Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 05-12-2014, 04:26 PM   #1
KRMpower
Member#: 367683
2008 WRX STI
black
Default Torque Steer
I have a 2008 still with 67k on the clock. I Got it from carmax @ 58k. When I purchased the car it pulled right. They aligned it(1st time) and it was not better.I loved the car and bought it anyways. Fast forward 3k miles from purchase date and I brought the car to subaru becausre it was still pulling and they began checking the tires and noticed i snagged a nail. Replaced one tire but Subaru felt it was within spec obviously because they replaced it and said nothing about replacing them all to match. They aligned (second time) the car and gave it back.
To my consternation, the car was still pulling to the right. The dealer said swapping the tires left to right caused the opposite to occur. when I brought it back to them again(3rd time) and they realigned it, finding that it had fallen out alignment...
They then gave it back. Fast forward 4k miles and the passenger right tires is worn so badly from toe in, it will need replaced. Carmax then aligned (4th time) it and showed me how close to factory the specs were, satisfied.They swap itThe tire to the back. Fast forward 1500 miles and now both back tires are destroyed and so is the tire in the front passenger side again... Figuring it was tires, I went out today and bought a whole new set of tires.
At some point it started pulling left, i think this started happening when the swapped out the worn front tire to the back .
It only pull on accel or under load though . At coast, it goes straight.
Carmax put wheels from a 2013 STi on the car with brand new tires, same problem, only now it pulls right instead of left.
they have replaced lower control arm bushings, and reset the rack (it was loose and missing bolts)
it has been aligned numerous times and always trues up, but doesnt go straight, whats the deal...
ALSO, if you dont have a clue (like me, or the dealerships i took it to)
I guess i need a good reputable body shop to verify angles, lengths and frame rigidity, any suggestions.
KRMpower is offline   Reply With Quote
Old 05-12-2014, 08:05 PM   #2
LEGITWRX
Member#: 255816
2006 Subaru WRX WRB
omgwtfbbq
Are any of the struts blown/leaking? If so, start there. Suspension geometry is changing under load/stress and could explain why alignment looks on spec while on the alignment machine. It could also explain the uneven wear on the tires etc. Worth a shot.
LEGITWRX is offline   Reply With Quote
Old 05-12-2014, 08:19 PM   #3
KRMpower
Member#: 367683
2008 WRX STI
black
no struts are blown or leaking. however, the car seems to bottom out pretty easily.
Old 05-12-2014, 09:58 PM   #4
RM3851
Member#: 232522
'14 STi
02C Croatianized
Where in SoCal are you from?
RM3851 is offline   Reply With Quote
Old 05-12-2014, 10:32 PM   #5
FreeDiRo
Member#: 324928
2006 Sti
SGM
If they are still the stock units from the factory it's time to replace them. They usually last about 60K miles and you don't know how badly the previous owner beat on them or the type of roads they drove on. I had an issue similar to this with an aftermarket set up, but that was due to springs binding and not sitting properly.
Talk to West End Alignment
FreeDiRo is offline   Reply With Quote
Old 05-12-2014, 10:34 PM   #6
KRMpower
Member#: 367683
2008 WRX STI
black
Irvine
Old 05-13-2014, 12:14 AM   #7
KRMpower
Member#: 367683
2008 WRX STI
black
The issue you had was similar how?
Old 05-13-2014, 01:14 PM   #8
KRMpower
Member#: 367683
2008 WRX STI
black
taking the car to darin tomorrow, then to uber thursday.
ill keep you guys informed, until then, any and all pointers or help or even if somebody wants to come drive the car and have a look let me know.
Old 05-13-2014, 01:20 PM   #9
blobeye05
Member#: 349560
2005 Impreza WRX STI
I had a slight torque steer /clunk on my 05 sti under launch and hard accel then i changed the front lower control arm bushings as well as most of the other suspension bushings (prothane) problem solved
blobeye05 is offline   Reply With Quote
Old 05-13-2014, 01:31 PM   #10
KRMpower
Member#: 367683
2008 WRX STI
black
it seems to be under any level of acceleration, obviously hard accel makes it worse, what exactly did you swap out?
