery isn't holding voltage.
What do you think?
RS_NW is offline   Reply With Quote
need an rs coupe wing for my 2000 rs sekretskwirl Private 'For Sale' Classifieds 1 04-14-2006 05:28 AM
TEC3 Map for STI ChAi Engine Management & Tuning 2 03-20-2006 01:23 AM
For Sale... 2000 RS coupe, 2001 RS sedan Fred South East Region Forum 17 10-26-2004 01:06 PM
What adjusting the MAP Clamp on 2000 RS-T does. IowaRS Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-26-2004 12:24 PM
Brake kits for a 2000 RS Xybermage Brakes, Steering & Suspension 22 06-22-2004 06:44 PM
Message Board Statistics All times are GMT -4. The time now is 02:00 AM.
