Old 10-22-2002, 02:18 AM   #1
veedubaholicvr6
Member#: 23078
2003 WRX
BLACK
Exclamation Apexi Turbo Timer Not Working.
In "Time" mode, it's at 0.30 and the LED next to it, lights stays at ORANGE and could not be adjusted, NOR does it keep the engine running.
Also no cruise control function. Anyway to have Timer AND have cruise control???
I did not use the built in A/F function, there for I did not splice the white wire.
I also used HKS harness. Grounded the timer to this bracket that holds glove box on, with 2 connector on the bottom (hope everyone know where i'm talking about)
I have a MY03, and on the passenger side, there isnt a pink wire to splice the E-brake wire off of the timer, so I went in on the red one instead. Here:
I cut the Grey wire here:
I cut the Dark green w/ Black wire off the cruise control button. Here a look:
Maybe i cut and spliced wrong wires????
veedubaholicvr6 is offline   Reply With Quote
Old 10-22-2002, 04:45 AM   #2
veedubaholicvr6
Member#: 23078
2003 WRX
BLACK
I'm an idiot... Maybe because I'm new to Subbies...
I just realized that I looked at the diagram wrong, i had of where the pink wire was confused with I think rear O2 sensor wiring... I knew I did something stupid...
As far as the Green/Black wire, I botched it too..
Hey at least I grounded it right~! But everything is fixed.
I'm doing the Timer/Headunit/Defi Gauges control at the same time, so far everything else work perfect. Just messed up 2 wires, so I did alright.
Well it's 4:20AM and I came back from a perfect test run. So let me go celebrate.
turbo timer not working. unhooked and car still won't turn on nxthxn Interior & Exterior Modification 4 08-07-2009 08:59 PM
AIRBAG light on, turbo timer not working. shadysalezmen Electrical & Lighting 3 05-20-2009 12:02 AM
Viper 5900 Turbo Timer not working SWRT_22B Car Audio, Video & Security 11 04-15-2008 03:24 PM
Apexi Turbo Timer not working!? NewShockerGuy Interior & Exterior Modification 0 08-21-2005 06:34 PM
Anyone is using an Apexi turbo timer in their STi? Does it work with the stock alarm? JDM addict Electrical & Lighting 6 09-17-2003 01:48 PM