Old 05-13-2014, 03:36 PM   #11
blobeye05
Member#: 349560
Front control arm bushing kit
Rear trailing arm bushing kit
Front sway bar bushings - 20mm
Rear sway bar bushings - 17mm
Manual Transmission Shifter Stabilizer Bushings
also whiteline rear differential and subframe bushings
and Cusco engine mounts
Most noticeable were the engine mounts and the front lower control arms. Much more responsive and sold feeling. Afterwards i heard no more clunks and had no more torque steer
Old 05-13-2014, 03:54 PM   #12
blobeye05
Member#: 349560
I forgot i also replaced my pitch stop mount with an Agency Power pitch stop...
Old 05-13-2014, 09:59 PM   #13
FreeDiRo
Member#: 324928
2006 Sti
SGM
my set up did the same thing under hard acceleration; pulled to the left and then I got a new alignment, still pulled to the left, so I got new tires and had my rims checked none were bent or messed up and then got a new alignment, the car pulled right after that then straightened up a bit. I got tired of the set up causing me problems and didn't want more of them so I upgraded them with coilovers and haven't had a issue since then. Maybe I got lucky and didn't have any suspension pieces bent.
Sorry I didn't clarify more earlier
Old 06-06-2014, 01:22 PM   #14
KRMpower
Member#: 367683
2008 WRX STI
black
UPDATE!
took the car to west end allignment, they set the alignment and discovered a 0.0 degree camber on the drivers side and .6 degree negative on the passenger side.
they sat me in the car and set it up negative 1.5 all around. HUGE improvement.
West end broke a stud on my car but other than that the guy waited an extra hour after closing for me so props.
took the car to coach craft and discovered that the car probably ran something over on the passenger side and required some kinds of repairs. Coachcraft is epic BTW.
car needs new bushings, and probably shocks and springs.
idk what the previous guy did but he wore the shocks and springs out so bad and unevenly the car squats wierd and pulls.
Old 06-09-2014, 10:08 AM   #15
rain042710
Member#: 294099
2015 STI/GT-R
UPDATE!
+ 1 For west end allignment
rain042710 is offline   Reply With Quote
Old 03-16-2015, 06:47 PM   #16
KRMpower
Member#: 367683
2008 WRX STI
black
Soo, 3 sets of tires, 3 different sets of wheels and it still does this. I'm beginning to suspect diff...
Old 03-16-2015, 07:20 PM   #17
filthy
Member#: 176613
GR Panty Dropper!
Built Silver STI!!!
Quit hitting potholes dude. that sucks. lol
filthy is offline   Reply With Quote
Old 03-18-2015, 12:48 PM   #18
KRMpower
Member#: 367683
2008 WRX STI
black
i try not to hit potholes, and usually don't. honestly, i don't think that's the problem. I'm seriously suspecting the differential either front, rear or center... can ANYBODY help me figure this out. I will pay the guy who diagnosis this correctly, even if he doesnt do the work, just help me figure this **** out.
SubieSpecialties couldnt get it, south coast Subaru couldnt get it, Irvine Subaru couldnt get it. it seems that nobody has any idea what the problem is.
Old 03-18-2015, 01:31 PM   #19
filthy
Member#: 176613
GR Panty Dropper!
Built Silver STI!!!
I dont think the differential has anything to with tire wearing... i could be wrong. Maybe a bent axle would do this. and if it is slightly bent it my not be as visible and still eat your tires.
Did you try West End Alignment? im beginning to think that alignment isnt the issue either if you have had 3 shops look at it. Bent Axle is my blind diagnosis.
BTW i was being sarcastic about the potholes.
Old 03-19-2015, 01:58 PM   #20
KRMpower
Member#: 367683
2008 WRX STI
black
i did go to West End, they corner balanced and couldn't find anything wrong with any of the steering or suspension components. I think when i do coilovers, ill also do end links, its just a process of trial and error at this point...
Old 03-19-2015, 02:57 PM   #21
thebanker
Breaker of Chins
Member#: 338070
2013 WRX Hatchback
2014 XV Crosstrek
That, or something wonky with one of the CV joints?
thebanker is offline   Reply With Quote
