Old 10-22-2002, 12:25 AM   #1
tuca33
Member#: 24303
2002 Impreza WRX
Default HKS Grounding MOD
I bought an HKS ground mod and the manual came in JApanese.
Anyone have a guide to install it???
Thanks
Tuca
tuca33 is offline   Reply With Quote
Old 10-22-2002, 01:15 AM   #2
atomicapples
Member#: 12626
02 2.5 rs
i just followed the pictures and used common sense. it really isnt a hard install.
atomicapples is offline   Reply With Quote
Old 10-22-2002, 01:44 AM   #3
cobrabyteWRX
Member#: 24818
World Rally Blue
Come on ... gotta be smarter than the wires
Just kidding,
Chris
cobrabyteWRX is offline   Reply With Quote
Old 10-22-2002, 02:06 AM   #4
tuca33
Member#: 24303
2002 Impreza WRX
Wich grounding points you guys used???
And i dont know where to install that round thing that attaches all the wires(distribution block),,should i screw it to the battery terminal?
Thanks
Tuca
Old 10-22-2002, 04:19 AM   #5
tuca33
Member#: 24303
2002 Impreza WRX
Ok,,now i am almost done.
I have 2 more questions
For what is that 2 black circles with some kind of fluffy protection??
and about the grounding points..many of them are in the manifold and other important parts.I should only unscrew it and screw it back again???like Will i need a torquimeter so i can measure the bolt pressure when reapliyng the bolt of those parts??
Thanks
Tuca
Old 10-22-2002, 01:53 PM   #6
tuca33
Member#: 24303
2002 Impreza WRX
Anyone??
Bump
Thanks
Tuca
Old 10-22-2002, 05:35 PM   #7
Yeoman
Member#: 175
2000 Impreza 2.5RS
2012 Legacy 3.6R
Dude, anywhere you want,
stick one of them under one of the strut top bolts,
and tighten the screw back down. as long as it's making contact, don't worry about torque specs, if anything dont OVER tighten them.
Yeoman is offline   Reply With Quote
Old 10-22-2002, 06:15 PM   #8
harvey
Member#: 24861
2000 STi 6 Wagon
I made up my own earth kit which cost about 10stg (15$) for the cable and the lugs which I crimped then soldered. From start to finish was over 2 hours including getting the material, cutting and making up and fitting. Any electrician could do the crimping and soldering and supply the cable too I expect.
I used 99.99% oxygen free copper.
Ran a number of wires to generally improve earthing including:Alternator mounting bolt to battery negative. Also ran loop to each side of the inlet manifold, the bulkhead and chasis leg. Measuring with an AVO Meter showed a good improvement.
I have seen one of th HKS kits in the UK and was told it cost 155 (230$) If that is true then do yourself a favour and make your own.
harvey is offline   Reply With Quote
Old 10-22-2002, 06:26 PM   #9
tdxflex
Member#: 13634
he's gotta know the torque spec if he doesn't want to overtighten them. most people use 12 ft-lbs
tdxflex is offline   Reply With Quote
Old 10-22-2002, 09:22 PM   #10
tuca33
Member#: 24303
2002 Impreza WRX
Thanks Tdx Flex.
And i bought the HKS kit for 125 USD$ and the kit is very nice.
perfect fit to a WRX..OEM Fit.
Thanks
Tuca
Old 10-22-2002, 09:39 PM   #11
Fastrnu
Member#: 9549
2004 STi
WR Blue
Does this mod really make that much of a difference?
I was planning on making my own kit the next time I get bored, but if it really helps I might speed up the process.
Whaddya think???
-Andy
Fastrnu is offline   Reply With Quote
Old 10-22-2002, 10:02 PM   #12
tuca33
Member#: 24303
2002 Impreza WRX
If you have the money..
I would say,,go for the HKS Kit.
It is really nice and very simple install.
Thanks
Tuca
I am a Nerd and could accomplish my install=)thats easy 30 min
Old 10-22-2002, 10:03 PM   #13
atomicapples
Member#: 12626
02 2.5 rs
Whaddya think???
-Andy
iu think its a well worth mod, but many may disagree
Old 10-22-2002, 10:51 PM   #14
slvrwrx02
Member#: 22026
2011 WRX STI
WRB Pearl
just look at the pictures. they're pretty self-explanatory.
--neil
slvrwrx02 is offline   Reply With Quote
Old 10-23-2002, 08:36 AM   #15
Syntax
Member#: 14452
what does the HKS ground mod acutally do?
Syntax is offline   Reply With Quote
Old 10-23-2002, 08:45 AM   #16
Eskram
Member#: 16697
2004 2.5 Hybrid 18g
Wagon + LGT 1-4 g00dness!
Nothing more than buying a few starter cables from Discount Auto Parts and attaching those..
I spent ~$9 on my 'grounding mod'
Eskram is offline   Reply With Quote
blitz 550cc, hks header, hks ground wires jdmej20 Private 'For Sale' Classifieds 12 09-27-2004 10:45 AM
Single-point ground mod vs. Multi-point ground mods DrBoy01 Normally Aspirated Powertrain 5 12-05-2003 04:21 PM
Question about the Single Point Grounding mod Bankheist Texas Impreza Club Forum -- TXIC 8 02-25-2002 10:59 AM
The grounding mod Kartoffel Texas Impreza Club Forum -- TXIC 30 02-21-2002 11:04 AM
Battery Connections & Grounding Mod JenisonWRX Electrical & Lighting 10 02-18-2002 11:01 PM
